Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-03-2013, 21:43 | #31 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | Starting kernel at 0x40008000... SWITCH_SEL(3) Uncompressing Linux... done, booting the kernel. PMIC rev = PASS2(4) mmc_initialize: mmc->capacity = 30777344 þinitialize_ddi_data: usable! (0:0x0) PARAM ENV VERSION: v1.0.. <start_checksum:331>CHECKSUM_HEADER_SECTOR :4096 <start_checksum:333>offset:50, size:6296 <start_checksum:336>CHECKSUM_HEADER_INFO : NeedChecksum:0 PartNo:20 Not Need Movinand Checksum Movinand Checksum Confirmation Pass init_fuelgauge: fuelgauge power ok get_battery_detect: battery is missed init_fuelgauge: battery is not detected, vcell(3571), soc(12) init_microusb_ic: MUIC: CONTROL1:0x1b init_microusb_ic: MUIC: CONTROL1:0x1b init_microusb_ic: MUIC: CONTROL2:0x3b init_microusb_ic: MUIC: CONTROL2:0x3b PMIC_ID = 0x02 PMIC_IRQSRC = 0x00 PMIC_STATUS1 = 0x10 PMIC_STATUS2 = 0x00 PMIC_PWRON = 0x0b PMIC_IRQ1 = 0x00 PMIC_IRQ2 = 0x00 s5p_check_keypad: 0x0 s5p_check_reboot_mode: INFORM3 = cafebabe ... skip s5p_check_upload: MAGIC(0x0), RST_STAT(0x20000000) microusb_get_attached_device: STATUS1:0x3c, 2:0x00 s5p_check_download: 0 microusb_get_attached_device: STATUS1:0x3c, 2:0x00 check_pm_status: non chargable jig, bypass check power ddi type = 1, S.LSI cmu_div:6, div:2, src_clk:880000000, pixel_clk:62614944 42, 16, a2, load_kernel: loading boot image from 106496.. - read_bl1 pit_check_signature (BOOT) valid. if_ddi_data: succeeded. (0:0x0) ATAG_CORE: 5 54410001 0 0 0 ATAG_MEM: 4 54410002 20000000 40000000 ATAG_MEM: 4 54410002 20000000 60000000 ATAG_MEM: 4 54410002 20000000 80000000 ATAG_MEM: 4 54410002 1ff00000 a0000000 ATAG_SERIAL: 4 54410006 4df10aaf 49548fe7 ATAG_INITRD2: 4 54420005 42000000 811fe ATAG_REVISION: 3 54410007 b ATAG_CMDLINE: 69 54410009 'console=ram loglevel=4 sec_debug.level=0 sec_watchdog.sec_pet=5 androidboot.debug_level=0x4f4c sec_log=0x200000@0x46000000 s3cfb.bootloaderfb=0x5ec00000 lcdtype=1 consoleblank=0 lpcharge=0 lpj=3981312 vmalloc=176m oops=panic pmic_info=67 cordon=e868b21b22928d1fefb4c21311a6b15e androidboot.emmc_checksum=3 androidboot.bootloader=N7100XXALJ3 androidboot.serialno=4df10aaf49548fe7 snd_soc_core.pmdown_time=1000' ATAG_NONE: 0 0 Starting kernel at 0x40008000... SWITCH_SEL(3) Uncompressing Linux... done, booting the kernel. |
10-04-2013, 15:05 | #34 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | N7100 Dead Boot Repair, 2nd time failed I bought the ready-made SD Card and Download-mode clip I followed the process (removing LCD, Put SD Card, Connect Download Mode Clip and Wait for 5 Minutes). Phone connected to odin after 5 mins and I flashed phone - ALL OK. (I flashed with only 1 part file) But when I power phone ON again with LCD, still NO Power. This is 2nd time i experience this. Pls any advice ? But with i9300, I have done 3 with same SD card and clip and all worked OK after FLash with 3-part file. |
10-05-2013, 03:34 | #37 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | hello, what's this error on my N7100? pls. help. phone can not power on. Uploaded with ImageShack.us |
10-05-2013, 11:45 | #38 (permalink) | |
Freak Poster Join Date: May 2012 Location: Beirut Age: 39
Member: 1759307 Status: Offline Sonork: 100.1636995 Thanks Meter: 56 | Quote:
you're done, it is just the display will not turn on... just enter download mode with key combo or usb jig (the screen will still be black) but odin will detect it, flash your phone | |
10-05-2013, 11:46 | #39 (permalink) |
Member: 1759307 Status: Offline Sonork: 100.1636995 Thanks Meter: 56 | boot repair done for n7100, i flashed with 4 file with pit and repartition but iam stuck in a boot loop, tried hard reset but nothing any idea? |
10-05-2013, 12:49 | #40 (permalink) |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | TN default <OK> <OK> [DVFS] INT(1) : 0 DRAM Type : LPDDR2 8G [DVFS] MIF(3) : 0 [EPLL][VPLL][CLK_DIV] OK <OK> [LOCK SW/HW]ARM:0/0 INT:0/0 G3D:0/0 MIF:0/0 SHIFT:0/0 [DVFS] ARM(0) : 5 [DVFS] INT(1) : 0 [DVFS] G3D(2) : 0 [DVFS] MIF(3) : 0 [SD_INIT SDMMC_HighSpeedONE] SD_READ: 20000 20000 0x40008000 -> 631528 usec <OK> Inp32(uAddr) : 0xffffffff LINUX Bootingüq!?ÕTN default <OK> <OK> [DVFS] INT(1) : 0 DRAM Type : LPDDR2 8G [DVFS] MIF(3) : 0 [EPLL][VPLL][CLK_DIV] OK <OK> [LOCK SW/HW]ARM:0/0 INT:0/0 G3D:0/0 MIF:0/0 SHIFT:0/0 [DVFS] ARM(0) : 5 [DVFS] INT(1) : 0 [DVFS] G3D(2) : 0 [DVFS] MIF(3) : 0 [SD_INIT SDMMC_HighSpeedONE] SD_READ: 20000 20000 0x40008000 -> 631848 usec <OK> Inp32(uAddr) : 0xffffffff LINUX Bootingøq!? i have n7100 note 2 all time stuck here win xp win 7 both same |
10-05-2013, 14:53 | #41 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Dhaka,Bangladesh
Member: 80250 Status: Offline Sonork: 100.1602959 Thanks Meter: 76 | sir today i successfully do samsung i9300. now coming download mode only. afte repair i flash with odin.using mx.pit and 4.1.2 latest firmware. after flashing now phone showing firmware upgrade encountered an issue. i try again flashing but now flashing fail. what can i do pls help |
10-05-2013, 21:10 | #44 (permalink) |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Online Sonork: 100.1623850 Thanks Meter: 157 | |
The Following 3 Users Say Thank You to .::intel32::. For This Useful Post: |
