Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
12-09-2017, 05:12 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | SM-G955U Bricked! QD_Loader Problem is i cannot find such files online to download to this phone. I believe i need .XML file and firehose files.. Any help? Please and thank you forum members -BR- .:112:. |
The Following User Says Thank You to Stunman112 For This Useful Post: |
12-09-2017, 06:50 | #2 (permalink) | |
Freak Poster Join Date: May 2012 Location: Haiti, Port-Au-Prince, Carref.
Member: 1763284 Status: Offline Thanks Meter: 56 | Quote:
Sent from my SM-A510F using Tapatalk | |
The Following User Says Thank You to Castle2k For This Useful Post: |
12-09-2017, 07:26 | #3 (permalink) | |
Freak Poster Join Date: Jul 2016
Member: 2596108 Status: Offline Thanks Meter: 58 | Quote:
The Following User Says Thank You to wirelessinfinit For This Useful Post: |
12-09-2017, 07:51 | #5 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | If anyone can make a dump backup it would be much appreciated.. Until then or files become available, i know i have a brick. Thanks -BR- .:112:. Sent from my SM-G928T using Tapatalk |
12-13-2017, 14:22 | #8 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | So i found the prog_ufs_firehose ddr 8998 for Samsung G955U and i think all i need now is the .xml. Getting closer.. -BR- .:112:. |
12-15-2017, 02:54 | #12 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | Programmer Path:C:\Users\User1\Desktop\nhlos\common\tools\eme rgency_download\prog_ufs_firehose_8998_ddr.elf Image Search Path: C:\Users\User1\Desktop\nhlos\common\tools\emergenc y_download RAWPROGRAM file path: C:\Users\User1\Desktop\nhlos\common\tools\emergenc y_download\rawprogram0.xml PATCH file path:C:\Users\User1\Desktop\nhlos\common\tools\eme rgency_download\patch0.xml Start Download Program Path:C:\Users\User1\Desktop\nhlos\common\tools\eme rgency_download\prog_ufs_firehose_8998_ddr.elf ***** Working Folder:C:\Users\User1\AppData\Roaming\Qualcomm\QFI L\COMPORT_11 Binary build date: Oct 31 2016 @ 22:51:05 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files (x86)\Qualcomm\QPST\bin\QSaharaServer.ex'Current working dir: C:\Users\User1\AppData\Roaming\Qualcomm\QFIL\COMPO RT_11 Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: C:\Users\User1\Desktop\nhlos\common\tools\emergenc y_download\prog_ufs_firehose_8998_ddr.elf 11:44:18: Requested ID 13, file: "C:\Users\User1\Desktop\nhlos\common\tools\emergen cy_download\prog_ufs_firehose_8998_ddr.elf" 11:44:18: 599432 bytes transferred in 0.172000 seconds (3.3236MBps) 11:44:18: File transferred successfully 11:44:18: Sahara protocol completed Sending Programmer Finished Switch To FireHose Wait for 3 seconds... Max Payload Size to Target:49152 Bytes Device Type:UFS Platform:8x26 Disable Ack Raw Data Every N Packets Skip Write:False Always Validate:False Use Verbose:False ***** Working Folder:C:\Users\User1\AppData\Roaming\Qualcomm\QFI L\COMPORT_11 Base Version: 16.10.28.15.28 Binary build date: Oct 31 2016 @ 22:51:02 Incremental Build version: 16.10.31.22.51.02 11:44:22: INFO: FH_LOADER WAS CALLED EXACTLY LIKE THIS ************************************************ C:\Program Files (x86)\Qualcomm\QPST\bin\fh_loader.exe --port=\\.\COM11 --sendxml=rawprogram0.xml --search_path=C:\Users\User1\Desktop\nhlos\common\to ols\emergency_download --noprompt --showpercentagecomplete --zlpawarehost=1 --memoryname=ufs ************************************************ 11:44:22: INFO: Current working dir (cwd): C:\Users\User1\AppData\Roaming\Qualcomm\QFIL\COMPO RT_11\ 11:44:22: INFO: Showing network mappings to allow debugging 11:44:22: INFO: 11:44:22: INFO: Trying to store 'rawprogram0.xml' in string table 11:44:22: INFO: Looking for file 'rawprogram0.xml' 11:44:22: INFO: User wants to talk to port '\\.\COM11' 11:44:22: INFO: Took 0.00000000 seconds to open port 11:44:22: INFO: Sorting TAGS to ensure order is <configure>,<erase>, others, <patch>,<power> 11:44:22: INFO: If you don't want this, use --dontsorttags 11:44:22: INFO: Looking for file 'gpt_main0.bin' 11:44:22: INFO: Looking for file 'gpt_backup0.bin' 11:44:22: INFO: Total to be tansferd with <program> or <read> is 44.00 KB 11:44:22: INFO: Sending <configure> 11:44:22: INFO: TARGET SAID: 'Binary build date: Jun 1 2017 @ 14:29:30' 11:44:22: INFO: TARGET SAID: 'Chip serial num: 4294967295 (0xffffffff)' 11:44:22: INFO: TARGET SAID: 'Supported Functions: program configure nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase peek poke ' 11:44:22: INFO: TARGET SAID: 'Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'' 11:44:22: INFO: fh.attrs.MaxPayloadSizeToTargetInBytes = 1048576 11:44:22: INFO: fh.attrs.MaxPayloadSizeToTargetInBytesSupported = 1048576 11:44:22: INFO: In handleProgram('gpt_main0.bin') 11:44:22: INFO: Looking for file 'gpt_main0.bin' 11:44:22: INFO: ================================================== ===== 11:44:22: INFO: {<program> FILE: 'C:\Users\User1\Desktop\nhlos\common\tools\emergen cy_download\gpt_main0.bin'} 11:44:22: INFO: {<program> (24.00 KB) 6 sectors needed at location 0 on LUN 0} 11:44:22: INFO: ================================================== ===== 11:44:22: INFO: TARGET SAID: 'ERROR: Failed to initialize (open whole lun) UFS Device slot 0 partition 0' 11:44:22: INFO: TARGET SAID: 'ERROR: ufs_open_error_code 0 :: 0x27c' 11:44:22: INFO: TARGET SAID: 'ERROR: last ufs_open_error_code 16 :: 0x27c' 11:44:22: INFO: TARGET SAID: 'ERROR: Failed to open the device 3 slot 0 partition 0' 11:44:22: INFO: TARGET SAID: 'INFO: Device type 3, slot 0, partition 0, error 0' 11:44:22: INFO: TARGET SAID: 'WARN: Get Info failed to open 3 slot 0, partition 0, error 0' 11:44:22: INFO: TARGET SAID: 'storage_device_get_num_partition_sectors FAILED!' 11:44:22: INFO: TARGET SAID: 'parseSectorValue could not handle start_sector value' _____ | ___| | |__ _ __ _ __ ___ _ __ | __| '__| '__/ _ \| '__| | |__| | | | | (_) | | \____/_| |_| \___/|_| 11:44:22: {ERROR: program FAILED - Please see log} Writing log to 'C:\Users\User1\AppData\Roaming\Qualcomm\QFIL\COMP ORT_11\port_trace.txt', might take a minute Log is 'C:\Users\User1\AppData\Roaming\Qualcomm\QFIL\COMP ORT_11\port_trace.txt' Download Fail:FireHose Fail:FHLoader Fail:Process fail Finish Download -BR- .:112:. |
12-15-2017, 03:55 | #15 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Online Thanks Meter: 174 | Quote:
The Following User Says Thank You to gayansuranga For This Useful Post: |
