Upgrade Samsung Galaxy S i9000 Firmware using Odin Flash Too Upgrade Samsung Galaxy S i9000 Firmware using Odin Flash Too flash Samsung Galaxy S i9000 with either leaked, custom ROM or Official release. Requirements
Procedure
Disclaimer
Flashing the device firmware can fix unexpected errors or failures on the device or when all else fails, it is the only way to restore a device to working condition after a partial brick or boot loop. Preparing and Setting up ODIN and Files used to Flash. -Odin3 version 1.85 or here Then download the latest Samsung Galaxy S II Original Firwares Or find and Download the latest firmware Updates Flashing the Samsung Galaxy S II I9100 Procedures: 1. Extract and Run the ODIN flasher tool. 2. Check these checkboxes options: Re-Partition , Auto Reboot , F.Reset Time 3. Select the PDA/Modem/CSC/.PIT files in Odin In the PIT section, select the u1_02_20110310_emmc_EXT4.pit file you downloaded. In the PDA section, select the CODE_I9100xxxxx_CL161513_REV02_user_low_ship.tar.m d5 file. In the PHONE section, select the MODEM_I9100xxxxx_REV_02_CL995882.tar.md5 file. In the CSC section, select the GT-I9100-MULTI-CSC-Oxxxxx.tar.md5 file. 4. Prepare the Samsung Galaxy S II into DOWNLOAD MODE. Turn the phone into the download mode by pressing and holding VolumeDown+OK+Power at the same time. 5. Connect the Device to PC using the DATA cable Connect your phone with your computer and wait until the drivers are installed. Make sure the ID:COM box highlighted yellow to know that the handset is connected to the PC properly. If you still do not get any results, try another USB port on your computer. 6. When all binary files needed is ready, Enter the Device into Firmware Downloading process, Click Start. The phone will be flashed and once it’s finished, it will boot up.Do NOT disconnect the usb-cable, remove the battery or otherwise interrupt this process! But if you do not see a blue progress bar on your phone after 5 minute, take out your phones battery, unplug your phone and start from step 1 again. 7. Handset reboots when flash or download completes Once you see the message "PASS!", you have successfully flashed your phone. 8. Codes to confirm the Downloaded Firmware Version *#1234# Full Reset *2767*3855# BR .::JUNAID ARAIN::. |
link not working a bout original firmware |
ned firmware i Ned firmware Samsung i90000 |
Br, azam |
hi bro plz send me file link |
regards |
hi sir samsung I9000 baseband unknown sol^ plzzzz |
assistance please in getting driver files, firmware i wish to remove the google account from my gt-i9000 it as been reset via the android reset function, but when restarting the phone its still askin for agoogle id. i have odin, i downloaded samsung drivers but windws still has th phon as umknown device. the phone is in down loadmode can any one please assist me please |
