Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-20-2018, 22:32   #1 (permalink)
momobreak's Avatar
Member: 1518824
Thanks Meter: 378
SM-J710F Binary 5 FRP Solution [World First]
j710F U5 FRP Remove android 7 By one Click
i tested much thing
1/bypass by calculatrice no work
2/ Unlock By eng boot no work
3/ downgard android 7 to 6 no work bcz B5
4/with combination no work
...... all method not working
the only method work and verry easy by one click its:
1/ make Phone in download Model
2/Chose J200G in z3x and click Reset Frp/rect/EE
and enjoy
You dont belive just try and let me know
dnt forget thanks butun
The Following 13 Users Say Thank You to momobreak For This Useful Post:
Old 07-09-2018, 17:03   #2 (permalink)
momobreak's Avatar
Member: 1518824
Thanks Meter: 378
After unlock do reset from setting
The Following User Says Thank You to momobreak For This Useful Post:
Old 07-11-2018, 12:22   #3 (permalink)
Member: 2823049
Thanks Meter: 9
your solution not work , but i do other away
Old 07-13-2018, 12:54   #4 (permalink)
Member: 600422
Thanks Meter: 6
can you share solution?
Old 07-21-2018, 06:48   #5 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 1,230
Final Solution for J710F Binary 5 FRP:
First Flash COMBINATION:
COMBINATION_OXA_FA60_J710FXXU5BRC1_OXAFAC.rar
file credits to PiratesGSMKing
Enable USB Debugging and put into download mode and flash this file:
(Do not ask for other region firmware, only Israel firmwares is live on Samsung Servers)
J710FXXU5BRC2 - 7.0 - ILO (Israel) - Single File.zip
Reset FRP with Box or If you do not have box use this tool:
Gsm Flasher FRP Reactivation Lock Remover Pro
The Following 13 Users Say Thank You to voltran2008 For This Useful Post:
Old 07-28-2018, 16:26   #6 (permalink)
Member: 2704612
Bad
i tested much thing
and enjoy
Phone it's dead now, i did what u say men, wrong
Old 08-02-2018, 13:14   #7 (permalink)
Member: 18823
Thanks Meter: 18
I tested and work ok , frp remove with z3x box
The Following 5 Users Say Thank You to destinul For This Useful Post:
Old 09-03-2018, 17:08   #8 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 50
I wonder how it worked for some people who leaved Thanks
It says Custom binary blocked by FRP, so it is 0% working procedure
Otherwise the tested method by me 10000% is this:
new method build 5 versions
flash combination build 5
COMBINATION_OXA_FA60_J710FXXU5BRC1_OXAFAC_CL7564864_QB17459718_REV03_user_mid_noship.tar
after this flash
but select to flash only sboot, boot, recovery, system, cache files in Z3X,
after this phone is detected as adb device which can be ****ed the way you want it, but you can also enter on the menu and Perform a Hard reset from there
i tested much thing
and enjoy
Old 12-18-2018, 12:44   #9 (permalink)
Member: 454134
Thanks Meter: 3
after this flash
Not working for 7.0
binary blocked by frp
Old 07-08-2019, 14:39   #10 (permalink)
Member: 2243791
so no solution j710f u5 frp wthout combnation?
Old 09-11-2019, 07:53   #11 (permalink)
rubelgsm's Avatar
Member: 1714226
Sonork: 100.1683394
Thanks Meter: 118
Im a tested & work ok with z3x box
Old 09-11-2019, 11:14   #12 (permalink)
Member: 1862574
Thanks Meter: 54
MY SOLUTION WITH J710F U5 FRP IS THIS SOLUTION AND IT ALWAYS WORKS VERY WELL :flash this combination
2..enable usb debugging
3..flash this stock rom without recovery and cache(it will keep enabling ur usb debougging)
4..reset it with any tool via adb
thats it.............................................
J710FXXU5BRC2_J710FOJK :stock rom ,and this combination:COMBINATION_OXA_FA60_J710FXXU5BRC1
Old 09-28-2019, 14:10   #13 (permalink)
Member: 2814900
Thanks Meter: 11
after cobination flash set need password
Old 10-25-2019, 09:54   #14 (permalink)
Member: 1159475
Sonork: multan
Thanks Meter: 57
SM-J710F U4 FRP Bypass
https://www.youtube.com/watch?v=BAPrznOMYZo&t=15s
Page generated in 0.40251 seconds with 7 queries
