Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-22-2016, 20:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | 1. Do you know from where this Z1 is? India has CPD5 as latest... CPD6 is from Bangladesh or Sri Lanka or Nepal... You can find out, what your CSC is... by removing battery... Check Serial Number with Kies 3 (Window s Tool)... 2. You could try 4 part Firmware for repair... If no luck... maybe something Unlock related... maybe no IMEI or something in this direction... With UART cable you could log, why... Best Regards |
08-24-2016, 07:26 | #3 (permalink) | |
Freak Poster Join Date: Aug 2013 Location: roorkee Age: 23
Member: 2006027 Status: Offline Sonork: 1645658 Thanks Meter: 36 | sir im use samsung smart manager ang kies but my sn no not mach in server Quote:
sir im use Samsung smart manager and kies but my sn no not mach in server And flashing compalite with 4 firmware but set same condition my sn.RZ1G21JZMCP IMEI 35739406385246/7 | |
The Following User Says Thank You to alamtelecom458 For This Useful Post: |
08-24-2016, 11:42 | #4 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Need some time to update my Kies 3... For now I can not check any Serial Number... Maybe Server "offline" or require latest Kies... If you are sure you have CSC INS (India)... then flash: CPD5 Maybe you could try then my rooted Firmware (rootfs.img) from here: http://forum.gsmhosting.com/vbb/f200...-2092789/Maybe Z1 start/boot then... I need some time to check f$%& Kies 3... Will post later result. Best Regards |
08-24-2016, 12:04 | #5 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | I have updated my Kies 3 to latest Version... Tried few SN from Z1... Then also 1 from SM-Z300H... Looks like Samsung Server Database is ""offline""... No idea if temporary or for ever... ----------------------- You tried Recovery Mode ? Volume + Home Power on Try Safe mode If nothing better... then try also Phone initialization (Factory Reset)Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
08-27-2016, 05:54 | #6 (permalink) | |
Member: 2006027 Status: Offline Sonork: 1645658 Thanks Meter: 36 | Sir thanku for reply Quote:
Sir i am flash cpd5 firmware but same hang on logo not going to recvery and safe mode | |
08-31-2016, 03:04 | #8 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | @ alamtelecom458 Any progress? Sorry, I have problems to verify Serial Numbers in my f&% Kies 3... Now I am not sure if this feature is obsolete for Z1 and Z3... Or my f.&% Kies 3 not proper work. I have never tried to flash Firmware from other country... I have Z1 for INS (India)... No idea if wrong Firmware create Security problem... as sboot.bin (Bootloader) is inside these Firmware packages... No idea if INS (India) device flashed with BNG (Bangladesh) or NPL (Nepal)... if Firmware mix lead to such problem... @ salekborhan Please, try to post your Link in other form... M a y b e try with Caps... Link is rendered invalid by Forum Software... But maybe something usefull inside your post. Best Regards |
08-31-2016, 03:09 | #9 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Firmware archive | Samsung Updates You could also try oldest public available Firmware, it is for INS (India): Z130HDDU0ANL7 Old Firmware contain sometimes low Security checks... Maybe this helps to bypass your problem. To have access again.Best Regards |
08-31-2016, 03:41 | #10 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Damn. Looks like Samsung disabled this feature for Z1 and Z3 in Kies 3... To use Serial Number for Firmware Init... I have also short checked Serial N. of SM-Z200F with no luck... But my GT-I9305 S/N was successfull... So my Kies 3 is proper working... Best Regards |
09-06-2016, 03:34 | #12 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | You know the history of this device? Working condition... not working? Firmware before? What was the reason for update? Again. I can see in your Screenshot MIX of different countries... Files not only from India CSC (INS)... So the main question is. Is Security destroyed/killed ? Bootloader mismatch or other Unlock attempt... It is also possible via UART cable to check little bit output during Booting... Something like this: Serial cable instead USB ? UART... - Post #33 Code: Samsung S-Boot 4.0 for SM-Z130H (Nov 18 2015 - 12:11:39) SC7727(EVT 0.0) / 768MB / 0MB / Rev 0 / Z130HDDU0BOK2 --------------------------------------------- MODEL_NAME:\{\{SM-Z130H\}\} eMMC_SERIAL_NUMBER:\{\{removed by @3\}\} --------------------------------------------- microusb_get_attached_device: data_type1=0x0 data_type2=0x8 adc=0x1c [MUIC]SM device_id = 0x11 get_charger_status: data_type=0x8 microusb_get_attached_device: data_type1=0x0 data_type2=0x8 adc=0x1c [MUIC]SM device_id = 0x11 is_usb_cable: data_type=0x8 [IIC DRV:]I2C_HAL_Open: handle=0, ref=1 i2c_open I2C_HAL_Open 0, 0 [IIC DRV:]I2C_HAL_Open: handle=8, ref=1 i2c_open I2C_HAL_Open 1, 8 [IIC DRV:]I2C_HAL_Open: handle=9, ref=2 i2c_open I2C_HAL_Open 2, 9 [IIC DRV:]I2C_HAL_Open: handle=24, ref=1 i2c_open I2C_HAL_Open 3, 24 set_vbuslimit_current : SM5701_VBUSCNTL (Input current limit) : 0x50 set_fastchg_current : SM5701_CHGCNTL2 (fastchg current) : 0x23 enable_charger: CHG_EN GPIO val : 0 sprd_check_reboot_mode: INFORM3 = f7df5f95 ... sprd_check_reboot_mode: magc_ram_base = 637addb7 ... skip microusb_get_attached_device: data_type1=0x0 data_type2=0x8 adc=0x1c [MUIC]SM device_id = 0x11 get_jig_status: data_type = 0x8 get_jig_status: UART_OFF get_jig_status : 0x4 mach_board_main: PMIC Power On Cause : 0x20c SMPL Disable!! mach_board_main : Entering the calibration [string value]:-3765680218 uart calibrate detecting ~mach_board_main: boot check start (0x0) [int value]:0 [int value]:0 [int value]:0 microusb_get_attached_device: data_type1=0x0 data_type2=0x8 adc=0x1c [MUIC]SM device_id = 0x11 sprd_check_download: 0 [int value]:20300 sprd_check_upload: MAGIC(0x637addb7), RST_STAT(0x0), POR_SRC_FLAG(0x20c) [int value]:0 eica status 0 adie efuse blocks dump: Remove all SIM cards and SD card... maybe Hardware malfunction... What was result with ANL7 Firmware? Best Regards |
09-06-2016, 08:13 | #13 (permalink) | |
Member: 2006027 Status: Offline Sonork: 1645658 Thanks Meter: 36 | Sir how to use this code Quote:
sir How to use UART cabel Wich Device | |
10-05-2016, 03:11 | #14 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | @alamtelecom458 Today tried again Kies 3 with your Serial Number... Kies 3 worked. (Smart Switch) not tested So Kies 3 shows me as result for your Serial Number you have Z1 India device... CSC for India: INS So latest downloadable Firmware is CPD5. Newer Firmware only as FOTA 3,5 MB... No idea if you managed your problem... Best Regards |
10-05-2016, 03:45 | #15 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | CPD6 Firmware is WRONG for your device... It was only for the other countries... Bangladesh, Nepal, Sri Lanka... But not for India INS device... I have never self tried how deadly it could be. To mix different country Firmware on Z1... as sboot (Bootloader(s)) are inside... Maybe if you have flashed CPD6, maybe this is the reason... Only as info/theory. Sorry for late response... but Samsung Server for Serial Numbers was long time not working... Best Regards |
