Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-08-2017, 11:33   #1 (permalink)
Crazy Poster
Member: 2765181
Thanks Meter: 56
Samsung SM-G5528 Playstore Fix File Free.
Samsung SM-G5528 Playstore Fix, Wifi Fix, Add Playstore, Add Full Language, Add Call Recoder
Here Is File SM-G5528_PlayStore fix File Tricks By combinefile.com.rar
Password
PHP Code:
www.combinefile.com
Last edited by ...:::::NP™:::::...; 10-08-2017 at 21:56. Reason: Remove has been redirected URL link from password .
Old 10-08-2017, 11:41   #2 (permalink)
Crazy Poster
Member: 2765181
Thanks Meter: 56
Password www. combinefile. com
Use Password Without Spaces.
Always Follow The Rules
Old 10-08-2017, 21:01   #3 (permalink)
Member: 2765480
Thanks Meter: 3
Is that flashable? I mean we should flash this from recovery?
Old 10-08-2017, 21:04   #4 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 1,235
I downloaded the file but not tested yet... It is Odin flashable..
There is a txt file that says:
there is trick to flash it
Step 1- first flash These Files, set will blink,
Step2- go to recvoery reset user data and reset cache
Step3- then start set in download mode then flash again
Old 10-09-2017, 07:11   #5 (permalink)
Crazy Poster
Member: 2765181
Thanks Meter: 56
If Link Not Working Here is Link
Download SM-G5528_20051_PlayStore fix By **********.rar | Marhaba Firmware
Old 10-18-2017, 17:34   #6 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
@voltron2008
you are so informative man.i like your tips from so much time.you helped me in past many times.
can you suggest me any other trick?
Old 10-18-2017, 17:34   #7 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
it stucks on this stage.
Old 10-18-2017, 17:55   #8 (permalink)
Member: 1713296
Thanks Meter: 67
What is the version of your firmware?
Old 10-18-2017, 17:59   #9 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
G5528zmu1aqe1
6.0.1
The Following User Says Thank You to MYUNLOCKING For This Useful Post:
Old 10-18-2017, 20:19   #10 (permalink)
Member: 861795
Thanks Meter: 1,235
It stucks at what stage? did you followed the steps in txt file:
"there is trick to flash it
Old 10-19-2017, 09:52   #11 (permalink)
Crazy Poster
Member: 2765181
Thanks Meter: 56
change odin version and try again. After Flash Hard reset your Set.
Old 10-19-2017, 14:29   #12 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
it stucks on
system.img.ext4
and then nothing happen.
even not fail and no done.just stuck
Old 10-19-2017, 14:29   #13 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
which version of odin i use?
Old 10-19-2017, 17:35   #14 (permalink)
Member: 861795
Thanks Meter: 1,235
try 3.10.7
Odin3 v3.10.7.rar
Old 04-13-2018, 16:18   #15 (permalink)
raza400's Avatar
Member: 1661953
Sonork: 100.1666694
Thanks Meter: 1,282
@all
just download & install crom service apk
than you able to flash any custom rom or twrp
Raza400
Page generated in 0.35686 seconds with 7 queries
