Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-02-2014, 14:54 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2215104 Status: Offline Thanks Meter: 0 | Stuck with Samsung G900A I have read that if I flash with 5 files ROMs may help, but am worry about bricking my S5. I am a NOOb and new to android so am just doing a lot of reading and trying to learn as much as I can. Thanks, for your Help. Peter |
07-02-2014, 15:20 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear customers! From what I'm reading and you say, the S5 phone is new and has been stuck on the logo. If the phone is still under warranty I, I recommend that you take it for service because as you say, you are new to android and technology would not be advisable to make a flash to your phone. |
07-02-2014, 15:26 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Other Option: - After installing bad or unsupported application into your Samsung mobile phone, Which causes your phone to be frozen. - Your Samsung mobile phone doesn't respond to any order after booting because of any software errors. - Forgotten pattern lock in Samsung Android mobile phones. - Forgotten user code. - Forgotten phone code. - Getting Rid of Force Close errors. - Fixing the Boot loop situation. - Before or after installing a new firmware update into your device. - Before selling the device, To Wipe all your saved personal data. Samsung Galaxy S5 Hard Reset Steps: - Turn your Galaxy S5 off. - Take its battery out. - Take out any existed SIM or memory card. - Wait for 10 seconds. - Put the battery back, But do not turn on your device. - Press and hold the Volume Up key + Home key, Then press the Power key. - Keep pressing the keys until Samsung Logo appears,Then release all keys. - Wait until you get the Factory reset / System Recovery menu on screen. - Use the Volume Down key to select Wipe Data / Factory Reset option. - Use the Power key to confirm the operation. - You need to use the Volume Down key again to select "Yes -- delete all user data" - Use the Power key to confirm. - After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key. - Now the phone will reboots, Wait for it to be fully on and then you can start using it. |
07-02-2014, 15:42 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Do you want to flash it? Follow this steps, buy I don recommend it Preparation Steps: 1- Check the current firmware of your mobile, You can check it from Setting > About Phone, Or you can use this easy code *#1234# 2- It is a good idea to write down your device current firmware version, It will be useful later, In case something goes wrong. 3- Charge your mobile's battery to be at least at 90% of charging level. 4- Updating your mobile's firmware will delete everything from your device internal memory, (SMS, Contacts, Notes...etc). 5- In case you have an external memory card inserted into your mobile, Then remove it. 6- Download the Samsung USB Driver, And install it, Then restart your computer. Download USB Drivers exe 7- Download Odin3 program (Original Android Flasher), Extract to your computer's desktop. Odin3 v3.09.3 - Download - 4shared 8- Download The suitable Firmware package for your Galaxy S5 Variant, Select the version you want to install it into your mobile. 9- Extract the firmware package to a known location on your computer. Odin3 Settings: 1- Double click on Odin3.exe to run it. 2- These settings must be checked: Auto Reboot, F.Reset Time. 3- If you have the PIT file of your Samsung model, Then check: Re-Partition Putting your mobile into Download Mode: Press and Hold Volume Down Key + Home Key then press Power key, And if you get the warning message release all keys and press Volume Up key to enter the Download Mode. Installing the new Firmware into your Samsung Galaxy S5 Device: 1- After you put your mobile into Download Mode, Use the USB cable to connect it to your computer. 2- You have to wait until Windows detects the device and installs any needed drivers. 3- Look at Odin3 program's window, If the program detects your connected device correctly, You should see its COM Port number (0:[COMxx]). 4- You are ready to install the new firmware files into your Samsung mobile, Click Start button to begin. 5- After you click the Start button, Odin3 program will start to install the selected firmware files into the connected device. 6- Odin3 program will restart your Samsung mobile automatically after installing the firmware. 7- Wait until your mobile is restarted. 8- Look again at Odin3 program's window, If your see PASS! word in green, Then the update was done successfully. 9- Disconnect your mobile. 10- When the mobile is fully on, Check the new installed firmware version. 11- Now you are ready to use the device, So reinsert the SIM and Memory cards, Restore your backup, And customize it. Samsung G900A Firmwares: Android 4.4.2 KitKat: Download G900AUCU1ANCE ATT1ANCE ATT USA Kit Kat zip - G900AUCU1ANCE / ATT1ANCE ATT USA |
07-02-2014, 16:14 | #5 (permalink) |
Member: 2215104 Status: Offline Thanks Meter: 0 | Thanks for your response! may be I didn't explain my problem. did a hard reset on my phone I have never set or had a Samsung account, ( I had to set one up per samsungs rep request to see if it would work ) now I have no access to my phone other than to set up wifi, accept the manufacture agreement, and set up my google account, after that it goes to the Samsung account where it asks for my email and password, and when I put it in it says, error, or log in fail. I have done the hard reset a couple times, I have clear the cache files but no luck it gives me the steps I mention, and then it asks me for the Samsung info, is like a stolen iPhone asking for the icloud email and password. what options do I have to complete remove or to make the device think there was no Samsung account ever? |
07-02-2014, 16:25 | #6 (permalink) |
Freak Poster Join Date: Jan 2008 Location: bhopal
Member: 676024 Status: Offline Thanks Meter: 38 | his is not my solution I only copied it and it worked on 4 devices. The person I copied it from gave credit to MOUNISKY our moderator. Activation after hard reset 1: connect to wifi then go back to the first screen tap accessibility tap talkback and make it on touch screen will start hanging because of the voice u will have to tap twice in my case i reboot the phone and once you go to accessibility a message will pop asking you to download languages click yes samsung appstore should come up click I agree click free install it will ask for samsung id update click yes and wait until counts 1/100 click install again and this time it will ask you to create new id or sign in sign in if you have an ID or create new. one i created new download started, I cancelled the download and went to first screen to disbale the accessiblity talk back go back to first screen and behold, your new id will show in the sign in screen just put password and your phone is activated. go to security and disable the reactivation lock. |
07-02-2014, 19:11 | #7 (permalink) | |
Member: 2215104 Status: Offline Thanks Meter: 0 | Quote:
Thanks, But after I reset the phone, the first and only screen I get is the wifi screen, I try to hit the back button, but nothing happen I haven't seen the option to DL any languages, or to turn voice control. Any other options? | |
09-18-2014, 23:11 | #10 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1387605 Status: Offline Thanks Meter: 13 | there is some solution posted on youtube recently. take a look. You can search by : reactivation lock edit here is the link http://www.youtube.com/watch?v=E41tLyi59II Last edited by ens1986; 09-18-2014 at 23:21. |
05-11-2016, 13:23 | #12 (permalink) |
Junior Member Join Date: Oct 2015 Location: amman.jordan
Member: 2470859 Status: Offline Sonork: zakaria Thanks Meter: 1 | i have the same problem any solution for frp lock i'v tried everything z3x and bst and octopluse and odin and rooting and otg nothing works help |
05-11-2016, 19:59 | #14 (permalink) | |
Member: 2470859 Status: Offline Sonork: zakaria Thanks Meter: 1 | Quote:
Sent from my SM-G800F using Tapatalk | |
05-11-2016, 20:27 | #15 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | In this condition u don't have to disable RL u may create a new samsung account to avoid the next hard reset Sent from my iPhone using Tapatalk |
