Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 09-19-2019, 19:35   #1 (permalink)
Member: 2749393
Thanks Meter: 39
J727P U5 keep reboot
Hello,
I need to fix bootloop for j727p u5,
please help
Old 09-19-2019, 19:49   #2 (permalink)
Member: 2613252
Thanks Meter: 1,837
Originally Posted by D. Dragon View Post
Hello,
please help
hello, to be in bootloop did you do some firmware flash or other operations to make the phone go bootloop?
in what state is the phone staying on the samsung logo?
the phone enters download mode and recovery mode and the display shows some written error message whether you put it in download mode or in recovery mode?
You could post a picture of the phone in what state it is
Or have you tried to do a factory reset or a wipe partion chache in recovery mode to see if the phone restarts from the bootloop?
Have you already tried to flash the binary 5 firmware in 4 files for j727p or did you try to flash the firmware in 5 files including a pit file to retrieve the phone?
Old 09-19-2019, 20:00   #3 (permalink)
Member: 2749393
Thanks Meter: 39
it worked but for second then reboot, I had it before on U4 and flash carrier file then fixed but I can't on U5. It's general problem
Old 09-19-2019, 20:07   #4 (permalink)
Member: 2613252
Thanks Meter: 1,837
I did not understand what worked for the second reboot, if I understood correctly you tried to flash the firmware with binary 4 and you failed to restart the phone because you can not with the binary 5, I do not follow you on what you have written.
you have to see if the phone when you put it in recovery or download mode first of all if you enter it and then read on the display if written errors appear and from there you understand the problem.
Or try flashing in 5 firmware files with the pit if the phone restarts if you have already tried the 4 firmware files and you have not solved
Old 09-19-2019, 20:11   #5 (permalink)
Member: 2749393
Thanks Meter: 39
Thank you, you can see this video https://www.youtube.com/watch?v=jiJPn5XEIHg but there is file to fix the problem without combination
Old 09-19-2019, 20:26   #6 (permalink)
Member: 2613252
Thanks Meter: 1,837
if you want to do the unlocking without installing the combination, just install the combination modem, extract the modem from the combination with 7zip and rename it in tar format and install it with odim then unlock the network, with the network unlocked reinstall the modem firmware stock is this the problem you have on your phone?
Old 09-19-2019, 20:37   #7 (permalink)
Member: 2749393
Thanks Meter: 39
Almost, I think the problem will solved after zero modem and efs but I can't find file for U5, also I need eng modem for U5, please help me if you have it
Old 09-19-2019, 20:46   #8 (permalink)
Member: 2613252
Thanks Meter: 1,837
if you are looking for the combination u5 for j727p it does not exist has never been released at the moment
then if to restart the phone delete the efs and the imei not having a backup of the two you are screwed, then for the model j727p there is no patch
Old 09-19-2019, 20:52   #9 (permalink)
Member: 2749393
Thanks Meter: 39
Yes I can't find u5 combination or modem. I need help
Old 09-19-2019, 20:57   #10 (permalink)
Member: 2613252
Thanks Meter: 1,837
unfortunately the combination and the modem of the combination u5 for j727p does not exist has never been released at the moment there is only binary 4
Old 09-19-2019, 21:04   #11 (permalink)
Member: 2749393
Thanks Meter: 39
OK,,, but can anyone upload me U5 stock modem please..
Old 09-19-2019, 21:26   #12 (permalink)
Member: 2613252
Thanks Meter: 1,837
you have to extract the modem from the firmware then it depends on what type of firmware you have installed on the phone if you want I can give you the u5 firmware for j727p in 4 file
J727PVPS5BSA3_J727PSPT5BSA3_SPR_8.1.0_Full.rar
Download:
https://androidfilehost.com/?fid=1395089523397961080
Old 09-20-2019, 14:23   #13 (permalink)
Member: 2749393
Thanks Meter: 39
Download:
Thank you but I need only modem file, please upload it if you have,,,
Page generated in 0.24563 seconds with 9 queries
