Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-15-2017, 00:09 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | SM-N920P no boot no recovery mode Ps, the device when i first got it was stuck on the "Custom binary blocked by frp lock" screen. It is gone now since i successfully removed it. .:112:. Sent from SM-N920P using Tapatalk |
The Following User Says Thank You to Stunman112 For This Useful Post: |
04-15-2017, 18:37 | #2 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | I get this when i flash the combo file .:112:. Sent from SM-N920P using Tapatalk Last edited by ...:::::NP™:::::...; 04-16-2017 at 21:11. Reason: Image resize |
04-17-2017, 00:43 | #4 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | Flashed the firmware with no errors and i am still getting the stuck at Samsung Note 5 boot logo. It has been there for over 10 minutes and recovery key combo doesnt work for recovery mode. I think it is worth noting that the phone when plugged into ac power goes directly to the Samsung logo, it does not show the battery charging screen. .:112:. Sent from SM-N920P using Tapatalk |
04-17-2017, 18:06 | #5 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | I guess i will try SmartSwitch emergency. I even tried flashing the 4 file 7.0 firmware with same results. Will post back results of emergency recovery.. .:112:. Sent from SM-N920P using Tapatalk |
04-17-2017, 18:28 | #6 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Hi Flash with this firmware uploading credit (Jessooca) After write this G920P-R4-NOUGAT-TWRP-by-LAMLAZY.tar credit (Lamlazy) Next step post here.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
04-17-2017, 21:39 | #7 (permalink) | |
Member: 2567774 Status: Offline Thanks Meter: 255 | Quote:
Re-Flash the latest 6.0.1 and then flash TWRP for 7.0? I want to make sure i understand that correctly. | |
04-17-2017, 21:43 | #8 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Hi Just TWRP for recovery mode working or not, that's all.
04-17-2017, 22:11 | #9 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | No luck. Remains on Samsung logo.. Could this be happening due to a low battery? I am lost for the solution, i have changed the board over to my screen frame with battery and it didnt seem to help either. |
04-22-2017, 06:19 | #10 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | If the issue is a hardware problem how will i know? I dont get any EMMC errors or anything. Still cant believe flashing multiple firmware releases from rev 2 to 3 none have allowed the phone to boot. |
04-22-2017, 06:26 | #11 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | Try Vol + Vol - and power button with usb plugged in to force power. A Sprint Note 5 did this to me and im still seeking a solution. Except i get stuck at Samsung. NO recovery mode at all even with factory binary or any full set. |
04-27-2017, 06:08 | #12 (permalink) |
Member: 2567774 Status: Offline Thanks Meter: 255 | Update on the status is the same. The Note is sitting around collecting age.. i have read i may be able to solve my issue by booting from a SD Card with another Notes Bootloader files and getting past the Samsung logo. Anyone have any suggestions on this method? .:112:. Sent from SM-N920P using Tapatalk |
12-20-2017, 12:17 | #13 (permalink) | |
Registered User Join Date: Jun 2005 Location: jamnagar gujarat india
Member: 149938 Status: Offline Thanks Meter: 47 | Quote:
br. | |
