Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 01-20-2020, 11:49   #1 (permalink)
Member: 2170791
Thanks Meter: 50
Samsung T290 FRP byapass
Hello how to unlock FRP on samsung tab T290(No sim model)..
Old 01-21-2020, 05:34   #2 (permalink)
Member: 2170791
Thanks Meter: 50
Cool Samsung Tab A 8.0 (2019) SM-T290 FRP Unlock Done
https://i.ibb.co/Zcz3bPK/s-l400.jpg
It's done by CHN firmware
In this model there is bot support SIM method and combination method
1- Download and flash CHN firmware from support sites
2- Activate device and enable OEM (CHN firmware automatically bypass FRP)
3- Flash with global firmware
Enjoy it.........
The Following User Says Thank You to ksajin For This Useful Post:
Old 12-23-2022, 12:56   #3 (permalink)
Member: 3028038
hi, I tried this and when the tablet rebooted it got to "Set up Baidu Location Services" and ticking/unticking boxes made no difference it just relooped back yo this point ?
Old 12-23-2022, 12:57   #4 (permalink)
Member: 3028038
Old 10-25-2023, 20:23   #5 (permalink)
Member: 2134885
Thanks Meter: 2
First flash fimware original for you region, second Flash the chinese firmware only ap and bl, after power on and try activate, once active put on download mode again and flash the cp and csc(this for activate oem unlock) after put wifi and active oem unlock and reflash again the firmware original
The Following User Says Thank You to kluan For This Useful Post:
Old 12-06-2023, 22:14   #6 (permalink)
Member: 2511800
Thanks Meter: 7
solutions I found
U3 firmwares
1. flash this firmware T290ZCU3ATD2 ONLY BL+AP+CSC
2. open device connect wifi and unlock the bootloader and enable oem if found and take off the FRP with the tool of your chooise
3.flash this firmware T290XXS3ATC4
AND DONE WITH THE U3 Firmares, if someone need the firmwares I can post it here
Old 12-06-2023, 22:22   #7 (permalink)
Member: 2511800
Thanks Meter: 7
U4 Firmwares
Flash this firmware T290XXS4CWD1
- pass the setup wizard > go the settigs quicky > developer options > activate ADB ( in this process your tablet can have a blocked message dont worry and start the process and make it faster)
- once the ADB is active , choose the tool of your preference and take of the FRP
- After the tool done the work , reflash the software and the job is done
IF SOMEONE NEED THE FIRMWARE LET ME KNOW TO POST IT HERE
The Following User Says Thank You to topspin220 For This Useful Post:
Page generated in 0.15451 seconds with 8 queries
