Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-20-2018, 14:55 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: pakistan
Member: 2503555 Status: Offline Thanks Meter: 90 | Samsung ''S7''S7 Edge''S8''S8+''Note 8'' Dead Boot Repair by One Click [World First] s7 dead boot file CuT URLs s7 edge CuT URLs s8 CuT URLs s8 plus CuT URLs note 8 CuT URLs Mirror Download Link http://forum.gsmhosting.com/vbb/13187543-post15.html Last edited by ...:::::NP™:::::...; 06-21-2018 at 10:01. Reason: Mirror download link added |
The Following 16 Users Say Thank You to imrangsmali For This Useful Post: |
03-13-2018, 15:08 | #7 (permalink) |
Freak Poster Join Date: May 2014
Member: 2189365 Status: Offline Sonork: 1614214 Thanks Meter: 22 | giving this error bro please can you give me solution? sir Data Bits: 8 Stop Bits: 1 Timeout: OFF XON/XOFF: OFF CTS handshaking: OFF DSR handshaking: OFF DSR sensitivity: OFF DTR circuit: OFF RTS circuit: OFF Status for device CON: ---------------------- Lines: 40 Columns: 110 Keyboard rate: 31 Keyboard delay: 1 Code page: 850 νΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩνΩ Input Port Number[1~300,x:Exit]:3 3 Start Recovery. emmcdl.exe -p COM3 -f prog_ufs_firehose_8996_ddr.elf -MemoryName ufs -SetActivePartition 1 -x rawprogram0.xml -x rawprogram1.xml -x rawprogram2.xml -x rawprogram3.xml Version 2.10 Downloading flash programmer: prog_ufs_firehose_8996_ddr.elf Successfully open flash programmer to write: prog_ufs_firehose_8996_ddr.elf Expecting SAHARA_END_TRANSFER but found: 0 !!!!!!!! WARNING: Flash programmer failed to load trying to continue !!!!!!!!! Programming UFS device using SECTOR_SIZE=4096 <?xml version = "1.0" ?><data><configure MemoryName="ufs" ZLPAwareHost="1" SkipStorageInit="0" SkipWrite="0" MaxPayloadSizeToTargetInBytes="1048576"/></data> |
The Following User Says Thank You to hacker.spone For This Useful Post: |
05-30-2018, 06:18 | #12 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | i have g935p deadboot after flash combination files Data Bits: 8 Stop Bits: 1 Timeout: OFF XON/XOFF: OFF CTS handshaking: OFF DSR handshaking: OFF DSR sensitivity: OFF DTR circuit: OFF RTS circuit: OFF Status for device CON: ---------------------- Lines: 40 Columns: 110 Keyboard rate: 31 Keyboard delay: 1 Code page: 437 νδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδνδ Input Port Number[1~300,x:Exit]:197 197 Start Recovery. emmcdl.exe -p COM197 -f prog_ufs_firehose_8996_ddr.elf -MemoryName ufs -SetActivePartition 1 -x rawprogram0.xml -x rawprogram1.xml -x rawprogram2.xml -x rawprogram3.xml Version 2.10 Downloading flash programmer: prog_ufs_firehose_8996_ddr.elf Successfully open flash programmer to write: prog_ufs_firehose_8996_ddr.elf Expecting SAHARA_END_TRANSFER but found: 0 !!!!!!!! WARNING: Flash programmer failed to load trying to continue !!!!!!!!! Programming UFS device using SECTOR_SIZE=4096 <?xml version = "1.0" ?><data><configure MemoryName="ufs" ZLPAwareHost="1" SkipStorageInit="0" SkipWrite="0" MaxPayloadSizeToTargetInBytes="1048576"/></data> |
06-20-2018, 13:03 | #13 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | 3 last links dead, any one to upload? so we can test Last edited by ...:::::NP™:::::...; 06-21-2018 at 09:40. |
The Following User Says Thank You to Formingus For This Useful Post: |
06-21-2018, 09:38 | #15 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Hi, Here's the direct download link of 2. Dead Boot Repair by One Click ''S7''S7edge''S8 ''S8+''Note8'' [World First] 'S7''S7 Edge''S8''S8+''Note 8'' Dead Boot Repair by One Click [World First]
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 06-24-2018 at 15:21. |
The Following 12 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
