Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-11-2017, 13:53 | #1 (permalink) |
No Life Poster Join Date: Feb 2014 Location: gsm
Member: 2131081 Status: Offline Sonork: 76543322223 Thanks Meter: 92 | SM-G950U big problem, help please is there anyone to instruct how to solve it? BR Last edited by ...:::::NP™:::::...; 11-12-2017 at 05:04. Reason: Image has been resized |
11-12-2017, 22:41 | #2 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2592628 Status: Offline Thanks Meter: 212 | combination? Why are you flashing combination file to remove FRP? Install stock firmware, use build QGL as it is the newest for sprint and use ODIN 3.12.5 (do NOT use hacked to install stock). once that finishes, you'll get back to welcome screen. then go back to download mode and flash the G950U_eng_boot file. this will bring you back to welcome screen with ADB access. Use box of choice to remove FRP lock. Once on home screen, go to settings factory reset phone. You will get hung up on same serial number screen. force to download mode flash stock boot file from QGL build you flashed in earlier steps. click reset on corrupt screen that will pop up after stock boot flashed. username @gmail for hangouts message me there if you need help |
The Following User Says Thank You to obliviousmnd For This Useful Post: |
