Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
10-10-2015, 01:40 | #631 (permalink) |
Freak Poster Join Date: Jul 2010 Location: soudi arabia
Member: 1339076 Status: Offline Thanks Meter: 30 | 10/037/2015 13:37:09 - INFO - <- This level is successfully initialized 10/037/2015 13:37:09 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00 10/037/2015 13:37:11 - INFO - Device disconnected 10/037/2015 13:37:20 - INFO - Selected Experia E4 model E2104 pattern unlock only / 1293-1927_24.0.A.5.14_R4A / _Customized GEL_ 10/037/2015 13:37:20 - INFO - Preparing files for flashing 10/037/2015 13:37:56 - INFO - Please connect your device into flashmode. 10/038/2015 13:38:06 - INFO - Device connected in flash mode 10/038/2015 13:38:07 - INFO - Opening device for R/W 10/038/2015 13:38:08 - INFO - Device connected in flash mode 10/038/2015 13:38:08 - INFO - Reading device information 10/038/2015 13:38:08 - INFO - Start Flashing 10/038/2015 13:38:08 - INFO - Processing loader.sin 10/038/2015 13:38:08 - INFO - Checking header 10/038/2015 13:38:08 - INFO - Ending flash session 10/038/2015 13:38:08 - ERROR - Error in processHeader : Read error :31 : A device attached to the system is not functioning. 10/038/2015 13:38:08 - ERROR - Error flashing. Aborted 10/038/2015 13:38:09 - INFO - Device connected in flash mode 10/038/2015 13:38:17 - INFO - Device disconnected |
10-12-2015, 03:11 | #635 (permalink) |
Member: 1339076 Status: Offline Thanks Meter: 30 | sony e2104 flash but pattern lock cant remove 12/004/2015 15:04:41 - INFO - Flashtool Version 0.9.19.0 built on 29-07-2015 12:00:00 12/004/2015 15:04:41 - INFO - Executing search strategies to find proxy selector 12/004/2015 15:04:42 - INFO - No proxy found for IE. Trying next one 12/004/2015 15:04:43 - INFO - No proxy found for firefox. Trying next one 12/004/2015 15:04:43 - INFO - No proxy found for java. Trying next one 12/004/2015 15:04:43 - INFO - Syncing devices from github 12/004/2015 15:04:44 - INFO - Scanning devices folder for changes. 12/004/2015 15:04:57 - INFO - Pulling changes from github. 12/004/2015 15:04:59 - INFO - Devices sync finished. 12/005/2015 15:05:04 - INFO - Device disconnected 12/005/2015 15:05:08 - INFO - Selected Bundle for Experia E4 model E2104 pattern unlock only. FW release : 1293-1927_24.0.A.5.14_R4A. Customization : _Customized GEL_ 12/005/2015 15:05:08 - INFO - Preparing files for flashing 12/005/2015 15:05:08 - INFO - Please connect your device into flashmode. 12/005/2015 15:05:19 - INFO - Device connected in flash mode 12/005/2015 15:05:20 - INFO - Opening device for R/W 12/005/2015 15:05:21 - INFO - Device connected in flash mode 12/005/2015 15:05:21 - INFO - Reading device information 12/005/2015 15:05:21 - INFO - Phone ready for flashmode operations. 12/005/2015 15:05:21 - INFO - Opening TA partition 2 12/005/2015 15:05:21 - INFO - Current device : E2104 - WUJ01HM62Q - 1293-7868_R4A - 1290-6614_24.0.A.3.8 - WORLD-a_24.0.A.3.8 12/005/2015 15:05:21 - INFO - Closing TA partition 12/005/2015 15:05:21 - INFO - Start Flashing 12/005/2015 15:05:21 - INFO - Processing loader.sin 12/005/2015 15:05:21 - INFO - Checking header 12/005/2015 15:05:21 - INFO - Flashing data 12/005/2015 15:05:21 - INFO - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_10 / Bootloader status : ROOTABLE 12/005/2015 15:05:21 - INFO - Transfer buffer size : 262144 12/005/2015 15:05:21 - INFO - Found a template session. Using it : C:\Documents and Settings\lords\.flashTool\devices\E21XX\default.fs c 12/005/2015 15:05:21 - INFO - Opening TA partition 2 12/005/2015 15:05:21 - INFO - Writing TA unit 00002774. Value : [01] 12/005/2015 15:05:21 - INFO - Closing TA partition 12/005/2015 15:05:21 - WARN - partition is excluded from bundle 12/005/2015 15:05:21 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 01] 12/005/2015 15:05:21 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 03] 12/005/2015 15:05:21 - WARN - preloader_s1sbl is excluded from bundle 12/005/2015 15:05:21 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 01] 12/005/2015 15:05:21 - WARN - secro is excluded from bundle 12/005/2015 15:05:21 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 00] 12/005/2015 15:05:21 - INFO - Opening TA partition 2 12/005/2015 15:05:21 - WARN - cache is excluded from bundle 12/005/2015 15:05:21 - WARN - apps_log is excluded from bundle 12/005/2015 15:05:21 - WARN - lk is excluded from bundle 12/005/2015 15:05:21 - WARN - EBR1 is excluded from bundle 12/005/2015 15:05:21 - WARN - EBR2 is excluded from bundle 12/005/2015 15:05:21 - WARN - logo is excluded from bundle 12/005/2015 15:05:21 - WARN - MBR is excluded from bundle 12/005/2015 15:05:21 - WARN - boot is excluded from bundle 12/005/2015 15:05:21 - WARN - fotakernel is excluded from bundle 12/005/2015 15:05:21 - WARN - tee1 is excluded from bundle 12/005/2015 15:05:21 - WARN - tee2 is excluded from bundle 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Opening TA partition 2 12/005/2015 15:05:22 - WARN - Unit 2127 not found in bundle 12/005/2015 15:05:22 - WARN - Unit 2301 not found in bundle 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Opening TA partition 2 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Opening TA partition 2 12/005/2015 15:05:22 - WARN - system is excluded from bundle 12/005/2015 15:05:22 - WARN - userdata is excluded from bundle 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Opening TA partition 2 12/005/2015 15:05:22 - WARN - Unit 2212 not found in bundle 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Opening TA partition 2 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Opening TA partition 2 12/005/2015 15:05:22 - WARN - elabel is excluded from bundle 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Opening TA partition 2 12/005/2015 15:05:22 - INFO - Writing TA unit 00002725. Value : [32, 30, 31, 35, 2D, 31, 30, 2D, 31, 32, 20, 31, 35, 3A, 30, 35, 3A, 32, 32, 00] 12/005/2015 15:05:22 - INFO - Writing TA unit 00002774. Value : [00] 12/005/2015 15:05:22 - INFO - Closing TA partition 12/005/2015 15:05:22 - INFO - Ending flash session 12/005/2015 15:05:22 - INFO - Flashing finished. 12/005/2015 15:05:22 - INFO - Please unplug and start your phone 12/005/2015 15:05:22 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings |
10-12-2015, 03:16 | #636 (permalink) |
Member: 1339076 Status: Offline Thanks Meter: 30 | try new version diffent error 12/013/2015 15:13:13 - INFO - Flashtool Version 0.9.19.10 built on 04-10-2015 21:00:00 12/013/2015 15:13:13 - INFO - Executing search strategies to find proxy selector 12/013/2015 15:13:13 - INFO - No proxy found for IE. Trying next one 12/013/2015 15:13:13 - INFO - No proxy found for firefox. Trying next one 12/013/2015 15:13:13 - INFO - No proxy found for java. Trying next one 12/013/2015 15:13:13 - INFO - Syncing devices from github 12/013/2015 15:13:13 - INFO - Scanning devices folder for changes. 12/013/2015 15:13:21 - INFO - Pulling changes from github. 12/013/2015 15:13:22 - INFO - Devices sync finished. 12/013/2015 15:13:27 - INFO - Device disconnected 12/013/2015 15:13:52 - INFO - Selected Bundle for Experia E4 model E2104 pattern unlock only. FW release : 1293-1927_24.0.A.5.14_R4A. Customization : _Customized GEL_ 12/013/2015 15:13:52 - INFO - Preparing files for flashing 12/014/2015 15:14:11 - INFO - Please connect your device into flashmode. 12/014/2015 15:14:20 - INFO - Device connected in flash mode 12/014/2015 15:14:21 - INFO - Opening device for R/W 12/014/2015 15:14:22 - INFO - Reading device information 12/014/2015 15:14:22 - INFO - Phone ready for flashmode operations. 12/014/2015 15:14:22 - INFO - Opening TA partition 2 12/014/2015 15:14:22 - INFO - Current device : E2104 - WUJ01HM62Q - 1293-7868_R4A - 1290-6614_24.0.A.3.8 - WORLD-a_24.0.A.3.8 12/014/2015 15:14:22 - INFO - Closing TA partition 12/014/2015 15:14:22 - INFO - Start Flashing 12/014/2015 15:14:22 - INFO - Processing loader.sin 12/014/2015 15:14:22 - INFO - Checking header 12/014/2015 15:14:22 - INFO - Flashing data 12/014/2015 15:14:22 - INFO - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_10 / Bootloader status : ROOTABLE 12/014/2015 15:14:22 - INFO - Max packet size set to 512K 12/014/2015 15:14:22 - INFO - Making a TA backup 12/014/2015 15:14:22 - INFO - Opening TA partition 1 12/014/2015 15:14:22 - INFO - Start Dumping TA partition 1 12/014/2015 15:14:22 - INFO - Finished Dumping TA partition 1 12/014/2015 15:14:22 - INFO - Closing TA partition 12/014/2015 15:14:22 - ERROR - 12/014/2015 15:14:22 - ERROR - Error dumping TA. Aborted 12/014/2015 15:14:22 - INFO - Opening TA partition 2 12/014/2015 15:14:22 - INFO - Start Dumping TA partition 2 |
10-12-2015, 03:16 | #637 (permalink) |
Member: 1339076 Status: Offline Thanks Meter: 30 | e2104 try new version diffent error 12/013/2015 15:13:13 - INFO - Flashtool Version 0.9.19.10 built on 04-10-2015 21:00:00 12/013/2015 15:13:13 - INFO - Executing search strategies to find proxy selector 12/013/2015 15:13:13 - INFO - No proxy found for IE. Trying next one 12/013/2015 15:13:13 - INFO - No proxy found for firefox. Trying next one 12/013/2015 15:13:13 - INFO - No proxy found for java. Trying next one 12/013/2015 15:13:13 - INFO - Syncing devices from github 12/013/2015 15:13:13 - INFO - Scanning devices folder for changes. 12/013/2015 15:13:21 - INFO - Pulling changes from github. 12/013/2015 15:13:22 - INFO - Devices sync finished. 12/013/2015 15:13:27 - INFO - Device disconnected 12/013/2015 15:13:52 - INFO - Selected Bundle for Experia E4 model E2104 pattern unlock only. FW release : 1293-1927_24.0.A.5.14_R4A. Customization : _Customized GEL_ 12/013/2015 15:13:52 - INFO - Preparing files for flashing 12/014/2015 15:14:11 - INFO - Please connect your device into flashmode. 12/014/2015 15:14:20 - INFO - Device connected in flash mode 12/014/2015 15:14:21 - INFO - Opening device for R/W 12/014/2015 15:14:22 - INFO - Reading device information 12/014/2015 15:14:22 - INFO - Phone ready for flashmode operations. 12/014/2015 15:14:22 - INFO - Opening TA partition 2 12/014/2015 15:14:22 - INFO - Current device : E2104 - WUJ01HM62Q - 1293-7868_R4A - 1290-6614_24.0.A.3.8 - WORLD-a_24.0.A.3.8 12/014/2015 15:14:22 - INFO - Closing TA partition 12/014/2015 15:14:22 - INFO - Start Flashing 12/014/2015 15:14:22 - INFO - Processing loader.sin 12/014/2015 15:14:22 - INFO - Checking header 12/014/2015 15:14:22 - INFO - Flashing data 12/014/2015 15:14:22 - INFO - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_10 / Bootloader status : ROOTABLE 12/014/2015 15:14:22 - INFO - Max packet size set to 512K 12/014/2015 15:14:22 - INFO - Making a TA backup 12/014/2015 15:14:22 - INFO - Opening TA partition 1 12/014/2015 15:14:22 - INFO - Start Dumping TA partition 1 12/014/2015 15:14:22 - INFO - Finished Dumping TA partition 1 12/014/2015 15:14:22 - INFO - Closing TA partition 12/014/2015 15:14:22 - ERROR - 12/014/2015 15:14:22 - ERROR - Error dumping TA. Aborted 12/014/2015 15:14:22 - INFO - Opening TA partition 2 12/014/2015 15:14:22 - INFO - Start Dumping TA partition 2 |
10-12-2015, 15:59 | #639 (permalink) |
Junior Member Join Date: Nov 2014 Location: india Age: 35
Member: 2289488 Status: Offline Thanks Meter: 6 | Plzzzz upload E4 E2115 kitkat version unlock ftf file..... Which uploaded on server is not work on new version.... Got error which najeebsalam got error in E2104. Or is there other solution. To fullfill this error |
10-13-2015, 12:40 | #641 (permalink) | |
Member: 2289488 Status: Offline Thanks Meter: 6 | Quote:
Where is Jamesjerrs Sir...... V All NeeD ur help.....??? | |
10-13-2015, 12:44 | #642 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Will upload new files | |
10-13-2015, 12:56 | #643 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | New files Uploaded Today Use Latest Version Flash Tool (0.9.19.10) Xperia C5 Ultra Dual E5533,E5563 lock remove.ftf Xperia M5 Dual E5633,E5663E,E5643 lock remove.ftf Xperia M5 E5603,E5653,E5606 lock remove.ftf Xperia Z5 Dual E6633,E6683 lock remove.ftf Xperia Z5 E6603,E6653 lock remove.ftf Xperia Z5 Compact E5803,E5823 lock remove.ftf |
The Following 3 Users Say Thank You to jamesjerss For This Useful Post: |
10-13-2015, 14:25 | #644 (permalink) |
Banned Join Date: Jun 2014
Member: 2209517 Status: Offline Thanks Meter: 134 | add ling easy-firmware.com REMOVE LOCK SCREEN | Easy Firmware |
The Following User Says Thank You to h11kurd For This Useful Post: |
10-13-2015, 15:29 | #645 (permalink) | |
Thanx for reply ... I alreadt using latest version thn also i got same error... I m not confrm but i think.its a file version issue.... Can.u plzzz provide the unlock ftf of E2115 kitkat latest version file..... Which u have uploaded thts a old ver. Thnx in.advance | |
