Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 12-05-2018, 23:56   #16 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,107
Originally Posted by osmanabu View Post
Hi wich part of the process do we flash stock firmware?
after that u can full flash this method long way ago in xda
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Old 12-06-2018, 10:05   #17 (permalink)
Member: 2217941
Thanks Meter: 3
please share eng root u3 file
Old 12-19-2018, 22:40   #18 (permalink)
Member: 15156
Thanks Meter: 31
Mayb I'm not doin something right after deleting files from efs folder restart phone imei returns to original imei hwcum?
Old 12-21-2018, 00:42   #19 (permalink)
Member: 1698993
some one can share eng root file?only found u2 thx
Old 12-23-2018, 19:59   #20 (permalink)
Member: 2406539
Thanks Meter: 24
Originally Posted by robert1978 View Post
hello when doing step 3 with root explorer and rebooting returns to the original imei. and does not raise me signal. someone to help me please, thank you
how to install es file explorer with combination file..?
i tried with sideload adb, but it says..
E: footer is wrong,
E: signature verification failed
Old 12-23-2018, 20:14   #21 (permalink)
Member: 2406539
Thanks Meter: 24
Originally Posted by zerishpho View Post
SM-G935F OREO 8.0 U3 IMEI PATCH CERTIFICATE Done by combination method
1st flash combination u3
2nd root using king root and repair imei using z3x
3rd install root explorer open efs delete all files except prov_data and factory app
4th reboot that's it
do i need to install root explorer after flashing stock rom or when phone has got combination file..?
Old 12-23-2018, 23:14   #22 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,304
You can use HiSuite for install Root Explorer, after flash combination go to setting enable USB debugging authorisations Option.
Before installing [RE] must be rooted by the KingoRoot.
http://www.youtube.com/watch?v=fVfOpvn-LDM&feature=*********
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Br,
Palash Ahammad
The Following 4 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 01-07-2019, 18:11   #23 (permalink)
Member: 2188821
Sonork: niko5610
this post has no use if it is not explained. please correct or delete the post. is not explained well, at the end of the procedure can you write stock firmware? or must stay in combination rom ?
Old 01-07-2019, 18:28   #24 (permalink)
Member: 975554
Thanks Meter: 18
basically NO..you need to write factory firmware again...how can you use the cellphone in binary firmware?
download binary 3 factory firmware and flash it again in the phone..my process was to flash only BL AP and CSC to be sure..and all is working
Old 01-09-2019, 12:30   #25 (permalink)
Member: 2188821
Sonork: niko5610
combi + imei + root. but when I delete the files from the efs folder, it returns to my original ..
Old 01-09-2019, 13:08   #26 (permalink)
Member: 2188821
Sonork: niko5610
combi + kingo root + repair imei + patch imei = imei status ok - write bl + ap + csc = imei status NG
if I delete the files from the efs folder it returns to the original imei..
Old 01-10-2019, 00:44   #27 (permalink)
Member: 975554
Thanks Meter: 18
if your imei was blacklisted you need to write certificate with imei on it and then patch it..my phone was only having null imei i dont know if it will work on your device i havnt test to write certificate
Old 01-10-2019, 14:50   #28 (permalink)
Member: 2188821
Sonork: niko5610
ok this procedure is only to restore original imei
Old 01-12-2019, 12:28   #29 (permalink)
Member: 2695370
cf auto root 7.0 2 time install first time root your device crash reset and again root device is root done..
Old 01-14-2019, 09:10   #30 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 107
Question confused
done all steps, and all good in combi and got operator Signal OK, but after write bl + ap + csc = imei status NG. and still Emergency Calls Only...
my imei is not blacklisted.
what am i missing ?
after flash full stock, need to root again and delete those files in EFS ?
thanks
Page generated in 0.16508 seconds with 7 queries
