Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-05-2017, 18:43 | #1 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2213928 Status: Offline Thanks Meter: 440 | Samsung (AT&T) [SM-G935A] [SM-G930A] FRP Remove File So here is process of S7_S7edge_Qualcomm FRP. Requirements :- Odin 3.12.X Odin3+v3.12+(PrinceComsy) Naugat 7.0 FRP-USA Naugat 7.0 FRP-USA Marshmallow 6.0.1 FRP-USA Marshmallow 6.0.1 FRP-USA Process :- 1) Connect phone in download mode using vol down + home + power. 2) Connect phone to pc and open odin. 3) Select boot.tar in Cp in odin and start . 4) After flash your phone adb will be on automatic . 5) Then FRP reset with z3x_umt_miracle any tool . That's it your S7_S7edge now FRP Remove |
The Following 29 Users Say Thank You to yuvraj9x2 For This Useful Post: |
11-23-2017, 18:34 | #5 (permalink) | |
Freak Poster Join Date: Jun 2016
Member: 2592628 Status: Offline Thanks Meter: 212 | search Quote:
What is the build number of the phone? Can be found in recovery mode at top of screen. build number starts with model number. I need that to be able to help you. | |
The Following User Says Thank You to obliviousmnd For This Useful Post: |
06-13-2018, 09:56 | #6 (permalink) |
Freak Poster Join Date: Nov 2007 Location: karachi,pakistan Age: 40
Member: 625563 Status: Offline Sonork: Niceguy Thanks Meter: 40 | G935a is not supported in z3x, eft, octopus, umt how to reset frp |
The Following User Says Thank You to jadoon_jadoon For This Useful Post: |
10-15-2018, 11:23 | #9 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Mirpur Azad Kashmir Age: 34
Member: 1154111 Status: Offline Sonork: 100.1620855 Thanks Meter: 158 | g935a u4 frp good jobs well done i tried ok file |
The Following User Says Thank You to kamranas For This Useful Post: |
12-05-2018, 00:14 | #10 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | REMOVE FRP DONE By Sir Real 1000% ok Quote:
FRP REMOVAL ******************************* -FLASH the adb file ABOVE -USE Samsung Frp Remove Tool 1.0 With Nougat Suppprt -SELECT Method 1 -After phone reboot > Drag Notification Area -CLICK SETTING (Gear like) -About > Build number > click 7times > ENABLE OEM UNLOCK -Factory Reset Done 10000% By Sir Real | |
The Following User Says Thank You to Siroartz For This Useful Post: |
12-05-2018, 00:20 | #11 (permalink) |
Member: 2358876 Status: Offline Thanks Meter: 78 | Do This FRP REMOVAL ******************************* -FLASH the adb file ABOVE -USE Samsung Frp Remove Tool 1.0 With Nougat Suppprt -SELECT Method 1 -After phone reboot > Drag Notification Area -CLICK SETTING (Gear like) -About > Build number > click 7times > ENABLE OEM UNLOCK -Factory Reset Done 10000% By Sir Real DONT FOGET TO PRESS THANKS |
03-10-2019, 16:39 | #15 (permalink) | |
Insane Poster Join Date: Sep 2017 Location: Jhelum
Member: 2762776 Status: Offline Thanks Meter: 22 | Quote:
It works perfectly everyone should try this. Thankyou very much because I've been trying with every single tool but it didn't worked | |
The Following User Says Thank You to hassananwer77 For This Useful Post: |
