Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-22-2018, 09:13   #16 (permalink)
Member: 2130020
Thanks Meter: 6
I'm stuck (I've about 1 hour with same message) at:
Status for device COM2:
Baud: 115200
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: ON
XON/XOFF: OFF
CTS handshaking: OFF
DSR handshaking: OFF
DSR sensitivity: OFF
DTR circuit: OFF
RTS circuit: OFF
Status for device CON:
Lines: 40
Columns: 110
Keyboard rate: 31
Keyboard delay: 1
Code page: 437
νδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδ
Input Port Number[1~300,x:Exit]:2
2
Start Recovery.
emmcdl.exe -p COM2 -f prog_ufs_firehose_8996_ddr.elf -MemoryName ufs -SetActivePartition 1 -x rawprogram0.xml -x rawprogram1.xml -x rawprogram2.xml -x rawprogram3.xml
Version 2.10
Old 02-24-2018, 14:49   #17 (permalink)
Member: 2711124
Thanks Meter: 40
Originally Posted by disable-lock View Post
g9550 u2 pls help g9550 u2 pls help
I think I can try to save it
Old 02-25-2018, 08:06   #18 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,147
Baud: 115200
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: ON
XON/XOFF: OFF
DTR circuit: OFF
RTS circuit: OFF
Lines: 40
Columns: 110
Keyboard rate: 31
Keyboard delay: 1
Code page: 437
2
Start Recovery.
Version 2.10
unistaill driver 9008 than reboot phone conect phone again reprocess done
Old 02-25-2018, 08:58   #19 (permalink)
Member: 2400457
Sonork: khurram7280072
Thanks Meter: 7
ahmad bro plz giving correct test point show. which test point we use??????????
Old 02-25-2018, 23:09   #20 (permalink)
Member: 2400457
Thanks Meter: 7
yes response done and gone download mode fine... my mobile is g935v.. i flashed combination file G935A/G935V combo 1 file. now my mobile in binary mode fine working, b4 my phone is showing in download mode G935V after combination flashed and qual com mode recovery done my phone showing G935A... when i want normally flashed from and z3x and odin no any modal take latest files G935v and G935A.. but still show in download mode G935A... in binary mode phone fine working...official stock firmware no flashing, when i flashed in download mode..........
RPMB PROVISIONED
SW REV CHECK FAIL : [about] Fused 5 > Binary 4
plz help me what can i do my customer mobile fine normally working showing??????????
Old 02-28-2018, 14:41   #21 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 522
i need help with g930p..... stuck in slb error , please is urgent
Old 03-01-2018, 12:52   #22 (permalink)
KUMARANSUGUMAR's Avatar
Member: 726340
Sonork: 100.1624264
Thanks Meter: 85
pls give me clear testpoint image bro
Old 03-01-2018, 19:59   #23 (permalink)
Member: 1209155
Thanks Meter: 40
G95550 u2 S8+ dead after flash combine file sam one help please
Old 03-09-2018, 07:36   #24 (permalink)
Member: 2189365
Sonork: 1614214
Thanks Meter: 18
please sir can you help me about sc-02h_g935d please ahmad bro
Old 03-09-2018, 07:48   #25 (permalink)
Member: 2189365
Sonork: 1614214
Thanks Meter: 18
i have tried but not working on g935d_sc-02h please urgently help me
Data Bits: 7
Stop Bits: 1
Timeout: OFF
XON/XOFF: OFF
DTR circuit: ON
RTS circuit: ON
Lines: 40
Columns: 110
Keyboard rate: 31
Keyboard delay: 1
Code page: 850
νΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩ
Input Port Number[1~300,x:Exit]:4
4
Start Recovery.
emmcdl.exe -p COM4 -f prog_ufs_firehose_8996_ddr.elf -MemoryName ufs -SetActivePartition 1 -x rawprogram0.xml -x rawprogram1.xml -x rawprogram2.xml -x rawprogram3.xml
Version 2.10
Downloading flash programmer: prog_ufs_firehose_8996_ddr.elf
Successfully open flash programmer to write: prog_ufs_firehose_8996_ddr.elf
Expecting SAHARA_END_TRANSFER but found: 0
!!!!!!!! WARNING: Flash programmer failed to load trying to continue !!!!!!!!!
Programming UFS device using SECTOR_SIZE=4096
<?xml version = "1.0" ?><data><configure MemoryName="ufs" ZLPAwareHost="1" SkipStorageInit="0" SkipWrite="0" MaxPayloadSizeToTargetInBytes="1048576"/></data>
The Following User Says Thank You to hacker.spone For This Useful Post:
Old 03-16-2018, 20:01   #26 (permalink)
Member: 751235
Sonork: 100.1662008
Thanks Meter: 522
please can anyone help me out? need clear tp picture
Old 04-09-2018, 07:54   #27 (permalink)
Member: 1250693
Thanks Meter: 3
Tested on a G930T and it worked perfect. THNX
Old 04-09-2018, 12:21   #28 (permalink)
Member: 2574379
Thanks Meter: 14
Please Approve my request to access your files.. google drive is asking for sending request to owner
Old 04-11-2018, 01:32   #29 (permalink)
Member: 1250693
Thanks Meter: 3
remove spaces bit .ly/ 2GQ70tv sorry but forum dont let share links
The Following User Says Thank You to insect33 For This Useful Post:
Old 04-11-2018, 17:57   #30 (permalink)
Member: 1250693
Thanks Meter: 3
remove spaces bit. ly /2v1tOVI the forum dont let me post links or images, sorry
The Following 2 Users Say Thank You to insect33 For This Useful Post:
Page generated in 0.38597 seconds with 7 queries
