Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-06-2015, 06:55   #1 (permalink)
rajmemon's Avatar
Member: 1131513
Thanks Meter: 60
Question samsung s7582 hangs on logo even after flash !!
tried single and multi files still the same problem
flashing completes but the phone hangs on logo
even recovery menu is not coming
is there any other file ?
Old 10-06-2015, 07:11   #2 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 369
Once format it by VOlume key and power button after flash if old MTK6575 it will be solved 100% the problem .
Old 10-07-2015, 07:29   #3 (permalink)
rajmemon's Avatar
Member: 1131513
Thanks Meter: 60
not working
phone is not coming in recovery mode
Old 10-07-2015, 08:43   #4 (permalink)
red_eagle's Avatar
Member: 1759307
Sonork: 100.1636995
Thanks Meter: 56
for recovery mode the key combination is
VOL UP + VOL DOWN + Home Button + Power Button
when phone turns on release power key and keep pressing the other keys until you get to recovery
clear data and cache and you should be fine
Old 10-07-2015, 09:11   #5 (permalink)
rajmemon's Avatar
Member: 1131513
Thanks Meter: 60
not working
phone is not coming in recovery mode...
Old 10-07-2015, 09:13   #6 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 369
Than the firmware you have flashed is not same as your phones' one .
Old 10-07-2015, 09:25   #7 (permalink)
Member: 2222183
Thanks Meter: 48
Thumbs up 100% solution tested by me...
just change touch 100% tested solution i has been solve this problem (70 pieces ) change touch and post result ....
The Following User Says Thank You to akhtar_in For This Useful Post:
Old 10-07-2015, 15:18   #8 (permalink)
rajmemon's Avatar
Member: 1131513
Thanks Meter: 60
bro
how could changing touch will solve software issue ?
Old 10-07-2015, 15:54   #9 (permalink)
red_eagle's Avatar
Member: 1759307
Sonork: 100.1636995
Thanks Meter: 56
use any box to put your device into recovery, maybe u have vol up button not working
Old 10-08-2015, 05:44   #10 (permalink)
Member: 2222183
Thanks Meter: 48
bro
bro many mobile's clone chip example (Mediatek)i tried to many phone before i try software and change file version but problem same after i check hardware (change lcd and other parts)but when i change touch my problem solve 1000000% ....
Old 10-21-2015, 08:37   #11 (permalink)
GsmVeer's Avatar
Member: 1140401
Sonork: 100.1586294
Thanks Meter: 374
bro i try this butt same problem
Old 01-03-2016, 16:26   #12 (permalink)
Member: 1814409
Sonork: 100.1621741
Thanks Meter: 25
samsung gt s7582 Duos Hang on logo done | GSMSolutionBD.Com
Old 01-03-2016, 16:30   #13 (permalink)
Ayyub Razaa's Avatar
Member: 2509195
Thanks Meter: 51
Remove tuch paid your problme 100% solve...
Page generated in 0.17328 seconds with 9 queries
