Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-24-2017, 08:50 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Age: 38
Member: 1836541 Status: Offline Thanks Meter: 92 | Solutiont unlock scv33 with out any box by tungkick COMBINATION_FA60_SC02HOMU1APD5_CL7806593_QB9363130 _REV02_user_mid_noship_MULTI_CERT.tar.rar - Go to recovery3e wipe factory data cache - Inplug simcard reboot system> Show enter code write 00000000 enter > reboot phone > work sign network. - Flash stock rom sc-02h phone unlock done .You can update ota 7.0 sc-02h. - Link rom full SCV33.SC02H.1BQC4.NOUGAT_GLOBAL_07042017.zip [Credit by tienquynh93] - If you want flash stock rom scv33 you need unpack rom stock then delete cache.img and repack tar all file > Flash rom phone will not lock. - If you want Permanently you need flash stock rom sc-02h. Last edited by ...:::::NP™:::::...; 08-11-2017 at 21:49. Reason: Firmware download link hasbeen update |
The Following 36 Users Say Thank You to tungkick For This Useful Post: |
02-24-2017, 11:26 | #3 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Greece
Member: 2130293 Status: Offline Sonork: 100.1637594 Thanks Meter: 68 | not working i flash with combination rom after that wipe factory reset than insert sim card and put 00000000 but giving error incorrect code any help me please many time i enter code my mode sc-02h docomo ???? |
02-26-2017, 01:35 | #8 (permalink) | |
Member: 1836541 Status: Offline Thanks Meter: 92 | Quote:
03-02-2017, 03:05 | #12 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1556436 Status: Offline Thanks Meter: 66 | It should work with combination file then flash back stock scv33 not sc-02h because sc-02h is docomo then scv33 is Au, but the solution we really need here from someone or any team is docomo sc-02h s7 edge unlock solution, only paid solution is made public. |
03-02-2017, 04:27 | #13 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2287102 Status: Offline Thanks Meter: 119 | maybe this solution is 100% tested by tungkick but many other member has complane and said not working but for me maybe this solution is tested but the problem is thet instruction not CLEAR thats why other member is said not work because if you have a scv33 and you want to unlock you need to flash with combination firmware after flash enter 00000000 and then after that why you need to flash that scv33 to sc-02h ?? and tungkick said the scv33 and the sc-02h in not same model ?? that is only my suggestion if why member said not work that solution |
03-03-2017, 04:02 | #15 (permalink) |
Member: 1836541 Status: Offline Thanks Meter: 92 | Sr english of my verry bad. - Ok first inplug sim flash combiantiont rom sc-02h> Go to recovery3e wipe data cache > reboot system enter code 00000000 then reboot phone > phone will show network when reboot done. Now unlock done scv33. OK. But if you want reback flash rom scv33 . - First you need delete cache.img in csc. And rebuild file tar CSC with out cahe > then flash BL AP CP CSC ( with out cache.img). Phone will unlock sim done. - If you want not lock again when update ota scv33. You need flash rom sc-02h stock full rom. Phone will work unlock sim done. - |
