Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 04-24-2018, 05:18   #31 (permalink)
Member: 1629495
please help me I have a G930P that was in use and suddenly turn off by itself and since it is on Qualcomm 9008 mode, no need for testpoint I think but when I try the recovery I get this error.
emmcdl.exe it not recognized as an internal or external command
Old 04-24-2018, 05:58   #32 (permalink)
Member: 269202
Thanks Meter: 254
Hi
please upload in another site
i cant download from link
Old 04-25-2018, 16:36   #33 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 268
G950U2
I used this files (from XDA) https://forum.xda-developers.com/gal...brick-t3668572
Samsung S8 G950U1
I get following error
<log value="ERROR: ufs_open_error_code 1 :: 0x114"/>
</data>
<?xml version="1.0" encoding="UTF-8" ?>
<data>
<log value="ERROR: ufs_open_error_code 2 :: 0x114"/>
</data>
<data>
<log value="ERROR: ufs_open_error_code 3 :: 0x114"/>
</data>
<data>
<log value="ERROR: ufs_open_error_code 4 :: 0x114"/>
</data>
<data>
<log value="ERROR: last ufs_open_error_code 16 :: 0x114"/>
</data>
<data>
<log value="ERROR: Failed to open the device 3 slot 0 partition 1"/>
</data>
<data>
<log value="INFO: Device type 3, slot 0, partition 1, error 0"/>
</data>
<data>
<log value="WARN: Set bootable failed to open 3 slot 0, partition 1, error 0"/>
</data>
<data>
<response value="NAK" />
</data>
---Target returned NAK---
Status: 13 The data is invalid.
Finish!!
The Following User Says Thank You to silhouette For This Useful Post:
Old 06-10-2018, 04:27   #34 (permalink)
Member: 2513902
hey geys
i have problem in g9500z dead after flash
and i need to repair boot
thx in advanse
Old 06-21-2018, 13:49   #35 (permalink)
dilbarkhan's Avatar
Member: 1814786
Sonork: 100.1619255
Thanks Meter: 30
The Link Does not work Anyone give here
Originally Posted by ahmedmohmed7274 View Post
Hello :
Today, we will provide you with repair files for all the phones of samsung dead after flashing Comb or Eng-root or error downgrade
fix will be done in Qualcom 9008 Mode
Download File And Run Recovery.bat
make TP in your Phone to enter Qualcom mode 9008
last waiting for repair done and enter download mode and make full flashing
link for files :
https://drive.google.com/drive/folde...JQbGpoHjz2bwoT
I hope everyone benefits
Greetings to you and thank you
bro :
ahmed mohmed 7274
Old 06-21-2018, 14:19   #36 (permalink)
Temporary banned !!
Member: 2511938
Thanks Meter: 118
i have file unbrick u2 u3 u4
Old 06-23-2018, 16:53   #37 (permalink)
Member: 166506
Thanks Meter: 18
please upload for g930f link dead
tx in advance
Old 07-10-2018, 07:15   #38 (permalink)
fofesz's Avatar
Member: 22869
Thanks Meter: 127
Thank you, repaired G930V aswell!
Make TP, connect without battery and Qualcomm 9008 recognised, remove TP than start flashing.
uploaded again:
https://mega.nz/#!6lwDQADb!24PISN8Q6...m1l1mqGghyi_6M
The Following 3 Users Say Thank You to fofesz For This Useful Post:
Old 07-16-2018, 06:32   #39 (permalink)
Member: 2514217
Thanks Meter: 71
how about SC-02H unbrick file? because now it stuck at SBL Error mode
Old 07-17-2018, 13:43   #40 (permalink)
Member: 2714502
Thanks Meter: 16
Instead of TP you should be able to just use a USB cable and short Dat0 to ground.
Old 07-18-2018, 17:41   #41 (permalink)
Member: 1391794
Thanks Meter: 52
does this work on sm-g965u?
Old 09-15-2018, 03:30   #42 (permalink)
Member: 2718897
Thanks Meter: 27
i have g965u rev2 edl files
Sent from my SM-N960U using Tapatalk
Old 09-23-2018, 01:17   #43 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 342
12 device not ready
any solution please?
Old 09-23-2018, 06:32   #44 (permalink)
diddygy's Avatar
Member: 1629133
Thanks Meter: 368
Hi for GT-I8190N dead boot solution sdcard
Thanks in advance!
Old 09-29-2018, 07:10   #45 (permalink)
Member: 671420
Thanks Meter: 13
Originally Posted by otherboy123 View Post
Not Work Plz help
Version 2.15
SerialNumber: 0xef1fdd2a
MSM_HW_ID: 0x009470e1
OEM_PK_HASH: 0x77b4f33930c480d0d2007909dfa3284eb5e4d41782a0ac8e 22718273a1d3a68b
SBL SW Version: 0x00000001
Status: 0 The operation completed successfully.
D:\EMMC\Unbrick\G930XU5>Input Port Number[1~300,x:Exit]:70
'Input' is not recognized as an internal or external command,
operable program or batch file.
D:\EMMC\Unbrick\G930XU5>70
'70' is not recognized as an internal or external command,
D:\EMMC\Unbrick\G930XU5>Start Recovery.
D:\EMMC\Unbrick\G930XU5>emmcdl.exe -p COM70 -f prog_ufs_firehose_8996_ddr.elf -MemoryName ufs -SetActivePartition 1 -x rawprogram0.xml -x rawprogram1.xml -x rawprogram2.xml -x rawprogram3.xml
Version 2.15
Downloading flash programmer: prog_ufs_firehose_8996_ddr.elf
Successfully open flash programmer to write: prog_ufs_firehose_8996_ddr.elf
Expecting SAHARA_END_TRANSFER but found: 0
!!!!!!!! WARNING: Flash programmer failed to load trying to continue !!!!!!!!!
Programming UFS device using SECTOR_SIZE=4096
<?xml version = "1.0" ?><data><configure MemoryName="ufs" ZLPAwareHost="1" SkipStorageInit="0" SkipWrite="0" MaxPayloadSizeToTargetInBytes="1048576"/></data>
ERROR: No response to configure packet
Status: 21 The device is not ready.
same problema here can't solve this issue. any help please
The Following User Says Thank You to gurrumichi For This Useful Post:
Page generated in 0.43280 seconds with 7 queries
