Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-05-2015, 07:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1807719 Status: Offline Sonork: 100.1619084 Thanks Meter: 30 | SM-G355H/DS Flashing Failed / Firmware Upgrade Encountered an issue Problem tried flashed with odin using firmware- G355HXXU0AOE4_G355HODD0AOE2_G355HDDU0AOE2_HOME_.ta r but flashing failed and phone stuck at warning message to coonect with kies and update kindly suggest me working firmware for this modal |
The Following User Says Thank You to rajugsm77735 For This Useful Post: |
08-05-2015, 07:51 | #2 (permalink) |
No Life Poster Join Date: May 2012 Location: Firmwares
Member: 1761687 Status: Offline Sonork: 100.1669047 Thanks Meter: 494 | Are u sure it is a software problem? where did the flashing faild bro? here is another versions: G355HXXU0AOG1_G355HODD0AOG1_India_4.4.2_Stock_ROM. zip - 604.25 MB G355HXXU0AOE1_G355HODD0AOE1_India_4.4.2_Stock_ROM. zip.zip - 604.18 MB G355HXXU0AOA4_G355HODD0AOA1_India_4.4.2_Stock_ROM. zip - 591.25 MB |
The Following User Says Thank You to Mr.Firmware For This Useful Post: |
08-05-2015, 17:43 | #4 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Test with this firmware, if it fails please post Odin log: Firmware: SM-G355H - Samsung Galaxy Core 2 Duos PDA: G355HXXU0AOF2 CSC: G355HOXE0AOF2 Country: Russia Product Code: SER Version: 4.4.2 Download: cloud.mail.ru - G355HXXU0AOF2_G355HOXE0AOF2_SER.zip Files: Single file, Official, Select via AP(PDA) tab -G355HXXU0AOF2_G355HOXE0AOF2_G355HXXU0AOF2_REV04_HO ME.tar.md5 |
The Following 2 Users Say Thank You to voltran2008 For This Useful Post: |
08-06-2015, 06:46 | #5 (permalink) |
Member: 1807719 Status: Offline Sonork: 100.1619084 Thanks Meter: 30 | odin log <ID:0/067> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> G355HXXU0AOG1_G355HODD0AOG1_G355HDDU0AOG1_HOME_.ta r.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/067> Odin v.3 engine (ID:67).. <ID:0/067> File analysis.. <ID:0/067> SetupConnection.. <ID:0/067> Initialzation.. <ID:0/067> Get PIT for mapping.. <ID:0/067> Firmware update start.. <ID:0/067> SingleDownload. <ID:0/067> system.img <ID:0/067> NAND Write Start!! <ID:0/067> FAIL! <ID:0/067> <ID:0/067> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/067> Removed!! |
08-13-2015, 02:10 | #6 (permalink) |
Freak Poster Join Date: May 2006
Member: 280594 Status: Offline Thanks Meter: 21 | same problem with 2 firmwares.. with 3.09 & 3.10.06 odin <ID:0/024> Added!! <ID:0/024> Odin engine v(ID:3.1005).. <ID:0/024> File analysis.. <ID:0/024> SetupConnection.. <ID:0/024> Initialzation.. <ID:0/024> Get PIT for mapping.. <ID:0/024> Firmware update start.. <ID:0/024> SingleDownload. <ID:0/024> system.img <ID:0/024> NAND Write Start!! <ID:0/024> FAIL! <ID:0/024> <ID:0/024> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/024> Removed!! phone status firmware upgrade encountered an issue. please select recoverymode in kies & try again |
The Following User Says Thank You to dEnw0h For This Useful Post: |
11-12-2015, 09:03 | #7 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Karachi,Pakistan Age: 34
Member: 701004 Status: Offline Sonork: 1626436:danish Thanks Meter: 116 | ID:0/035> Added!! <ID:0/035> Odin v.3 engine (ID:35).. <ID:0/035> File analysis.. <ID:0/035> SetupConnection.. <ID:0/035> Initialzation.. <ID:0/035> Get PIT for mapping.. <ID:0/035> Firmware update start.. <ID:0/035> SingleDownload. <ID:0/035> system.img <ID:0/035> NAND Write Start!! <ID:0/035> FAIL! <ID:0/035> <ID:0/035> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
The Following User Says Thank You to danishrehmanzai For This Useful Post: |
11-12-2015, 10:55 | #8 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | don't flash with that they are give you because it will dead after flash ... u need same firmware Sm-g355h/ds for flashing with . 6 ***** ago i have flash with G355HXXU0AOG1 after the phone is dead i have do jtag all box nothing i have buy another phone for ownr |
The Following 2 Users Say Thank You to gunit1 For This Useful Post: |
11-21-2015, 17:53 | #10 (permalink) |
Member: 1761687 Status: Offline Sonork: 100.1669047 Thanks Meter: 494 | Bro if u want u can test this one: http://forum.gsmhosting.com/vbb/10943687-post6.html a firend told me this one he use for G355H/ds model and it is ok u can test on your own good luck bro Last edited by ...:::::NP™:::::...; 03-23-2018 at 10:53. |
The Following 3 Users Say Thank You to Mr.Firmware For This Useful Post: |
11-30-2015, 13:18 | #11 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629694 Status: Offline Thanks Meter: 50 | wrst phn to flash. first of all we do hardwrk to flash this phn but aftr flash imei gone and yet no solution for imei repair. solution availbe r fake. wht to dooooo |
The Following 2 Users Say Thank You to kulwinder2002 For This Useful Post: |
01-21-2016, 12:45 | #12 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | well i have samsung g355h/ds indian version and i have flashed it with odin but after flash phone is stuck with warning message "Firmware Upgrade Encountered An Issue . Please Select Recovery Mode In Kies & Try Again " so i am confused now ............. i try in z3x box and odin with different firmware but not success in flashing again so what to do now ??? please help me if any one have right & tested solution |
01-21-2016, 12:48 | #13 (permalink) | |
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | Quote:
so what is condition of your phone its live again or same condition ?? if you found any solution please tell me thanks | |
01-21-2016, 14:54 | #14 (permalink) | |
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | [IMG][img=http://s12.postimg.org/zd1f3dc09/success_3.jpg][/IMG] Quote:
file= G355HXXU0ANHB_OXE0ANHB log <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> BL_G355HXXU0ANHB_2631775_REV04_user_low_ship.tar.m d5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> AP_G355HXXU0ANHB_2631775_REV04_user_low_ship.tar.m d5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/006> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CP_G355HXXU0ANHB_2631775_REV04_user_low_ship.tar.m d5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CSC_OXE_G355HOXE0ANHB_2631775_REV04_user_low_ship. tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/006> Odin v.3 engine (ID:6).. <ID:0/006> File analysis.. <ID:0/006> SetupConnection.. <ID:0/006> Initialzation.. <ID:0/006> Set PIT file.. <ID:0/006> DO NOT TURN OFF TARGET!! <ID:0/006> Get PIT for mapping.. <ID:0/006> Firmware update start.. <ID:0/006> SingleDownload. <ID:0/006> spl.img <ID:0/006> NAND Write Start!! <ID:0/006> sboot.bin <ID:0/006> sboot2.bin <ID:0/006> param.lfs <ID:0/006> boot.img <ID:0/006> recovery.img <ID:0/006> system.img <ID:0/006> SPRDCP.img <ID:0/006> Transmission Complete.. <ID:0/006> Now Writing.. Please wait about 2 minutes <ID:0/006> Receive Response from boot-loader <ID:0/006> SPRDDSP.img <ID:0/006> Transmission Complete.. <ID:0/006> Now Writing.. Please wait about 2 minutes <ID:0/006> Receive Response from boot-loader <ID:0/006> nvitem.bin <ID:0/006> Transmission Complete.. <ID:0/006> Now Writing.. Please wait about 2 minutes <ID:0/006> Receive Response from boot-loader <ID:0/006> cache.img <ID:0/006> hidden.img <ID:0/006> RQT_CLOSE !! <ID:0/006> RES OK !! <ID:0/006> Removed!! <ID:0/006> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/032> Added!! [/IMG] | |
01-22-2016, 17:53 | #15 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: banglore\kerala
Member: 523496 Status: Offline Sonork: ammachis Thanks Meter: 76 | Quote:
