Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-11-2019, 19:36 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | TWRP for Samsung Galaxy J7 (2016 Exynos): This is for the Exynos SM-J710F, SM-J710FN, SM-J710GN, SM-J710MN, SM-J710K models only! TWRP: https://dl.twrp.me/j7xelte/ SuperSU 2.82 SR5: SR5-SuperSU-v2.82-SR5-20171001224502.zip Magisk 19.1 Latest Stable: Magisk-v19.1.zip |
The Following 7 Users Say Thank You to voltran2008 For This Useful Post: |
11-01-2019, 14:17 | #3 (permalink) |
Freak Poster Join Date: Nov 2011 Location: India Age: 34
Member: 1682257 Status: Offline Thanks Meter: 60 | i tried all the methods in j710f but fail to root i want to repair network through octopus or z3x but unable to root while using super su it is installed successfully but show error "su binary occupied " while using magisk than unable to flash magisk zip android version 8.1.0 ,u6 binary be fast reply please Last edited by jitubhati20; 11-01-2019 at 14:23. |
11-04-2019, 06:23 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: BANGLADESH Age: 43
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | 100% tested root file j710f 8.1 u6 tested j710f u6 root file here 1st: flash with Recovery file 2nd:Wipe format data 3rd:flash no-verity-opt-encrypt-6.0_2.zip https://androidfilehost.com/?fid=6006931924117942220 |
The Following 2 Users Say Thank You to helpful-man For This Useful Post: |
11-07-2019, 13:22 | #5 (permalink) |
Major Poster Join Date: May 2002 Location: MX-KEY is the BEST NOKIA TOOL Age: 59
Member: 12007 Status: Offline Thanks Meter: 1 | tested j710f u6 root file here 1st: flash with Recovery file 2nd:Wipe format data 3rd:flash no-verity-opt-encrypt-6.0_2.zip https://androidfilehost.com/?fid=6006931924117942220 ================== wire Pass u not good frind |
12-29-2020, 14:59 | #9 (permalink) | |
Freak Poster Join Date: Apr 2014
Member: 2177146 Status: Offline Thanks Meter: 20 | Quote:
03-29-2021, 13:21 | #13 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch CERT Selected model: SM-J710F Software version: 42.6 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 8.1.0 PDA version: J710FXXU6CSG2 CSC version: J710FOJV6CSG1 Phone version: J710FXXU6CSG3 Product code: SM-J710FZDDTHR CSC country code: IRAN CSC sales code: THR Phone SN: RF8HC1RCTHL IMEI: HW version: MP 0.400 RF cal date: 20161216 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-07-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 1) Done with Samsung Tool PRO v.42.6 |
The Following User Says Thank You to mahi20015 For This Useful Post: |
03-29-2021, 13:22 | #14 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | patch error REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch CERT Selected model: SM-J710F Software version: 42.6 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 8.1.0 PDA version: J710FXXU6CSG2 CSC version: J710FOJV6CSG1 Phone version: J710FXXU6CSG3 Product code: SM-J710FZDDTHR CSC country code: IRAN CSC sales code: THR Phone SN: RF8HC1RCTHL IMEI: HW version: MP 0.400 RF cal date: 20161216 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-07-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 1) Done with Samsung Tool PRO v.42.6 |
