Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 01-12-2013, 15:03   #1 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 147
samsung s3 mobile network not available
sir i have samsung i9300 S3 all is well.
but with call mobile network not available
androaid version 4.0.4
imei 0049990-----
how to fix the problem
Old 01-12-2013, 17:01   #2 (permalink)
Member: 228579
Sonork: 100.1612511
Thanks Meter: 94
wat is the story ?
and do yu have spt or z3x?
Old 01-13-2013, 03:27   #3 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Thanks Meter: 99
if the hardware conditions r ok then try to find out the odin for s3 it is much btter than spt and z3x
Old 01-13-2013, 07:02   #4 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 147
Originally Posted by siyahhh View Post
wat is the story ?
i have z3x and volcano
Old 01-13-2013, 07:08   #5 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 147
how to use the odin plz explain if possible
i have try i9300 before some month after root same problem
then imei was 00000000--
Old 01-13-2013, 13:30   #6 (permalink)
Member: 228579
Sonork: 100.1612511
Thanks Meter: 94
1.root phone
2.open z3x select i9100
3.press repair and write imei
4.wait z3x say connect comport
5.disconnect usb,conect c3300k uart cabel
6.finish
The Following User Says Thank You to siyahhh For This Useful Post:
Old 01-14-2013, 14:53   #7 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 147
1.root phone
6.finish
SIR HOW TO ROOT i9300
when i connect phone with z3x usb cable only phone info work
not any other option
and phone is unlocked
i checked *#7465625#
all lock is off
but imei 0049990-----
Plz give me tested solution
Old 01-15-2013, 07:03   #8 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 147
all lock is off
Old 02-19-2014, 12:14   #9 (permalink)
evolutions's Avatar
Member: 863844
Sonork: 100.1587943
Thanks Meter: 40
How To Root Samsung Galaxy S3
1. Download Odin: http://rapidapk.com/uupyaa1g4kiw/Odin3-v1.85_3.zip
2. Put your galaxy s3 in download mode. Hold the down volume key+the home button+ the side power button.
3. Click on volume up and continue
4. Plug in your galaxy S3.
5. Unzip Odin3-v1.85_3.zip and click on extract file, you should get a .exe file when extracted.
6. Download CFRoot (this will give you root access and clockwork mod recovery) CF-Root Download
7. Extract the CF-Root-SGS3-v6.4.zip file to obtain a file named CF-Root-SGS3-v6.4.tar
8.Click on PDA and find where the CFRoot file is.
9. Click start and wait for it to be finished.
10. Now you have officially rooted your galaxy s3.
Old 12-21-2015, 13:29   #10 (permalink)
Member: 2122688
Enable usb debbuging, connect to your pc using usb cable, root your phone (kingo root does it prfectly), start Samsung tool pro, select com port, go to repair tab and click on patch certificates. I've tried all other solutions I found on different forums, bricked the phone several times, but this did the trick.
Page generated in 0.37152 seconds with 7 queries
