Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
01-28-2016, 20:08 | #736 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Xperia Z5 E6603,E6653 lock remove.ftf | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
01-31-2016, 20:17 | #739 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | Sony Xperia M4 (E2303) Aqua Lock Remover & Full FTF Firmware Here is Lock Remove FTF E2303_261A2119_R3A_Lock_Remove Here is Full Firmware FTF E2303_26.1.A.2.119_R3A_Service Exchange Unit Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
The Following User Says Thank You to gsm_masud7 For This Useful Post: |
02-06-2016, 09:27 | #741 (permalink) |
Freak Poster Join Date: Sep 2015 Location: Sri Lanka
Member: 2459395 Status: Offline Thanks Meter: 53 | Sony C4 (E5333) Pattern Lock Done 01.Make sure the battery fully charge 02.Do not forget to backup all important data 03.Turn off the SONY XPERIA C4 (DUAL) 04.Press and Hold together: Power Button + Volume Up Button for several seconds 05.Follow the menu at LCD screen to continue the hard reset SONY XPERIA C4 (DUAL) https://www.youtube.com/watch?v=jSkqaK3ZWb8 Last edited by danilaperera; 02-06-2016 at 09:33. |
02-13-2016, 07:37 | #745 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Online Thanks Meter: 311 | c1904 given error 13/032/2016 11:32:02 - INFO - <- This level is successfully initialized 13/032/2016 11:32:02 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00 13/032/2016 11:32:06 - INFO - Device disconnected 13/036/2016 11:36:15 - ERROR - Drivers need to be installed for connected device. 13/036/2016 11:36:15 - ERROR - You can find them in the drivers folder of Flashtool. 13/036/2016 11:36:21 - INFO - Device connected with USB debugging off 13/036/2016 11:36:21 - INFO - For 2011 devices line, be sure you are not in MTP mode 13/036/2016 11:36:58 - INFO - Selected null 13/036/2016 11:36:58 - INFO - Flash canceled 13/037/2016 11:37:21 - ERROR - Drivers need to be installed for connected device. 13/037/2016 11:37:21 - ERROR - You can find them in the drivers folder of Flashtool. 13/037/2016 11:37:24 - INFO - Device connected with USB debugging off 13/037/2016 11:37:24 - INFO - For 2011 devices line, be sure you are not in MTP mode 13/037/2016 11:37:53 - INFO - Selected null 13/037/2016 11:37:53 - INFO - Flash canceled 13/038/2016 11:38:27 - ERROR - Drivers need to be installed for connected device. 13/038/2016 11:38:27 - ERROR - You can find them in the drivers folder of Flashtool. 13/038/2016 11:38:31 - INFO - Device connected with USB debugging off 13/038/2016 11:38:31 - INFO - For 2011 devices line, be sure you are not in MTP mode 13/039/2016 11:39:09 - ERROR - Drivers need to be installed for connected device. 13/039/2016 11:39:09 - ERROR - You can find them in the drivers folder of Flashtool. 13/039/2016 11:39:12 - INFO - Device connected with USB debugging off 13/039/2016 11:39:12 - INFO - For 2011 devices line, be sure you are not in MTP mode 13/040/2016 11:40:14 - ERROR - Drivers need to be installed for connected device. 13/040/2016 11:40:14 - ERROR - You can find them in the drivers folder of Flashtool. 13/040/2016 11:40:18 - INFO - Device connected with USB debugging off 13/040/2016 11:40:18 - INFO - For 2011 devices line, be sure you are not in MTP mode 13/041/2016 11:41:08 - INFO - Device disconnected 13/056/2016 11:56:51 - INFO - Selected null 13/056/2016 11:56:51 - INFO - Flash canceled 13/057/2016 11:57:12 - INFO - Selected Xperia M C1904 / 15.4.A.1.9 / lock remove 13/057/2016 11:57:12 - INFO - Preparing files for flashing 13/057/2016 11:57:18 - INFO - Please connect your device into flashmode. 13/057/2016 11:57:20 - INFO - Device connected in flash mode 13/057/2016 11:57:20 - INFO - Opening device for R/W 13/057/2016 11:57:20 - INFO - Start Flashing 13/057/2016 11:57:20 - INFO - Processing loader.sin 13/057/2016 11:57:20 - INFO - Checking header 13/057/2016 11:57:20 - INFO - Ending flash session 13/057/2016 11:57:20 - ERROR - 13/057/2016 11:57:20 - ERROR - Error flashing. Aborted 13/057/2016 11:57:20 - INFO - Device connected in flash mode 13/057/2016 11:57:36 - INFO - Selected Xperia M C1904 / 15.4.A.1.9 / lock remove 13/057/2016 11:57:36 - INFO - Preparing files for flashing 13/057/2016 11:57:39 - INFO - Please connect your device into flashmode. 13/057/2016 11:57:40 - INFO - Opening device for R/W 13/057/2016 11:57:40 - INFO - Reading device information 13/057/2016 11:57:40 - INFO - Phone ready for flashmode operations. 13/057/2016 11:57:41 - INFO - Current device : C1904 - YT910LGHMG - 1274-3899_R4C - 1272-2325_15.4.A.1.9 - WORLD-a_15.4.A.1.9 13/057/2016 11:57:41 - INFO - Start Flashing 13/057/2016 11:57:41 - INFO - Processing loader.sin 13/057/2016 11:57:41 - INFO - Checking header 13/057/2016 11:57:41 - INFO - Flashing data 13/057/2016 11:57:41 - INFO - Loader : S1_Root_dbe9 - Version : loader_MSM8X30_10 / Boot version : S1_Boot_MSM_8227_5 / Bootloader status : ROOTABLE 13/057/2016 11:57:44 - INFO - Processing userdata.sin 13/057/2016 11:57:44 - INFO - Checking header 13/057/2016 11:57:44 - INFO - Flashing data 13/057/2016 11:57:47 - INFO - Ending flash session 13/057/2016 11:57:47 - ERROR - ERR_SEVERITY="MINOR";ERR_CODE="0017";ERR_DYNAMIC=" 0x8020001C "; 13/057/2016 11:57:47 - ERROR - Error flashing. Aborted 13/057/2016 11:57:47 - INFO - Device connected in flash mode 13/057/2016 11:57:49 - INFO - Device disconnected 13/003/2016 12:03:24 - INFO - Selected Xperia M C1904 / 15.4.A.1.9 / lock remove 13/003/2016 12:03:24 - INFO - Preparing files for flashing 13/003/2016 12:03:32 - INFO - Please connect your device into flashmode. 13/004/2016 12:04:48 - INFO - Device connected in flash mode 13/004/2016 12:04:48 - INFO - Opening device for R/W 13/004/2016 12:04:48 - INFO - Reading device information 13/004/2016 12:04:48 - INFO - Phone ready for flashmode operations. 13/004/2016 12:04:48 - INFO - Current device : C1904 - YT910LGHMG - 1274-3899_R4C - 1272-2325_15.4.A.1.9 - WORLD-a_15.4.A.1.9 13/004/2016 12:04:48 - INFO - Start Flashing 13/004/2016 12:04:48 - INFO - Processing loader.sin 13/004/2016 12:04:48 - INFO - Checking header 13/004/2016 12:04:48 - INFO - Flashing data 13/004/2016 12:04:49 - INFO - Loader : S1_Root_dbe9 - Version : loader_MSM8X30_10 / Boot version : S1_Boot_MSM_8227_5 / Bootloader status : ROOTABLE 13/004/2016 12:04:49 - INFO - Processing userdata.sin 13/004/2016 12:04:49 - INFO - Checking header 13/004/2016 12:04:49 - INFO - Flashing data 13/004/2016 12:04:49 - INFO - Ending flash session 13/004/2016 12:04:49 - ERROR - ERR_SEVERITY="MINOR";ERR_CODE="0017";ERR_DYNAMIC=" 0x8020001C "; 13/004/2016 12:04:49 - ERROR - Error flashing. Aborted 13/004/2016 12:04:49 - INFO - Device connected in flash mode 13/004/2016 12:04:51 - INFO - Device disconnected 13/005/2016 12:05:03 - ERROR - Drivers need to be installed for connected device. 13/005/2016 12:05:03 - ERROR - You can find them in the drivers folder of Flashtool. 13/005/2016 12:05:09 - INFO - Device connected with USB debugging off 13/005/2016 12:05:09 - INFO - For 2011 devices line, be sure you are not in MTP mode |
02-16-2016, 09:06 | #749 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Delhi Age: 37
Member: 1511197 Status: Offline Thanks Meter: 17 | xpfrifirm download a file for creat ftf xpfrifirm download a file for creat ftf below left corner of xprifirm unpack autometily this option tick or untick |
02-20-2016, 09:31 | #750 (permalink) |
No Life Poster Join Date: May 2008 Location: shimoga Age: 40
Member: 781262 Status: Offline Thanks Meter: 90 | Whats the problem that was i am doing please suggest me how to [/U][/U] 20/050/2016 13:50:34 - INFO - Flashtool Version 0.9.19.10 built on 04-10-2015 21:00:00 20/050/2016 13:50:34 - INFO - Executing search strategies to find proxy selector 20/050/2016 13:50:34 - INFO - No proxy found for IE. Trying next one 20/050/2016 13:50:34 - INFO - No proxy found for firefox. Trying next one 20/050/2016 13:50:34 - INFO - No proxy found for java. Trying next one 20/050/2016 13:50:35 - INFO - Syncing devices from github 20/050/2016 13:50:35 - INFO - Scanning devices folder for changes. 20/051/2016 13:51:01 - INFO - Pulling changes from github. 20/051/2016 13:51:02 - INFO - Devices sync finished. 20/051/2016 13:51:08 - INFO - Device disconnected 20/051/2016 13:51:50 - INFO - Selected Bundle for Sony Xperia E4 (E2115). FW release : 24.0.B.5.14. Customization : Customized IN 20/051/2016 13:51:50 - INFO - Preparing files for flashing 20/051/2016 13:51:51 - INFO - Please connect your device into flashmode. 20/056/2016 13:56:42 - INFO - Device connected in flash mode 20/056/2016 13:56:42 - INFO - Opening device for R/W 20/056/2016 13:56:42 - INFO - Reading device information 20/056/2016 13:56:42 - INFO - Phone ready for flashmode operations. 20/056/2016 13:56:42 - INFO - Opening TA partition 2 20/056/2016 13:56:43 - INFO - Current device : E2115 - WUJ01GTV3V - 1299-1708_R1A - 1290-6611_24.0.B.5.17 - WORLD-i_24.0.B.5.17 20/056/2016 13:56:43 - INFO - Closing TA partition 20/056/2016 13:56:43 - INFO - Start Flashing 20/056/2016 13:56:43 - INFO - Processing loader.sin 20/056/2016 13:56:43 - INFO - Checking header 20/056/2016 13:56:43 - INFO - Flashing data 20/056/2016 13:56:43 - INFO - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_11 / Bootloader status : ROOTABLE 20/056/2016 13:56:43 - INFO - Max packet size set to 512K 20/056/2016 13:56:43 - INFO - Making a TA backup 20/056/2016 13:56:43 - INFO - Opening TA partition 1 20/056/2016 13:56:43 - INFO - Start Dumping TA partition 1 20/056/2016 13:56:43 - INFO - Finished Dumping TA partition 1 20/056/2016 13:56:43 - INFO - Closing TA partition 20/056/2016 13:56:43 - ERROR - 20/056/2016 13:56:43 - ERROR - Error dumping TA. Aborted 20/056/2016 13:56:43 - INFO - Opening TA partition 2 20/056/2016 13:56:43 - INFO - Start Dumping TA partition 2 20/056/2016 13:56:43 - INFO - Finished Dumping TA partition 2 20/056/2016 13:56:43 - INFO - TA partition 2 saved to C:\Users\Taieeb\.flashTool\registeredDevices\WUJ01 GTV3V\s1ta\2016-02-20_01-56-43\2.ta 20/056/2016 13:56:43 - INFO - Closing TA partition 20/056/2016 13:56:48 - INFO - Found a template session. Using it : C:\Users\Taieeb\.flashTool\devices\E21XX\default.f sc 20/056/2016 13:56:48 - INFO - Opening TA partition 2 20/056/2016 13:56:48 - INFO - Writing TA unit 00002774. Value : [01] 20/056/2016 13:56:48 - INFO - Closing TA partition 20/056/2016 13:56:48 - WARN - partition is excluded from bundle 20/056/2016 13:56:48 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 01] 20/056/2016 13:56:48 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 03] 20/056/2016 13:56:48 - WARN - preloader_s1sbl is excluded from bundle 20/056/2016 13:56:48 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 01] 20/056/2016 13:56:48 - WARN - secro is excluded from bundle 20/056/2016 13:56:48 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 00] 20/056/2016 13:56:48 - INFO - Opening TA partition 2 20/056/2016 13:56:48 - WARN - cache is excluded from bundle 20/056/2016 13:56:48 - INFO - Flashing finished. 20/056/2016 13:56:48 - INFO - Please unplug and start your phone 20/056/2016 13:56:48 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings |
