Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-07-2015, 08:55   #31 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
@debeliamark
First mount system and data from mount menu in recovery.
The Following User Says Thank You to Rahul_Bhutani For This Useful Post:
Old 10-08-2015, 17:28   #32 (permalink)
Member: 2419324
Sonork: 100.1667713
Thanks Meter: 39
Samsung S2 Gt-i900
where do i find Odin flashable custom recovery...
any links or sites?
Old 10-11-2015, 16:46   #33 (permalink)
Member: 227338
Thanks Meter: 25
I have SM-G530H I installed recovery PhilZ Touch 6 and when I connect to PC . and adb devices = Offline
how to slove it ?
Old 10-28-2015, 06:01   #34 (permalink)
Member: 2220289
Thanks Meter: 3
BY OCTOPUS no adb no root reset screen done
Old 10-29-2015, 12:24   #35 (permalink)
Member: 2475126
Does it work in a samsung galaxy s6 blocked with fingerprint
model sm-g925i ???
Old 10-29-2015, 12:49   #36 (permalink)
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Yes will work on s6 if FRP not on and if on you can even off using tricks posted on forum.
Old 10-29-2015, 13:16   #37 (permalink)
Member: 2475126
FRP is finger print?
let me explain it better
My problem was the finger print is not working, i forgot the backup password, the device is not connected to internet and the usb debug is not enabled, so this tutorial can save me?
Old 10-29-2015, 23:20   #38 (permalink)
Member: 2450347
Some different kinds of Locks
he's saying it will work unless factory reset protection has been enabled (a simple forum search for FRP would have revealed that). Sometimes I find google search of gsmhosting yields better results.
here's a related post (I can't post links yet):
search "how-remove-screen-lock-s6-edge-new-version-g925fxxu2coh8-1998005-post11327212"
I'm in the same situation but more out of curiosity than necessity on my tmoibile s6 edge with android 5.1.1 (of6 firmware).
Fingerprint screen lock enabled & also backup password but I want to remove fingerprint password and login to the S6 Edge without factory reset (I want to keep settings / data), I also don't want to trip Samsung's KNOX (**** bootloader control to void your hardware warranty). Lastly, I would like to flash custom recovery with Odin (not sure if I can do this without having root but I would rather keep the device stock and simply remove the fingerprint / password screen lock.
So bottom line, you are confusing Samsung's Account Lock (FRP to avoid theft) with finger print lock.
If Reactivation Lock is enabled you can't use Odin to flash custom recovery (to my VERY limited knowledge, unless maybe doing battery pull and risking softbrick?)
So in short, search that other post I referenced and make sure the Samsung Reactivation lock on your phone is not enabled so you can flash and gain root if necessary (to delete system files through adb to remove fingerprint / password lock).
It takes a bit of patience searching to get used to basic concepts; it's just time consuming but nothing too difficult with basic reading and comprehension skills.
There are different kinds of locks:
Samsung Account Lock (Reactivation Lock):
You can check to see if this has been enabled by booting into recovery menu on phone by powering on while holding power + up volume + home buttons at the same time.
Than there is Google Account Lock (search forums for OTG settings bypass).
Then there is a Screen lock (fingerprint & backup password).
Goodluck, we're both in the same boat!
Old 11-02-2015, 14:15   #39 (permalink)
Fatalfury's Avatar
Member: 810122
Thanks Meter: 65
just flash this in custom recovery
Dr.Ketan_LockScreen_Security_bypassV1.1
Old 11-02-2015, 16:24   #40 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
if there is any way for sony or htc to remove with out ADB will be good ,coz any way to unlock bootloader for this devices will wipe data
DevX
Old 11-05-2015, 19:09   #41 (permalink)
.:==di@bila==:.'s Avatar
Member: 254137
Sonork: 1592525
Thanks Meter: 275
doesnt work on sm n7505
br
Old 11-09-2015, 10:15   #42 (permalink)
Member: 2386502
Thanks Meter: 6
how to restore samsung galaxy s
Old 12-07-2015, 09:09   #43 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
note 5 sm-n920c fingerprint & password lock it will work this method ?
Old 12-07-2015, 09:22   #44 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
custom binary(recovery)blocked by frp lock
now no way
Old 12-12-2015, 21:03   #45 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
m919 done ok
mount system
mount data
adb devices
adb shell
cd data/system
rm /data/system/locksettings.db
rm /data/system/locksettings.db-wal
rm /data/system/locksettings.db-shm
The Following User Says Thank You to bhiret For This Useful Post:
Page generated in 0.25640 seconds with 9 queries
