Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-31-2015, 18:38 | #66 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Also picture not are visible can read good this: Quote:
BR | |
04-13-2015, 10:31 | #67 (permalink) |
Major Poster Join Date: Jun 2014
Member: 2197465 Status: Offline Sonork: none Thanks Meter: 7 | reply pls help me i try this procedure i put deadboot memory card in galaxy note 2,,and insert a baterry follow by the uart cable and proced teraterm,,and it appear like this,,,can u give me and advice what solution to solve this problem? i change another memory card and burn the files maybe it solve? but still going on,,pls give me a solution Last edited by ...:::::NP™:::::...; 04-14-2017 at 21:21. Reason: Main post (big) quote removed |
04-28-2015, 14:47 | #70 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Misiones
Member: 710759 Status: Offline Sonork: No Thanks Meter: 329 | [DVFS] INT(1) : 0 DRAM Type : LPDDR2 16G [DVFS] MIF(3) : 0 [EPLL][VPLL][CLK_DIV] OK <OK> [LOCK SW/HW]ARM:0/0 INT:0/0 G3D:0/0 MIF:0/0 SHIFT:0/0 [DVFS] ARM(0) : 5 [DVFS] INT(1) : 0 [DVFS] G3D(2) : 0 [DVFS] MIF(3) : 0 [SD_INIT SDMMC_NormalSpeedONE] SD_READ: 20000 20000 0x40008000 -> 486823 usec <OK> Inp32(uAddr) : 0xfffeea00 LINUX Bootingø##%50 is stoped in this |
04-30-2015, 19:08 | #73 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @1986jhong, instead of quote a big post of this only for waste forum space cannot read this belowe? Quote:
br | |
05-16-2015, 17:06 | #74 (permalink) |
Junior Member Join Date: Jul 2007
Member: 552967 Status: Offline Thanks Meter: 7 | TN default <OK> <OK> [DVFS] INT(1) : 0 DRAM Type : LPDDR2 16G [DVFS] MIF(3) : 0 [EPLL][VPLL][CLK_DIV] OK <OK> [LOCK SW/HW]ARM:0/0 INT:0/0 G3D:0/0 MIF:0/0 SHIFT:0/0 [DVFS] ARM(0) : 5 [DVFS] INT(1) : 0 [DVFS] G3D(2) : 0 [DVFS] MIF(3) : 0 [SD_INIT SDMMC_HighSpeedONE] SD_READ: 20000 20000 0x40008000 -> 422477 usec <OK> Inp32(uAddr) : 0xea00007e FW Booting MMC Init Fail. my phone is N7100 i tried with 2 memory card......pls help |
05-17-2015, 09:53 | #75 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Now with ATF you can Repair for to have totally New other time...also the eMMc is TOTALLY DEAD and Jtag not repair. If have Atf and enough knowdledge about Jtag and Hw can solve you problem, in other case ask for help to who is able to work in this. BR allumts | |
