Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-28-2014, 13:00 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Samsung S7262 Root solution needed? I tried Kingoroot, VRoot, TowelRoot, Flashing files from XDA Developer forum. Anyone have the solution for Root. Best Regards. Siddeque. |
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
08-29-2014, 21:15 | #5 (permalink) | |
Major Poster Join Date: Feb 2014
Member: 2122608 Status: Offline Thanks Meter: 16 | Quote:
bro try this solution Files Required S7262XXUAMI6_ODDAMI6_India_4.1.2_.zip [Credit Tsar3000] Steps to Update Galaxy Star Pro S7262 with S7262XXUAMI6_ODDAMI6_India_4.1.2 Jelly Bean Firmware Step 1: Extract Firmware zip file using WinRAR/7-Zip/WinZip or any other extracting tool, you will get a .tar.md5 file and some other files (optional). Step 2: Extract Odin zip file and you will get Odin3 v3.07.exe along with few other files. Step 3: Switch off the Galaxy Star Pro. Step 4: Boot the device into Download Mode by pressing and holding Volume Down, Home and Power buttons together until a construction Android robot icon with a warning triangle appears on screen. Now press the Volume Up button to enter Download Mode. Step 5: Run Odin on the computer as an Administrator. Step 6: Connect the Galaxy Star Pro to the computer using USB cable while it is in the Download Mode. Wait until Odin detects the device. When the device is connected successfully, the ID: COM box will turn to light blue with the COM port number. Additionally, the successful connected will be indicated by a message saying Added. Note: If the Added message does not appear, then try re-install USB drivers or changing the port on the computer. Step 7: Select the following files in Odin from extracted S7262XXUAMI6_ODDAMI6_India_4.1.2_.zip firmware folder: Click the PDA button and select the .tar.md5 file. Click the Phone button and select file with MODEM in its name. Ignore if there is no such file. Click the CSC button and select file with CSC in its name. Ignore if there is no such file. Click the PIT button and select the .pit file. Ignore if there is no such file. Step 8: In Odin, enable Auto Reboot and F. Reset Time checkboxes. Also, ensure the Re-Partition checkbox is chosen only if a .pit file was chosen in the previous step. Step 9: Verify everything suggested in Step 7 and Step 8 is done correctly. Then hit the Start button to begin the installation process. Step 10: Once the installation process is completed, your phone will restart and soon you will see a PASS message with green background in the left-most box at the very top of the Odin. You can now unplug the USB cable to disconnect your device from the computer. Samsung Galaxy Star Pro S7262 should be now updated with official Android S7262XXUAMI6_ODDAMI6_India_4.1.2_.zip Jelly Bean. Head over to Settings >> About Phone to verify the software version running on the device. Note: If Galaxy Star Pro S7262 stuck at booting animation after Step 10 then go to recovery mode (press and hold the Volume Up, Home and Power buttons together) and perform Wipe data/Factory Reset and Wipe Cache Partition task before selecting reboot system now function. In recovery mode use Volume keys to navigate between options and Power key to select the option. Please note, performing wiping task will erase your device internal memory data and not external SD card data Last edited by ...:::::NP™:::::...; 06-11-2017 at 09:36. Reason: Firmware link update | |
The Following User Says Thank You to Mobile-Repair. For This Useful Post: |
09-13-2014, 10:13 | #9 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | S7262 star pro 100% root done Hi every one let see the procedure which one is help full for me kindly I am sharing to all my friends and I found this solution after more time spend 1) download this "S7262JVUANB2_S7262OJVANB3" file from z3x shell and flash with z3x 2)wipe data factory reset 3)use vroot to root the phone here is some screen shot which I print after complete my procedure http://i59.tinypic.com/x0pmao.jpg http://i58.tinypic.com/b6ouma.jpg If my post will be help full taen say thanks |
10-24-2014, 19:26 | #11 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
try vit this Root_with_Restore_by_Bin4ry_v36.zip enable usb debugging Run the runme bat file 1st try 3) new-standard root if not ok try all | |
12-12-2014, 07:33 | #14 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Friends I solved my problem I got a .tar file from xda if anyone facing the same problem contact me ill share that file. BR. Siddeque. |
