Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
01-14-2016, 15:23 | #721 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA BHUBANESWAR
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | 4/050/2016 19:50:49 - INFO - Start Dumping TA partition 1 14/050/2016 19:50:50 - INFO - Finished Dumping TA partition 1 14/050/2016 19:50:50 - INFO - TA partition 1 saved to C:\Documents and Settings\Administrator\.flashTool\registeredDevice s\WUJ01KMCLY\s1ta\2016-01-14_07-50-49\1.ta 14/050/2016 19:50:50 - INFO - Closing TA partition 14/050/2016 19:50:50 - INFO - Opening TA partition 2 14/050/2016 19:50:50 - INFO - Start Dumping TA partition 2 14/050/2016 19:50:50 - INFO - Finished Dumping TA partition 2 14/050/2016 19:50:50 - INFO - TA partition 2 saved to C:\Documents and Settings\Administrator\.flashTool\registeredDevice s\WUJ01KMCLY\s1ta\2016-01-14_07-50-49\2.ta 14/050/2016 19:50:50 - INFO - Closing TA partition 14/050/2016 19:50:50 - INFO - No flash script found. Using 0.9.18 flash engine 14/050/2016 19:50:50 - INFO - Opening TA partition 2 14/050/2016 19:50:50 - INFO - Writing TA unit 00002774. Value : [01] 14/050/2016 19:50:50 - INFO - Closing TA partition 14/050/2016 19:50:50 - INFO - Opening TA partition 2 14/050/2016 19:50:50 - INFO - Closing TA partition 14/050/2016 19:50:50 - INFO - Opening TA partition 2 14/050/2016 19:50:50 - INFO - Closing TA partition 14/050/2016 19:50:50 - INFO - Opening TA partition 2 14/050/2016 19:50:51 - INFO - Closing TA partition 14/050/2016 19:50:51 - INFO - Opening TA partition 2 14/050/2016 19:50:51 - INFO - Closing TA partition 14/050/2016 19:50:51 - INFO - Opening TA partition 2 14/050/2016 19:50:51 - INFO - Closing TA partition 14/050/2016 19:50:51 - INFO - Opening TA partition 2 14/050/2016 19:50:51 - INFO - Writing TA unit 00002725. Value : [32, 30, 31, 36, 2D, 30, 31, 2D, 31, 34, 20, 31, 39, 3A, 35, 30, 3A, 35, 31, 00] 14/050/2016 19:50:51 - INFO - Writing TA unit 00002774. Value : [00] 14/050/2016 19:50:51 - INFO - Closing TA partition 14/050/2016 19:50:51 - INFO - Ending flash session 14/050/2016 19:50:51 - INFO - Flashing finished. 14/050/2016 19:50:51 - INFO - Please unplug and start your phone 14/050/2016 19:50:51 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 14/050/2016 19:50:52 - INFO - Device connected in flash mode 14/050/2016 19:50:57 - INFO - Device disconnected |
01-14-2016, 16:07 | #722 (permalink) | |
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | Quote:
5/041/2016 21:41:23 - INFO - Opening TA partition 2 15/041/2016 21:41:24 - INFO - Processing userdata.sin 15/041/2016 21:41:24 - INFO - Checking header 15/041/2016 21:41:24 - INFO - Flashing data 15/041/2016 21:41:25 - ERROR - Processing of userdata.sin finished with errors. 15/041/2016 21:41:25 - INFO - Ending flash session 15/041/2016 21:41:55 - ERROR - 87 : The parameter is incorrect. 15/041/2016 21:41:55 - ERROR - Error flashing. Aborted 15/041/2016 21:41:55 - INFO - Flashing finished. 15/041/2016 21:41:55 - INFO - Please unplug and start your phone 15/041/2016 21:41:55 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 15/041/2016 21:41:56 - INFO - Device disconnected | |
01-14-2016, 16:19 | #723 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Hi, have read here: Quote:
BR allumts | |
01-25-2016, 08:26 | #731 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | SONY XPERIA E4 (E2105) - Android firmware + Lock Remove Here is Full Firmware E2105_24.0.A.5.14_R5A_Customized GR.ftf Here is Lock Remove E2105_24.0.A.5.14_R5A_Lock Remover.ftf Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
The Following 5 Users Say Thank You to gsm_masud7 For This Useful Post: |
01-25-2016, 09:29 | #733 (permalink) |
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | fast post have this lock remove FTF file http://forum.gsmhosting.com/vbb/f778...015-a-1872872/ your lock remover file Xperia_E4_Dual_E2115_240B38_R5 credit : jamesjerss Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
The Following User Says Thank You to gsm_masud7 For This Useful Post: |
