Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 01-14-2019, 09:16   #31 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 112
Exclamation
Originally Posted by ...:::::NP™:::::... View Post
You can use HiSuite for install Root Explorer, after flash combination go to setting enable USB debugging authorisations Option.
Before installing [RE] must be rooted by the KingoRoot.
http://www.youtube.com/watch?v=fVfOpvn-LDM&feature=*********
this method is obsolete, as Hisuite will (compulsory) self update to 9.0 and Applications TAB is removed from 9.0.
better update info or test before post.
thanks
Old 01-14-2019, 10:15   #32 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,377
If you have any smooth & already tested method you can post here.
I have already tested to install the root explorer.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Br,
Palash Ahammad
Old 01-14-2019, 10:27   #33 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 112
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\kde>cd..
C:\Users>cd..
C:\>cd..
C:\>cd androidadbn
C:\AndroidADBn>adb devices
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
ce10160acb59093804 device
C:\AndroidADBn>adb install Rootexplorer_2.2.3.apk
2789 KB/s (4341516 bytes in 1.520s)
pkg: /data/local/tmp/Rootexplorer_2.2.3.apk
Success
C:\AndroidADBn>
Old 01-14-2019, 12:05   #34 (permalink)
Member: 478535
Thanks Meter: 333
C:\Users\kde>cd..
C:\Users>cd..
C:\>cd..
C:\>cd androidadbn
Success
C:\AndroidADBn>
He used the rootexplorer from your post, just show how to install Rootexplorer_2.2.3.apk via adb, without using hisuite as hisuite will autoupdate and loose the application manager that allowed to install Rootexplorer_2.2.3.apk.
The rest is just following the process:
3rd install root explorer open efs delete all files except prov_data and factory app
Old 01-16-2019, 16:38   #35 (permalink)
Member: 2188821
Sonork: niko5610
this procedure only serves to restore original imei. it does not apply to a different one
Old 01-23-2019, 07:42   #36 (permalink)
mob-tech's Avatar
Member: 600282
Sonork: 100.1614516
Thanks Meter: 65
Originally Posted by zerishpho View Post
SM-G935F OREO 8.0 U3 IMEI PATCH CERTIFICATE Done by combination method
1st flash combination u3
2nd root using king root and repair imei using z3x
4th reboot that's it
tested by me 100% worked !!
The Following User Says Thank You to mob-tech For This Useful Post:
Old 01-24-2019, 19:46   #37 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 58
I tried it several times and the only thing I achieve is to recover the original imei, and I'm interested in repairing and pacth
Old 01-29-2019, 00:13   #38 (permalink)
Member: 2769072
Thanks Meter: 74
i have problem when ive flash combination after reboot stuck on start up logo even reset phone in recovery mode but same
Old 02-01-2019, 13:24   #39 (permalink)
Member: 2188821
Sonork: niko5610
this procedure is only valid to restore the original imei without damaging knox
Old 02-11-2019, 21:17   #40 (permalink)
Member: 1539068
Thanks Meter: 30
100% fake solution, already tried all steps, didn't work, waste of time..
Old 02-13-2019, 16:07   #41 (permalink)
Member: 1744601
Thanks Meter: 29
lack of understanding is your problem. the solution worked for many why is that? maybe you are one click person
Old 02-13-2019, 16:11   #42 (permalink)
Member: 1744601
Thanks Meter: 29
Originally Posted by TMAC1122 View Post
how to install es file explorer with combination file..?
i tried with sideload adb, but it says..
E: footer is wrong,
E: signature verification failed
use apk installer program its a small to dwonlaod ApkInstaller.exe 2.8mb google it
Page generated in 0.32347 seconds with 7 queries
