Solution Fix Touch Not Work Galaxy J7 Pro SM-J730G,SM-J730GM Done By Aaryan Hack Solution Fix Touch Not Work Galaxy J7 Pro SM-J730G,SM-J730GM by Aaryan Firmware Use otg cable to connect mouse and unlock OEM (how to) Copy J730G_Fix_Touch.zip to SDcard or Memory Flash TWRP and boot in RECOVERY Install: J730G_Fix_Touch.zip Reboot system. Success :)) DOWNLOAD: Twrp J730G J730GM 1000% Working Aaryan Hack J730G_Fix_Touch.zip For This Solution if any issue leave ur commant Br, Aaryan Hack |
How to Oem Option enabled ??? Pleases oem option enabled system suggest ....tnxx for advance |
How to Fix j710F Touch solution Best Regards ZEB_AFRIDI |
Phone has 8 Oreo installed on it . Is your method going to work on Oreo 8 version |
any idea for oem option on oreo ? i use otg mouse go setting develop but there no oem to enable |
bro restart only after flash rom |
i need combination file for binary 5 kindly give me some link |
no oem option on may oreo j730g |
already try this method but not work |
Fake Methood , How to OF OEM |
i have the same problem j730gm touch screen after update how to fix |
already try this method but not work j730gm |
Worked Check rmm status |
Needed try Off FRP first have one in FRP ON for Enable or disable OEM |
u5 no oem unlock and not possible via adb maybe need to wait for offical update Fix |
