Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 11-05-2014, 17:11   #61 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Originally Posted by Rui Romano View Post
I need some help please
first how do I flash the remove lock file on your 4shared page on the phones
second is it possible to provide a file to Xperia D2303.
Or is there any way to make him.
Please help me descybing a litle better this procedure please
I am a rokie with this tool.
And my differs a little bit from the pictures also since it doesn't provide me with the SEUS Decrypt menu also.
And I am with two totally tactil screen and without any back key.
Witch keu also shall I press in these cases with this tool please.
Sory for all these questions.
I apreciate all the help anyone can give me.
In new version flashtool select lik below givn n the picr
After create flash usng same tool. press volume down key nd cnnt usb to flash yur mob
Old 11-06-2014, 07:19   #62 (permalink)
Member: 1422757
hi i need xperia e3 D2212 pattern lock remove file
Old 11-06-2014, 08:57   #63 (permalink)
Member: 636569
Thanks Meter: 192
need st26i remove lock and user data....help
Old 11-06-2014, 09:24   #64 (permalink)
VIJAYMOURYA's Avatar
Member: 712406
Sonork: 100.1651933
Thanks Meter: 251
i need d2212 file..please upload
Old 11-06-2014, 09:40   #65 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Xperia j St26i already included check the download link n my 1st post
Old 11-06-2014, 09:45   #66 (permalink)
Support.gsm.codes's Avatar
Member: 2273252
Thanks Meter: 369
LT29i lock remove.ftf Download link. Piliz help
Old 11-06-2014, 09:56   #67 (permalink)
RICKY great's Avatar
Member: 641849
Sonork: 100.1619689
Thanks Meter: 44
need lt30p lock remove file bro pls share
Old 11-06-2014, 10:23   #68 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Lt29i already included check the download link in my 1st post .
Old 11-06-2014, 20:26   #69 (permalink)
Member: 889598
Thanks Meter: 6
after update service server closed u save all of us
The Following 2 Users Say Thank You to NIRAJ JHA For This Useful Post:
Old 11-07-2014, 11:49   #70 (permalink)
Member: 636569
Thanks Meter: 192
need c1605 bro......
Old 11-07-2014, 14:55   #71 (permalink)
mak1983's Avatar
Member: 1704666
Sonork: 100.1652565
Thanks Meter: 157
need lock remove file sk17i i have create SK17i_4.1.B.0.587_lock remove.ftf siz 111 kb
i try flashing sony flash tool showing this
07/024/2014 19:24:10 - INFO - <- This level is successfully initialized
07/024/2014 19:24:10 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00
07/024/2014 19:24:15 - INFO - Device disconnected
07/024/2014 19:24:18 - INFO - Selected SK17i / 4.1.B.0.587 / lock remove
07/024/2014 19:24:18 - INFO - Preparing files for flashing
07/024/2014 19:24:18 - INFO - Please connect your device into flashmode.
07/024/2014 19:24:24 - INFO - Device connected in flash mode
07/025/2014 19:25:04 - INFO - Device disconnected
any version
1} Flashtool Version 0.9.11.0 built
2} flashtool-0.9.13.0-windows_2
3} flashtool-0.9.18.1-windows
4} flashtool-0.9.18.3-windows
but not successes device power on not flashing
Old 11-07-2014, 19:55   #72 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
any version
Use wel charged battery, install latest driver nd check
Old 11-07-2014, 20:54   #73 (permalink)
gsm_masud7's Avatar
Member: 2102992
Sonork: 100.1626305
Thanks Meter: 2,763
Thumbs up sony d6503 remove screen lock
remove screen lock test by me
Download link......
D6503_17.1.2.A.0.314_R4A_Customized MEA2
best solution........
gsm_masud7
Old 11-07-2014, 22:04   #74 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
Thanks Meter: 5,082
REQUIREMENTS:
+ Windows XP SP2 or newer!
+ Microsoft .NET Framework 3.5 or newer!
+ Flashtool* OR Java Runtime Environment 8:
--- for Windows 32-bit: Download Java Runtime Environment 8.0 build 25 (32-bit) - FileHippo.com
--- for Windows 64-bit: Download Java Runtime Environment 8.0 build 25 (64-bit) - FileHippo.com
* If you have Flashtool installed, Java Runtime is bundled with it and doesn't have to be installed separately. Just extract XperiFirm's files to Flashtool's folder and run XperiFirm.exe from there. (See screenshot below)
* For Windows 8 or 8.1 users: If you want to run XperiFirm without installing any old .NET Framework, make sure you also extract "XperiFirm.exe.config" to the same folder XperiFirm.exe is located. [Thanks to aphanic for pointing out this Windows 8 issue]
CHANGELOG:
v3.0b [November 07, 2014]:
- MINOR: Fixed some annoying visual glitches.
v3.0a [November 07, 2014]:
- FIX: Fixed a crash caused by some missing files on Sony servers that messed up with column ordering by Latest Release. (this happens when Sony just begins to roll an update, it's a big mess of missing files, you'll just need to wait patiently until Sony finishes uploading their updates).
v3.0 [November 07, 2014]:
- ATTENTION: XperiFirm now targets .NET Framework 3.5 or later to enable some of the newer features!
- NEW: Total UI re-make. More information about each device (like project/code name). Easier to navigate then ever before. Many levels above any other firmware downloading tool.
- NEW: XperiFirm.jar is being self-extracted when you launch XperiFirm.exe. It is being always validated to be the correct file and recreated if it was modified or damaged.
- NEW: Smart downloading: Dummy files are not downloaded. Each file gets a name by analyzing data received from Sony.
- NEW: Smart auto-decryption ability, that uses online data to correctly unpack the firmware and prepare it for FTF creating in Flashtool.
- NEW: Smart sorting for both "Market" and "Operator", for finding your firmware easily.
- NEW: Smart release version checking: Only empty "Latest Release" fields will be checked when using "Check All".
- NEW: Smarter error handling.
- NEW: Added support for multiple simultaneous downloads.
- NEW: Added the ability to copy the raw download links of a firmware to the clipboard. Use however you want and at your own risk!
- NEW: Each and every device is being recognized exactly as marketed by Sony all around the UI, including devices that are merely variants of the same device.
- NEW: The download folder will always have a unique name (adding "(#)" instead of overwriting).
- NEW: The date of the latest update to the device list or any of the CDF lists will be displayed below the device list.
- NEW: A cool sound will notify you when a firmware finishes downloading and/or unpacking.
- FIX: Fixed a bug that broke the scrollbars of the CDF list when minimizing the window.
- DONATE: A nice looking donation button was added, please use it to support me!
Download
XperiFirm_3.0b_(by_IaguCool).zip 183 KB
https://mega.co.nz/#!i4J3zQqR!aIREWI...rDgs28eCPRQr-M
Old 11-08-2014, 02:05   #75 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
Mego not open plz sare other link i try to install maney softwer but root element is missing
Page generated in 0.27734 seconds with 8 queries
