Samsung S5 G900F Dead Boot Repair Complete files included Samsung Galaxy S5 Dead Boot Repair http://www.androible.com/wp-content/...y-S5-G900F.png Requirements: Odin Dowanload Boot Loader Files (Different firmware Bootloaders soon vil b added In My folder) MSM8974PRO_boot_recovery.pit SM-G900F Boot Recovery Guide PDF Full Folder Here Procedure: Note: If yu get error while flasing Bootloader on working mobile that means yu re on lateset version Bootloader So Need to Create new firmware version Bootloader. To create Bootloader from new firmwares Follow this Guide here * Run Odin flasher. * Click on PIT button and select: MSM8974PRO_boot_recovery.pit * Click on BL button and select: BL_G900Fxxxxxxxx_...tar * Check T Flash option at Odin flasher. * Insert the microSD card inside a working Galaxy S5 SM-G900F mobile phone * Put the working Galaxy S5 SM-G900F mobile phone into Download Mode * Connect the GS5 mobile phone to the computer using the USB cable. * When Odin3 flasher detects the device, Click on Start button * After Odin3 do his job, You will get the PIT and Bootloader files on the microSD card * Remove the microSD card from the working GS5 and insert it inside the Dead Galaxy S5 mobile phone. * Press and Hold the Volume Down key + Home key + Power key. * If the recovery process completed successfully, You will get the dead Galaxy S5 device into Download Mode. * Now you have to flash your device with full firmware package Pit, Bootloader, AP, CP, And CSC files. |
Samsung S5 G900F Dead Boot Repair Complete files included bro my samsung g900f imei null any solution http://s25.postimg.org/izzx8c08v/20141129_105828.jpg http://s25.postimg.org/vfwn22tkv/20141129_105722.jpg |
@gsm_masud7 First flash phone to latest firmware,and check imei show or not,if not then try to reset efs with prof tools. PS: reset efs will erase your original imei and you have to use super/service imei. |
ander solution....... |
Br james Sent from my SM-G900F using Tapatalk |
Samsung G900P boot repair !!!! |
Br james |
for dead boot s5.must need working s5 unit our hand??? |
if yu dnt hav wrking device use g900f sdc files to repair boot only yu need atf box nd sdc file . Br james |
g900w8 boot repair is posible?? |
Br james |
Can anyone help me with a image file for SM-G900f?Image created from a recovery Sdcard with HDD Raw copy tool for example. |
