Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-20-2014, 12:49 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Tutorial to create samsung 4 file multi firmware on your own 100% Tutorial to create samsung 4 file multi firmware by yur own Note: This is the guide for jus converting files to odin flashable. If you need to wipe your device while flashing add pit file into CSC. To create proper repair firmware take backup of param.bin from working device nd create vit the same build firmware of working device. [Include param.bin into Bootloader] Download nd install cywinDownload here * create a new folder in c drive c/Newfolder Name the folder as MyWork or any * copy the single file firmware into created folder * Delete the.md5extension for example if yur file isi9300xxx xxx.tar.md5 ---> i9300xxx xxx.tar * Extract the firmware using winrar * Im trying on 4.4.2 i9500 single firmware I9500XXUFNC1_I9500ODDFNC1_I9500DDUFNA4_HOME Run cygwin Enter below given commnd cd /cygdrive/c/mywork (Tis cmmd is for show the file path) * Now yu hav to createBootloader,PDA,MODEM,CSC Extracted files: boot.img cache.img hidden.img modem.bin param.bin recovery.img sboot.bin system.img * NoW Bootloader files areboot.img,param.bin,sboot.bin * PDA --->boot.img,param.bin,sboot.bin,recovery.img,system.i mg * CSC --->cache.img, hidden.img * Modem ---->modem.bin Run below given cmmds to create Bootloader (command:tar -H ustar -c filename.img > filename.tar) tar -H ustar -c boot.img param.bin sboot.bin > BOOTLOADER_I9500XXUFNC1.tar For PDA tar -H ustar -c boot.img param.bin sboot.bin recovery.img system.img > PDA_I9500XXUFNC1.tar For CSC tar -H ustar -c cache.img hidden.img system.img > CSC_I9500DDUFNA4.tar For MODEM tar -H ustar -c modem.bin > MODEM_I9500ODDFNC1.tar NoW yu are done creating Odin flashable Tar files. If yu want to convert tar to MD5 Commands : md5sum -t filename.tar >> filename.tar mv filename.tar filename.tar.md5 Example: Run below given command after create .tar file example below For Bootloader md5sum -t BOOTLOADER_I9500XXUFNC1.tar >> BOOTLOADER_I9500XXUFNC1.tar mv BOOTLOADER_I9500XXUFNC1.tar BOOTLOADER_I9500XXUFNC1.tar.md5 For PDA md5sum -t PDA_I9500XXUFNC1.tar >> PDA_I9500XXUFNC1.tar mv PDA_I9500XXUFNC1.tar PDA_I9500XXUFNC1.tar.md5 For CSC md5sum -t CSC_I9500DDUFNA4.tar >> CSC_I9500DDUFNA4.tar mv CSC_I9500DDUFNA4.tar CSC_I9500DDUFNA4.tar.md5 For MODEM md5sum -t MODEM_I9500ODDFNC1.tar >> MODEM_I9500ODDFNC1.tar mv MODEM_I9500ODDFNC1.tar MODEM_I9500ODDFNC1.tar.md5 Last edited by jamesjerss; 03-25-2016 at 11:48. |
The Following 99 Users Say Thank You to jamesjerss For This Useful Post: |
09-20-2014, 16:46 | #2 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | I9500 flashing result vit created other firmware |
The Following 13 Users Say Thank You to jamesjerss For This Useful Post: |
09-20-2014, 20:31 | #4 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
or request here i vil post | |
The Following 4 Users Say Thank You to jamesjerss For This Useful Post: |
09-22-2014, 16:05 | #6 (permalink) | |
Yes try vit other files if need repair file use this Bootloader Recovery al included n PDA CODE_I8190XXAMA2_809600_REV00_user_low_ship.rar (481.2 MB) CSC English CSC_OXE_I8190OXEAMA1_800680_REV00_user_low_ship.ra r (106.9 MB) jus flash tis two file firmware no need 4 file | |
09-23-2014, 07:33 | #7 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Dadu Sindh Pakistan Age: 37
Member: 1322713 Status: Offline Sonork: 100.1663786 Thanks Meter: 254 | Dear how can i Install This Softwre Plz Help me I have install this Software in C drive and Creat a Folder My Work In C drive. When i Run this softwre an Type this cd/cygdrive/c/mywork show error no such file directory plz guide me.......... |
09-23-2014, 11:32 | #8 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | make sure yu enter the correct folder name.. mywork no space between my nd work |
The Following User Says Thank You to jamesjerss For This Useful Post: |
09-23-2014, 13:31 | #9 (permalink) |
Freak Poster Join Date: May 2006 Location: Pak
Member: 283247 Status: Offline Thanks Meter: 71 | brother help i have not one before flash mobile only show download mode i flash with downloader with using pit file and complete files but after flash mobile goes dead so how flash without Jtag please help i have no Jtag box |
09-23-2014, 15:03 | #10 (permalink) | |
if mobile completely dead yu need jtag no other ways . but sme models yu can repair vit out jtag. post yur model nubr | |
09-24-2014, 16:22 | #13 (permalink) |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | MR jamesjerss what command should i use ? I9505 fie name I9505XXUFNBA_I9505OJVFNB2_I9505XXUFNBA_HOME.tar.md 5 |
The Following User Says Thank You to riajul1988 For This Useful Post: |
09-24-2014, 17:20 | #14 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | boot---->aboot.mbn tz.mbn sbl1.mbn sbl2.mbn sbl3.mbn Pda---->boot.img recovery.img system.img.ext4 persdata.img.ext4 modem--->modem.bin NON-HLOS.bin csc---->cache.img.ext4 hidden.img.ext4 Your commnd boot: tar -H ustar -c aboot.mbn tz.mbn sbl1.mbn sbl2.mbn sbl3.mbn > BL_I9505XXUFNBA.tar pda: tar -H ustar -c boot.img recovery.img system.img.ext4 persdata.img.ext4 > AP_I9505XXUFNBA.tar csc: tar -H ustar -c cache.img.ext4 hidden.img.ext4 > CSC_I9505OJVFNB2.tar modem: tar -H ustar -c modem.bin NON-HLOS.bin > MODEM_I9505XXUFNBA.tar Note: if yu want to add pit into CSC Downoad pit JFLTE_EUR_OPEN.pit csc: tar -H ustar -c cache.img.ext4 hidden.img.ext4 JFLTE_EUR_OPEN.pit > CSC_I9505OJVFNB2.tar If yu want 4file firmware 4.4.2 Download here Last edited by jamesjerss; 09-24-2014 at 17:28. |
