Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-29-2014, 00:41 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Samsung S5 G900F Dead Boot Repair Complete files included Samsung Galaxy S5 Dead Boot Repair Requirements: Odin Dowanload Boot Loader Files (Different firmware Bootloaders soon vil b added In My folder) MSM8974PRO_boot_recovery.pit SM-G900F Boot Recovery Guide PDF Full Folder Here Procedure: Note: If yu get error while flasing Bootloader on working mobile that means yu re on lateset version Bootloader So Need to Create new firmware version Bootloader. To create Bootloader from new firmwares Follow this Guide here * Run Odin flasher. * Click on PIT button and select: MSM8974PRO_boot_recovery.pit * Click on BL button and select: BL_G900Fxxxxxxxx_...tar * Check T Flash option at Odin flasher. * Insert the microSD card inside a working Galaxy S5 SM-G900F mobile phone * Put the working Galaxy S5 SM-G900F mobile phone into Download Mode * Connect the GS5 mobile phone to the computer using the USB cable. * When Odin3 flasher detects the device, Click on Start button * After Odin3 do his job, You will get the PIT and Bootloader files on the microSD card * Remove the microSD card from the working GS5 and insert it inside the Dead Galaxy S5 mobile phone. * Press and Hold the Volume Down key + Home key + Power key. * If the recovery process completed successfully, You will get the dead Galaxy S5 device into Download Mode. * Now you have to flash your device with full firmware package Pit, Bootloader, AP, CP, And CSC files. Last edited by ...:::SHAMIM:::...; 07-18-2018 at 09:49. Reason: broken link added |
The Following 32 Users Say Thank You to jamesjerss For This Useful Post: |
11-29-2014, 09:20 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | Samsung S5 G900F Dead Boot Repair Complete files included bro my samsung g900f imei null any solution Last edited by gsm_masud7; 10-12-2017 at 09:11. |
The Following User Says Thank You to gsm_masud7 For This Useful Post: |
11-29-2014, 09:24 | #3 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | @gsm_masud7 First flash phone to latest firmware,and check imei show or not,if not then try to reset efs with prof tools. PS: reset efs will erase your original imei and you have to use super/service imei. |
11-29-2014, 10:11 | #5 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Try othr taiwan nd Russian firmwares if same must be baseband ic issue . if yur efs is corrupted yur mob vil not boot normally aftr flash so it seems lik baseband chip. Br james Sent from my SM-G900F using Tapatalk |
