Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 01-26-2013, 06:50   #1 (permalink)
JUNAID ARAIN's Avatar
Member: 1530955
Sonork: 100.1627356
Thanks Meter: 213
Thumbs up Upgrade Samsung Galaxy S i9000 Firmware using Odin Flash Too
flash Samsung Galaxy S i9000 with either leaked, custom ROM or Official release.
Requirements
  • Unlocked Samsung Galaxy S i9000
  • Latest Samsung Kies or Device drivers installed.
  • ODIN 3 version 1.0 (flash program)
  • Upgrade Firmware upgrade File (.tar) can be downloaded from Samsung-Firmware
  • .PIT file (the boot file of the phone generally called 512.pit) which will be included in upgrade file.
  • USB cable
Procedure
  • Open Odin (preferably “Run as Administrator”)
  • Browse the PIT file from extracted firmware upgrade.
  • In PDA, browse the TAR file which is the main file requirement.
  • Optionally if there is any file with CSC in it, browse and select it.
  • Switch off Phone and remove SD Card (if any) and SIM.
  • Connect with USB
  • Hold Volume down + Home Key + Power button till the phone boots in “Download mode”.
  • Press Start button on Odin program window after it detects ID:COM
  • Phone will reboot again and whoa! your Phone is flashed with latest firmware.
Disclaimer
  • Take Backup of Contacts, Messages and Calender events and Apps before proceeding as it will erase all data in ROM.
  • I have flashed my Samsung Galaxy S i9000 with official leaked ROM using the following procedure and it worked fine on Windows 7.
  • We are not responsible if you accidentally brick your phone.
Let any firmware release or leak on web, if it is not available officially for you, flashing with odin is a working method. After Flashing, the phone is unrooted so, you will have to root Samsung Galaxy S i900 again in one click available for 2.1 Eclair and 2.2 Froyo.
Flashing the device firmware can fix unexpected errors or failures on the device or when all else fails, it is the only way to restore a device to working condition after a partial brick or boot loop.
Preparing and Setting up ODIN and Files used to Flash.
-Odin3 version 1.85
or here
Then download the latest Samsung Galaxy S II Original Firwares
Or find and Download the latest firmware Updates
Flashing the Samsung Galaxy S II I9100 Procedures:
1. Extract and Run the ODIN flasher tool.
2. Check these checkboxes options: Re-Partition , Auto Reboot , F.Reset Time
3. Select the PDA/Modem/CSC/.PIT files in Odin
In the PIT section, select the u1_02_20110310_emmc_EXT4.pit file you downloaded.
In the PDA section, select the CODE_I9100xxxxx_CL161513_REV02_user_low_ship.tar.m d5 file.
In the PHONE section, select the MODEM_I9100xxxxx_REV_02_CL995882.tar.md5 file.
In the CSC section, select the GT-I9100-MULTI-CSC-Oxxxxx.tar.md5 file.
4. Prepare the Samsung Galaxy S II into DOWNLOAD MODE.
Turn the phone into the download mode by pressing and holding
VolumeDown+OK+Power at the same time.
5. Connect the Device to PC using the DATA cable
Connect your phone with your computer and wait until the drivers are installed.
Make sure the ID:COM box highlighted yellow to know that the handset is connected to the PC properly.
If you still do not get any results, try another USB port on your computer.
6. When all binary files needed is ready, Enter the Device into Firmware Downloading process, Click Start.
The phone will be flashed and once it’s finished, it will boot up.Do NOT disconnect the usb-cable, remove the battery or otherwise interrupt this process!
But if you do not see a blue progress bar on your phone after 5 minute, take out your phones battery, unplug your phone and start from step 1 again.
7. Handset reboots when flash or download completes
Once you see the message "PASS!", you have successfully flashed your phone.
8. Codes to confirm the Downloaded Firmware Version
*#1234#
Full Reset
*2767*3855#
.::JUNAID ARAIN::.
The Following 5 Users Say Thank You to JUNAID ARAIN For This Useful Post:
Old 09-07-2013, 16:11   #2 (permalink)
mazentel..'s Avatar
Member: 155719
Thanks Meter: 92
link not working a bout original firmware
Old 10-30-2013, 04:51   #3 (permalink)
Member: 2040745
Sonork: 100.1647585
Thanks Meter: 8
Arrow ned firmware
i Ned firmware Samsung i90000
Old 10-30-2013, 14:29   #4 (permalink)
..::Nokian Care®::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,225
here is your firmware Hotfile.com: One click file hosting: Samsung-Updates.com-GT-I9000_DBT_2_20110525171343.zip
Br,
azam
Old 04-16-2014, 07:29   #5 (permalink)
Member: 1038649
hi bro plz send me file link
Old 04-16-2014, 07:49   #6 (permalink)
Murat Bekar's Avatar
Member: 2088
Sonork: 100.1630154
Thanks Meter: 56
Samsung GT-I9000,Samsung GT-I9000 (Galaxy S) official firmwares download
regards
The Following User Says Thank You to Murat Bekar For This Useful Post:
Old 04-17-2014, 09:01   #7 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Odin3_v1.84 - Download - 4shared - Hossne Mamun Hossne Mamun
Old 06-11-2014, 14:40   #8 (permalink)
Member: 1674140
hi sir samsung I9000 baseband unknown sol^ plzzzz
Old 11-28-2015, 05:14   #9 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 91
Old 09-10-2016, 07:37   #10 (permalink)
Member: 2622882
assistance please in getting driver files, firmware
i wish to remove the google account from my gt-i9000 it as been reset via the android reset function, but when restarting the phone its still askin for agoogle id.
i have odin, i downloaded samsung drivers but windws still has th phon as umknown device. the phone is in down loadmode
can any one please assist me please
Old 01-22-2017, 00:02   #11 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 469
https://mega.nz/#!udMkFAgD!LIz4X3P2S...dHFOXyZFpj6UqI
The Following User Says Thank You to gunit1 For This Useful Post:
Page generated in 0.33803 seconds with 7 queries
