Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-19-2014, 23:03 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Samsung Sm-G7102 Soft Unbrick Tested Firmware + Downgrade From 4.4.2 Guide Samsung Sm-G7102 Soft Unbrick Tested Firmware + Downgrade From 4.4.2 Guide Note:This file Only fix Bootloop issues ,Always Booting in recovery mode, after update to 4.4.2 hang Logo Only recovery mode. Firmware Flashing Method: * Put Mobile in Download Mode By Holding Vol dwn + Home + Pwr * Cnnt vit pc using Usb * Run Odin * Select File in PDA * Uncheck Auto Boot in Odin (Important This Step ) * Click Start * After Flash complete Disconnect yur mobile Remove battery Wait for 20 Insert Battery Pwr ON yur Mobile * If downgraded From 4.4.2 Hard rest it Mobile should Boot * After flash Hard reset it if not Booted Note:Tested on 2 Devices Worked Fine nd IMEI also fine Firmware Download From Here Android 4.3 G7102ZTUANG2_ZZTANG2_BRI_Taiwan_4.3.zip [Credit Tsar3000] Odin Flasher DON'T SAY THANKSJUST PRESS BUTTON BUTTON Last edited by ...:::::NP™:::::...; 08-19-2017 at 12:00. Reason: Download link has been update |
The Following 34 Users Say Thank You to jamesjerss For This Useful Post: |
11-25-2014, 15:28 | #7 (permalink) |
Major Poster Join Date: Aug 2014 Location: surat Age: 34
Member: 2235420 Status: Offline Thanks Meter: 9 | thanx sir solved my problem thanx i will solve problem this trickk Last edited by aZimBahar; 02-17-2016 at 09:10. Reason: Quote removed |
The Following 3 Users Say Thank You to starele_surat For This Useful Post: |
11-27-2014, 20:06 | #9 (permalink) |
Freak Poster Join Date: Jan 2011 Location: ON THE BEACH
Member: 1487630 Status: Offline Sonork: 100.1621007 Thanks Meter: 43 | hi i also got one sm-g7102 just hang on logo i tried to flash with many file but no luck after that i have used ur file and procedure and it works like a charm thanks mr.jamesjerss for ur file and procedure all ur thread is very useful pls give us ur sonork and send us ur thread link to our sonork regards, |
12-03-2014, 08:47 | #13 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Br james | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
12-15-2014, 13:42 | #14 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | anther link to download from sammobile here http://www.----.com/firmwares/confir...TANG2_BRI.zip/ replace " ---- " with sammobile |
