Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-31-2012, 09:23 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | [Tutorial]Galaxy S3 Backup And Restore Imei Without Root. INSTRUCTIONS: 1) Download NV reader/writer HERE and install THESE drivers. 2) Dial *#7284# and select "Qualcomm USB Settings" then check "RMNET + DM + MODEM". *If you are running a aosp rom (cm9,cm10,aokp etc) you can use the diag method described HERE 3) Save item 00550 with NV reader/writer. You can write the backup directly back to the phone. This backs up your IMEI only. *If you want a FULL NV backup read the phone with the default values [Range (Dec): 00000-65535]. 4) Dial *#7284# and select "Qualcomm USB Settings" then check "MTP + ADB". Demonstration video HERE IMEI ALREADY CORRUPT? 1) make a backup of item 00550 like described above and open with your favorite text editor. 2) Separate your IMEI (find it behind the battery) into blocks of two but with the first digit alone, like this- 353022050234285 = 3 53 02 20 50 23 42 85 3) Now add an "A" after the first digit then reverse the two numbers in all the other blocks, then add a 08 to the beginning. Like this- 3 53 02 20 50 23 42 85 = 08 3A 35 20 02 05 32 24 58 4) Now replace the first nine values in the NV block with your converted IMEI and save the text document. 5) Write the NV back to the phone and then reboot. Thanks: <:GeeK:> cdma-ware Peoplearmy GerardAnthony BR Rahul_Bhutani |
The Following 32 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
07-31-2012, 10:01 | #7 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Bro imei damaged phone base band also damaged without box base band cant repairable(some model cant work with any tools) asansam dongle correctly fixed only few models i9000 etc....... they have green methode with base band reapir nothing to work then why rebuild imei via this technics? Im sure after rebuild imei phone cant take the network imei null cause fix any way in this software? This is very good for users now jtag only fix this |
07-31-2012, 10:06 | #8 (permalink) | |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Quote:
dial *#1234# if phone version unknown then you have to change rf ic,if phone version ok,then you can repair it vie software,some devices are available in market which can fix it without jtag. | |
The Following 2 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
08-01-2012, 02:26 | #14 (permalink) | |
Freak Poster Join Date: Mar 2007
Member: 460280 Status: Offline Thanks Meter: 73 | Quote:
Can you please upload a sample of NV item (IMEI backup)? If not possible here, please upload it via PM. Again, BIG THANKS. | |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
