Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-09-2014, 15:05 | #1 (permalink) |
No Life Poster Join Date: Jun 2013 Location: BANGLADESH+UAE Age: 34
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | Working CWM Recovery For Galaxy Core GT-I8262 Download Links : STOCK RECOVERY : http://www.mediafire.com/?531dq5mi794dki8 CWM : http://www40.zippyshare.com/v/48874900/file.html ODIN 3.07 : http://www.mediafire.com/download/77...x2/Odin307.zip Galaxy Core Drivers :http://developer.samsung.com/board/d...hId=0000000001 INSTRUCTIONS : 1. Install the Galaxy Core Drivers On Your Desktop 2. Extract ODIN.zip on your Desktop 3. Copy Recovery.tar File In ODIN Folder(its preferable to keep them in the same directory) 4. Now Go To Your Phone Settings 5. Click On Developer Options & Tick USB Debugging 6. Turn Off Your Phone 7. After Your Mobile Is Completely Turned Off Go Into Downloading Mode - Press & Hold Volume Down +Home Key +Power Key, Press Volume Up Again To Proceed 8. Connect Your Phone To Your PC via USB Cable 9. Now Open ODIN 3.07 10. Your Phone Should Be Detected In ODIN If You Have Installed The Drivers Correctly 11. Now Click On The PDA Button Then Select recovery.tar(CWM Recovery File) 12. Press The Start Button. Now The Installation Should Start. 13. When The Installation Is Completed It Should Display "PASS" Then Remove The USB Cable From Your Device 14. Now To Go Into CWM Recovery - Turn Off Your Phone Completely. 15. Press Power Button + Home Button + Volume Down Button. 16. Now You Have A CWM Recovery!!!!!!!!!!!!!! If It Helped HIT the "THANKS" button!!! |
The Following 7 Users Say Thank You to maxmobilephone For This Useful Post: |
06-27-2016, 15:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | Flashed this recovery file using odin in i8262 but not success to go in recovery mode......phone condition is "firmware upgrade encountred an issue " |
