Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-08-2015, 05:15 | #167 (permalink) | |||
Major Poster Join Date: Mar 2014
Member: 2158895 Status: Offline Thanks Meter: 24 | Quote:
Looking for solution to unlock Sprint S5 G900P on 5.0 G900PVPU2BOD3 | |||
07-18-2015, 18:16 | #174 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Yerevan
Member: 1172145 Status: Offline Thanks Meter: 204 | Samsung Galaxy S6 SM-G920P Unlock instruction Please make sure your S6 has oe2 build number . If not, your device Oc9 or OCF, just turn on WiFi, go to menu, Settings, scroll down to system updates, update. Once you got the O2 Download archive https://mega.co.nz/#!MQNXXAZL!wos0g-...Hr-RI2sTggUaWs Unzip supersu.7z Install Superuser.apk with supersu.7z Install pingpongroot_beta6.apk and run,the program will be offered once again to install SuperSU then click Install. Do not run the SuperSU . Start pingpongroot, click Get root. If you see "It is recommended to reboot your device NOW" the phone has rooted, you need to overroot. If no, then Download Data then click Get root. 1)insert Sim 2)install GTv3.1.5.apk 3)install GTUpdate2_v3.1.8.apk and run , SuperSU will ask the question, then Grant, then Update and reboot your smartphone after the program closes itself. 4)Run idone press *UICC SIM Unlock* 5)reboot your device go to Settings menu, Mobile networks, Network mode, select GSM/UMTS. Your phone should find the network and can call. Search network then put the auto. I poluchilos first once . Time spent 30 minutes searching and unlocks .Good luck to everyone |
The Following 4 Users Say Thank You to gagjan For This Useful Post: |
07-18-2015, 20:47 | #175 (permalink) |
Junior Member Join Date: Aug 2006 Location: union st andrew's grenada
Member: 333555 Status: Offline Thanks Meter: 2 | Hey i have a s5 from Sprint but its on 5.0 and i cant get it to downgrade. How can i unlock it with ssu?? Sent from my LG-D415 using Tapatalk |
The Following User Says Thank You to skets For This Useful Post: |
07-19-2015, 09:17 | #180 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | Sprint unlock galaxy s5 sport: https://www.youtube.com/watch?v=_6u2UvvfdBI Sent from my SM-G925T using Tapatalk |
The Following User Says Thank You to Isellcert For This Useful Post: |
