Samsung SM-G5528 Playstore Fix File Free. Samsung SM-G5528 Playstore Fix, Wifi Fix, Add Playstore, Add Full Language, Add Call Recoder Here Is File SM-G5528_PlayStore fix File Tricks By combinefile.com.rar Password PHP Code: |
Password www. combinefile. com Use Password Without Spaces. Always Follow The Rules |
Is that flashable? I mean we should flash this from recovery? |
I downloaded the file but not tested yet... It is Odin flashable.. There is a txt file that says: there is trick to flash it Step 1- first flash These Files, set will blink, Step2- go to recvoery reset user data and reset cache Step3- then start set in download mode then flash again |
If Link Not Working Here is Link Download SM-G5528_20051_PlayStore fix By **********.rar | Marhaba Firmware |
http://i67.tinypic.com/214nl1j.png @voltron2008 you are so informative man.i like your tips from so much time.you helped me in past many times. can you suggest me any other trick? |
it stucks on this stage. |
What is the version of your firmware? |
G5528zmu1aqe1 6.0.1 |
It stucks at what stage? did you followed the steps in txt file: "there is trick to flash it Step 1- first flash These Files, set will blink, Step2- go to recvoery reset user data and reset cache Step3- then start set in download mode then flash again" |
change odin version and try again. After Flash Hard reset your Set. |
system.img.ext4 and then nothing happen. even not fail and no done.just stuck |
@all just download & install crom service apk than you able to flash any custom rom or twrp Br Raza400 |
