Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-01-2017, 23:31 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | [TWRP][Root] Samsung Galaxy S7/S7 Edge Android 7.0 Nougat Extract & downloaded All Necessary file to your desktop twrp-3.0.2-4-herolte.img.tar file to the extracted folder. Now turn off your Galaxy S7 and press and hold the Volume Down + Home + Power keys at the same time for 2-3 seconds to boot your phone into the Download mode. Release the keys as soon as you see a blue screen with exclamation sign and press the Volume Up key. When your phone gets into the Download/Odin mode, open the Odin folder and launch the Odin v3.11.1.exe as administrator. Now connect your Galaxy S7 to your computer using a USB cable. The ID:COM port on Odin will be highlighted in blue as soon as your device is detected. Click the AP button in Odin and add the twrp-3.1.0-0-hero2lte.img.tar file to Then Click the Options tab in Odin and uncheck Auto-Reboot. Now click the Start button to trigger TWRP installation. When TWRP is installed and you get PASS! message in Odin. Disconnect the USB cable if you wish to. However, if you want to copy the SuperSU and no-very-opt-encrypt zip files over MTP, stay connected to PC. Now press and hold the Volume Down + Home + Power buttons at the same time and immediately swap to Volume Up as soon as the screen goes blank/black while still pressing the Home and Power keys. Keep the 3 keys pressed until you get into TWRP Recovery. At this point, you will reach the screen asking if you want to allow system modifications. Just ignore the warning. Now tap Reboot> Recovery. Your S7 will get into TWRP mode again. Now connect your phone (while booted in TWRP mode) to your PC and transfer no-verity-opt-encrypt-5.0.zip and SR3-SuperSU-v2.79-SR3-20170114223742.zip files using MTP mode (via USB cable). Tap the Install button in Odin, navigate to no-verity-opt-encrypt-5.0.zip and select it. Swipe the confirmation slider when prompted. When it’s flashed, go back and tap Reboot> Recovery. When your phone reboots into TWRP recovery, tap Install again and install SR3-SuperSU-v2.79-SR3-20170114223742.zip this time. The SuperSU is flashed, go back to TWRP main menu and tap Reboot System. Done! The first boot might take awhile so don’t panic and wait patiently. After one time set will be restarted then run normally, your Root Success.. Special thanks to yeshil for create this video tutorial http://forum.gsmhosting.com/vbb/f777...ot-ok-2210641/ Source ==> XDA & CF Auto-root
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 04-02-2017 at 06:24. Reason: Information update |
The Following 12 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
01-14-2018, 23:06 | #4 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Did You mean what exactly by your post, of course the TWRP method works perfectly.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
01-17-2018, 00:02 | #5 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2799920 Status: Offline Thanks Meter: 2 | Hi i'm with G930F S7 . I get "operation faild" in the odin log after i'm flasing with twrp -3 . 1 . 0 -0 - hero 2 lte . img . tar . I also got a message on the phone screen " Custom Binary" (recovery) blocked by frp lock... help please? should I flash with another file before that operation ? |
01-17-2018, 19:17 | #6 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Very easy, fast remove your FRP lock protection, after you can flash TWRP or 3'rd party kernel file for Root. Because when your phone inside has been FRP lock protection enabled, you can't flash any kind of 3'rd party kernel.
