Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-09-2017, 18:38 | #394 (permalink) |
Insane Poster Join Date: Dec 2006
Member: 413606 Status: Offline Thanks Meter: 10 | Format: Log Type - Time(microsec) - Message - Optional Info Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic B - 429409 - debug_level : MID D - 8662 - boot_read_param_partition, Delta B - 442250 - CDT version:3,Platform ID:8,Major ID:1,Minor ID:0,Subtype:0 B - 449173 - sbl1_ddr_set_params, Start B - 452803 - cpr_init, Start D - 30 - cpr_init, Delta B - 458445 - Pre_DDR_clock_init, Start D - 183 - Pre_DDR_clock_init, Delta D - 0 - sbl1_ddr_set_params, Delta B - 472231 - pm_driver_init, Start D - 3385 - pm_driver_init, Delta B - 483150 - pm_driver_init, Start B - 483303 - pm_driver_init, configuring PMIC to do a DVDD reset B - 486719 - turn off PM_LDO_11 for sdcard detetion D - 7991 - pm_driver_init, Delta B - 494466 - clock_init, Start D - 30 - clock_init, Delta B - 500505 - boot_fota_restore_partition, Start D - 335 - boot_fota_restore_partition, Delta D - 107207 - QSEE Image Loaded, Delta - (362544 Bytes) B - 616832 - boot_fota_close_hdev, Start D - 0 - boot_fota_close_hdev, Delta B - 623481 - Image Load, Start D - 274 - SEC Image Loaded, Delta - (2048 Bytes) B - 631868 - sbl1_efs_handle_cookies, Start D - 274 - sbl1_efs_handle_cookies, Delta D - 27938 - QHEE Image Loaded, Delta - (45784 Bytes) B - 667645 - RPM loading is successful. D - 68076 - RPM Image Loaded, Delta - (176344 Bytes) D - 329339 - APPSBL Image Loaded, Delta - (1305052 Bytes) B - 1067622 - QSEE Execution, Start D - 61 - QSEE Execution, Delta B - 1073447 - SBL1, End D - 897158 - SBL1, Delta S - Flash Throughput, 119000 KB/s (1891772 Bytes, 15890 us) S - DDR Frequency, 400 MHz Android Bootloader - UART_DM Initialized!!! device type 1 = 0x0 device type 2 = 0x8 device type 1 = 0x0 device type 2 = 0x8 device type 1 = 0x0 device type 2 = 0x8 rt5033_set_charger_enable: charger enable(0x2) device type 1 = 0x0 device type 2 = 0x8 device type 1 = 0x0 device type 2 = 0x8 BOOTLOADER VERSION : A500FUXXS1CQC4 0x8f7503f0: 00000000 00000000 00000000 0000000f |................| 0x8f750400: 00000000 00000003 00000000 8f7503fc |..............u.| 0x8f750410: 00000000 8f675fcc 8f7504dc 8f644064 |......g...u.d.d.| 0x8f750420: 8f750438 8eba3bc1 00000000 00000007 |..u.............| 0x8f750430: 8f603780 8f675fd0 8f676390 8eba3bc1 |......g..cg.....| 0x8f750440: 00000001 8eba3bc1 8f676340 8f738fac |.........cg...s.| 0x8f750450: 8f7443ac 8eba3bc1 8f67e53c 8f73554c |.Ct.......g.LUs.| 0x8f750460: 8f7504dc 8f61193c 8f73554c 8f62edec |..u...a.LUs...b.| Any thoughts? samsung a500fu. I've tryed to flash combination file from z3x support, unlock it, then when i want to flash normal firmware (latest version), give a error about file size is too big. When i reset it in download mode, the phone is dead, just vibrate once. thank you |
