Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-17-2012, 15:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: BD.UAE. QATAR SAUDI INDIA
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | samsung s5830i flash problem how to flash samsung s5830i need pitt file have flash file amd odin but pitt file not available site |
02-18-2012, 06:35 | #2 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
As you always used to get the Best and the Easiest Tutorials from our How To Guides, also today we will try to give you the new Guide about updating Firmware of new Samsung model S5830 Galaxy Ace. Here are some features of Samsung S5830 Galaxy Ace: - GSM 850 / 900 / 1800 / 1900 - HSDPA 900 / 2100 - LCD TFT capacitive touchscreen, 16M colors - Accelerometer sensor for UI auto-rotate - Touch - sensitive controls - TouchWiz v3.0 UI - Swype text input method - Internal Memory 158 MB storage - MMC microSD, up to 32GB, 2GB included - Wi-Fi 802.11 b / g / n, DLNA - Bluetooth v2.1 with A2DP - Camera 5 MP, 2592x1944 pixels, autofocus, LED flash - OS Android OS, v2.2 (Froyo) - CPU 800 MHz ARM 11 processor, Adreno 200 GPU, Qualcomm MSM7227 chipset - Stereo FM radio with RDS - A - GPS support - MP4 / H.264 / H.263 player - MP3 / WAV / eAAC+ player - Organizer - Document editor - Image editor - Google Search, Maps, Gmail,YouTube, Calendar, Google Talk, Picasa integration - Voice memo/dial - Predictive text input Firmware Update Steps: 1 run Samsung S5830 Galaxy Ace Downloader all samsung phone downloder here SAMSUNG Flashing Programs 2 Select OPS file : Cooper_v1.0.ops in his field. 3 Click BOOT button and select: APBOOT_S5830xxxxx_xxx...._user_low_true.tar.md5 4 Click Phone button and select: MODEM_S5830xxxxx_xxx...._REV03.tar.md5 5 Click PDA button and select: CODE_S5830xxxxx_xxx...._REV03_user_low_true.tar.md 5 6 Click CSC button and select: CSC_S5830xxxxxx_xxx......_REV03_user_low_true.tar. md5 7 Put your phone into Download Mode: Press middle Key ( OK key ) + Power + Volume Down 8 Connect USB cable to your phone and the program must read the Com number it takes 9 Click Start button and the update process will start. 10 Do not touch or remove anything till the device rebooted and you can see PASS word on the program Samsung S5830 Galaxy Ace USB Drivers here Hotfile.com: One click file hosting: Samsung_I5510_USB_Drivers.rar Samsung S5830 Galaxy Ace Original Firmwares. SAMSUNG Flash Files ( S ) Series | |
The Following User Says Thank You to vaghubha_sodha For This Useful Post: |
12-12-2012, 06:21 | #11 (permalink) |
Junior Member Join Date: Dec 2012 Location: Pune Age: 30
Member: 1850043 Status: Offline Thanks Meter: 0 | Samsung s5830i download mode problem I have Samsung s5830i but it is not going into download mode only a blank screen appears looks like someone write a wrong binary file what should i do plz help me. |
07-10-2013, 14:44 | #14 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | How To Update Samsung S5830i Galaxy Ace Firmware by Odin Flasher [FONT=verdana]Samsung S5830i is also known as Galaxy Ace but there are two differences between this one and the Older one ( S5830 ), In the S5830i model the CPU is 832MHz and Bluetooth V3.0 when the S5830 has 800 MHz CPU and BT V2.1. The other Features of the Both models are the same but the Firmware and Flashing program is not, So here we will try to explain how and what to use when you want to Update your Samsung S5830i Firmware. Tools: - Samsung S5830i Firmware Package S5830i Firmwares: S5830i PIT File Android 2.3.6: http://hotfile.com/dl/188531779/edba...2.3.6.zip.html - Odin Flasher http://www.4shared.com/file/RYxLQjAo...ownloader.html - Original USB Drivers http://hotfile.com/dl/143026020/1167...300_0.rar.html Last edited by gcceleghg; 07-10-2013 at 14:50. |
The Following User Says Thank You to gcceleghg For This Useful Post: |
07-10-2013, 14:52 | #15 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Firmware Update Steps: S5830i - Run Odin flasher and check these options: Re-Partition, Auto Reboot, F.Reset Time. - Now you have to select the Firmware files that will be used by Odin to Update your phone: PIT: cooperve_0623.pit BOOTLOADER: DefaultCalDataWithBoot_S5830ixxxxx_REV00.tar.md5 PDA: PDA_S5830ixxxxx_REV00.tar.md5 PHONE: MODEM_S5830ixxxxx_REV00.tar.md5 CSC: GT-S5830i-MULTI-CSC-Oxxxxx.tar.md5 - Put your phone into Download Mode: Press Volume Down Key + Volume Up Key + Power. - Connect USB cable to phone and PC and install drivers ( If needed ). - Make sure that Odin can detect the Com Port number of your connected phone. - Click Start button on Odin program to begin the update process. - Odin flasher will update your phone then will restart it automatically. - After your phone completely on do full reset by this code: *2767*3855#. - Wait till the phone rebooted and setup the needed options to use it the way you like. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
