Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 06-08-2016, 13:23   #811 (permalink)
gsm_masud7's Avatar
Member: 2102992
Sonork: 100.1626305
Thanks Meter: 2,763
Originally Posted by hans salim View Post
Help spg321 tft lock remove ??
check fast post how to create lock remove FTF , i thank you can do , here easy method anyone do this ,jamesjerss sir also post tutorial
http://forum.gsmhosting.com/vbb/f778...015-a-1872872/
Don't forget to press Thanks Button
Read The Rules Careful HERE
M@SUD
Old 06-10-2016, 17:46   #812 (permalink)
Member: 2435816
Talking
Thanks! I've been looking for this and finally found it. Now I can resurrect my long time ago lost friend, Xperia play!
Rock on!
Old 06-12-2016, 13:15   #813 (permalink)
munavar's Avatar
Member: 1773503
Sonork: 100.1637046
Thanks Meter: 88
need help pls share link for sony c6833 lock remove ftf file
Old 06-12-2016, 13:39   #814 (permalink)
Member: 2139605
Thanks Meter: 31
Sony E2115 pattten rest erree
12/031/2016 17:31:41 - INFO - Flashtool Version 0.9.20.0 built on 04-10-2015 21:00:00
12/031/2016 17:31:41 - INFO - Executing search strategies to find proxy selector
12/031/2016 17:31:41 - INFO - No proxy found for IE. Trying next one
12/031/2016 17:31:41 - INFO - Strategy firefox failed trying next one : No Firefox installation found
12/031/2016 17:31:41 - INFO - No proxy found for java. Trying next one
12/031/2016 17:31:41 - INFO - Syncing devices from github
12/031/2016 17:31:41 - INFO - Opening devices repository.
12/031/2016 17:31:41 - INFO - Scanning devices folder for changes.
12/031/2016 17:31:54 - INFO - Pulling changes from github.
12/031/2016 17:31:57 - INFO - Quietly closing devices repository.
12/031/2016 17:31:57 - INFO - Devices sync finished.
12/031/2016 17:31:57 - INFO - Loading devices database
12/031/2016 17:31:57 - ERROR - root : this bundle is not valid
12/031/2016 17:31:57 - INFO - Loaded 91 devices
12/031/2016 17:31:57 - INFO - Starting phone detection
12/032/2016 17:32:01 - INFO - Device disconnected
12/033/2016 17:33:11 - INFO - Selected Bundle for Sony Xperia E4(E2115). FW release : 24.0.B.5.14. Customization : Customized MEA
12/033/2016 17:33:11 - INFO - Preparing files for flashing
12/033/2016 17:33:12 - INFO - Device connected in flash mode
12/033/2016 17:33:30 - INFO - Device disconnected
12/033/2016 17:33:44 - INFO - Device connected with USB debugging off
12/033/2016 17:33:44 - INFO - For 2011 devices line, be sure you are not in MTP mode
12/033/2016 17:33:46 - INFO - Please connect your device into flashmode.
12/034/2016 17:34:20 - INFO - Device disconnected
12/034/2016 17:34:22 - INFO - Device connected in flash mode
12/034/2016 17:34:23 - INFO - Opening device for R/W
12/034/2016 17:34:23 - INFO - Reading device information
12/034/2016 17:34:23 - INFO - Phone ready for flashmode operations.
12/034/2016 17:34:23 - INFO - Opening TA partition 2
12/034/2016 17:34:23 - INFO - Current device : E2115 - WUJ01HFMLL - 1293-2971_R3A - 1290-6611_24.0.B.5.14 - WORLD-i_24.0.B.5.14
12/034/2016 17:34:23 - INFO - Closing TA partition
12/034/2016 17:34:23 - INFO - Start Flashing
12/034/2016 17:34:23 - INFO - Processing loader.sin
12/034/2016 17:34:23 - INFO - Checking header
12/034/2016 17:34:23 - INFO - Flashing data
12/034/2016 17:34:23 - INFO - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_11 / Bootloader status : ROOTABLE
12/034/2016 17:34:23 - INFO - Max packet size set to 524288K
12/034/2016 17:34:23 - INFO - USB buffer size set to 524288K
12/034/2016 17:34:26 - INFO - Found a template session. Using it : C:\Users\zia\.flashTool\firmwares\firmwares\device s\E21XX\default.fsc
12/034/2016 17:34:26 - INFO - Opening TA partition 2
12/034/2016 17:34:26 - INFO - Writing TA unit 00002774. Value : 01
12/034/2016 17:34:26 - INFO - Closing TA partition
12/034/2016 17:34:26 - INFO - Processing partition.sin
12/034/2016 17:34:26 - INFO - Checking header
12/034/2016 17:34:26 - INFO - Flashing data
12/034/2016 17:34:26 - INFO - Set loader configuration : [00 01 00 00 00 01]
12/034/2016 17:34:26 - INFO - Set loader configuration : [00 01 00 00 00 03]
12/034/2016 17:34:26 - INFO - Flashing finished.
12/034/2016 17:34:26 - INFO - Please unplug and start your phone
12/034/2016 17:34:26 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
Old 06-12-2016, 13:57   #815 (permalink)
Member: 2139605
Thanks Meter: 31
sony E2115 pattren rest ERROR
Old 06-12-2016, 21:53   #816 (permalink)
gsm_masud7's Avatar
Member: 2102992
Sonork: 100.1626305
Thanks Meter: 2,763
@ziakpk us latest version flashtool
Download Link
M@SUD
Old 06-16-2016, 09:52   #817 (permalink)
Member: 2197465
Sonork: none
Thanks Meter: 7
e6653 ftf upload pls,,,,,,,,,,,,,,,,,,,,,
Old 06-20-2016, 08:19   #818 (permalink)
Member: 2584310
Thanks Meter: 2
jamesjers bro i need sony e4 E2115 lock remove file
i cant flash lock remove file and sony companion and xperia companion plss give me solution thanx in advance
Old 06-20-2016, 08:39   #819 (permalink)
Member: 2585111
Thanks Meter: 22
d5503 4.3 ftf link plz
Old 06-20-2016, 08:51   #820 (permalink)
Member: 2584310
Thanks Meter: 2
how to remove pattern sony e2115 plss help
Old 06-20-2016, 12:46   #821 (permalink)
gsm_masud7's Avatar
Member: 2102992
Sonork: 100.1626305
Thanks Meter: 2,763
hi check 1st post here have guide ,create own FTF file easily
you can us full FTF file
1st try to flash with lock remove FTF file ,if not work flash yur device full
M@SUD
Old 06-21-2016, 16:49   #822 (permalink)
Member: 1981875
Thanks Meter: 63
Xperia E3 D2203 Lock Remove.ftf file credit: bimes
i no see plesae share this.
Old 06-21-2016, 17:09   #823 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
Hard Reset SONY Xperia J1 Compact D5788
ftf file plees
Old 06-21-2016, 22:34   #824 (permalink)
gsm_masud7's Avatar
Member: 2102992
Sonork: 100.1626305
Thanks Meter: 2,763
ftf file plees
here is yur full flash file,flash it
D5788_14.4.C.0.136_1296-4381_R4C_Rakuten_Mobile_JP_(MVNO).ftf
M@SUD
Old 06-24-2016, 11:12   #825 (permalink)
Member: 1993709
Sonork: 100.1644971
Thanks Meter: 8
sony e6553 lock removal ftf file help me
Page generated in 0.56243 seconds with 8 queries
