Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 04-12-2014, 11:59   #16 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 105
Connecting to Phone,Wait...Done
Factory Resetting Phone... Please Wait
>>Done!Phone will Restart Now.
problem just me contact me [email protected]
Old 04-14-2014, 10:10   #17 (permalink)
Member: 2089757
Thanks Meter: 8
s7262 hard reset
thanks brother it is a tested solution i have tried it with odinv3.07 it work for me
Old 04-14-2014, 22:09   #18 (permalink)
Member: 630795
Thanks Meter: 177
My phone display turns white , phone is working but screen is white . flashed many stock roms but all the same ?? any suggestions??
Old 04-16-2014, 18:20   #19 (permalink)
Member: 1890019
Thanks Meter: 21
Thumbs up s7262 hard reset 100% tested :)
s7262 hard reset
first press power key suddenly press vol plus and home key (center key )
after on display release only power key not vol up and home key
after that phone show whipe data factory reset
use up down for volume key
press power is for ok
simple
Old 04-18-2014, 07:04   #20 (permalink)
rabindar's Avatar
Member: 1277253
Sonork: 100.1617779
Thanks Meter: 33
Originally Posted by janu_shivam View Post
Samsung s7262 hard reset
This trick is 100000000000000000% ok i am tested
yes its works for me 100%%%%%%%%%%% tested
yes its really works.***********
Old 04-20-2014, 15:28   #21 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
Samsung s7262 dual sim Restart solution
S7262 Do Not Going Android Menu Apply This Solution
Apply CSC Just Start Now Set going for android menu easily than just wipe restart phone now problem solve
Successfull By G$M @deel
The Following 2 Users Say Thank You to .....::::GsmAdeel:::::..... For This Useful Post:
Old 04-22-2014, 14:49   #22 (permalink)
dan0007's Avatar
Member: 38050
Thanks Meter: 61
Flash your phone with 4fils .Flashing only csc fil to reset phone is not perfect solution.First try reset by bouton if not working full flash phone with 4 fils.You get this problem because this csc (S7262XXUAMJ3) firmware is different to your phone firmware.
The Following User Says Thank You to dan0007 For This Useful Post:
Old 04-23-2014, 12:54   #23 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
s 7262 succsesful pattren lock
Old 04-24-2014, 23:40   #24 (permalink)
Member: 2121192
s 7262 succsesful pattren lock via odin
Old 04-28-2014, 17:13   #25 (permalink)
idrish911's Avatar
Member: 1497850
Sonork: 100.1601368 QQID:21952428
Thanks Meter: 1,575
Originally Posted by ashish_telecom View Post
workig solution keep it up..
Old 04-30-2014, 05:02   #26 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
bro 90% this solution not working
Old 04-30-2014, 14:15   #27 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
YOu solution make my mobile white display.. Where are admin to remove this post which is doing brick users mobile
The Following 2 Users Say Thank You to zishhaider For This Useful Post:
Old 05-02-2014, 21:46   #28 (permalink)
Registered User
Member: 1361365
Sonork: 100.1670394
Thanks Meter: 15
white lcd !!!!!!!! any else solution????
Old 05-04-2014, 18:56   #29 (permalink)
mr. nokia's Avatar
Member: 73117
Thanks Meter: 31
it works for me perfect one time
but in the second phone it gave me white screen
Old 05-04-2014, 20:31   #30 (permalink)
mr. nokia's Avatar
Member: 73117
Thanks Meter: 31
my device is white screen
how can i solve this problem
Page generated in 0.23629 seconds with 8 queries
