Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
11-05-2014, 17:11 | #61 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
After create flash usng same tool. press volume down key nd cnnt usb to flash yur mob | |
11-07-2014, 14:55 | #71 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | need lock remove file sk17i i have create SK17i_4.1.B.0.587_lock remove.ftf siz 111 kb i try flashing sony flash tool showing this 07/024/2014 19:24:10 - INFO - <- This level is successfully initialized 07/024/2014 19:24:10 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00 07/024/2014 19:24:15 - INFO - Device disconnected 07/024/2014 19:24:18 - INFO - Selected SK17i / 4.1.B.0.587 / lock remove 07/024/2014 19:24:18 - INFO - Preparing files for flashing 07/024/2014 19:24:18 - INFO - Please connect your device into flashmode. 07/024/2014 19:24:24 - INFO - Device connected in flash mode 07/025/2014 19:25:04 - INFO - Device disconnected any version 1} Flashtool Version 0.9.11.0 built 2} flashtool-0.9.13.0-windows_2 3} flashtool-0.9.18.1-windows 4} flashtool-0.9.18.3-windows but not successes device power on not flashing |
11-07-2014, 19:55 | #72 (permalink) | |
11-07-2014, 20:54 | #73 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | sony d6503 remove screen lock remove screen lock test by me Download link...... D6503_17.1.2.A.0.314_R4A_Customized MEA2 best solution........ Br gsm_masud7 |
11-07-2014, 22:04 | #74 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | REQUIREMENTS: + Windows XP SP2 or newer! + Microsoft .NET Framework 3.5 or newer! + Flashtool* OR Java Runtime Environment 8: --- for Windows 32-bit: Download Java Runtime Environment 8.0 build 25 (32-bit) - FileHippo.com --- for Windows 64-bit: Download Java Runtime Environment 8.0 build 25 (64-bit) - FileHippo.com * If you have Flashtool installed, Java Runtime is bundled with it and doesn't have to be installed separately. Just extract XperiFirm's files to Flashtool's folder and run XperiFirm.exe from there. (See screenshot below) * For Windows 8 or 8.1 users: If you want to run XperiFirm without installing any old .NET Framework, make sure you also extract "XperiFirm.exe.config" to the same folder XperiFirm.exe is located. [Thanks to aphanic for pointing out this Windows 8 issue] CHANGELOG: v3.0b [November 07, 2014]: - MINOR: Fixed some annoying visual glitches. v3.0a [November 07, 2014]: - FIX: Fixed a crash caused by some missing files on Sony servers that messed up with column ordering by Latest Release. (this happens when Sony just begins to roll an update, it's a big mess of missing files, you'll just need to wait patiently until Sony finishes uploading their updates). v3.0 [November 07, 2014]: - ATTENTION: XperiFirm now targets .NET Framework 3.5 or later to enable some of the newer features! - NEW: Total UI re-make. More information about each device (like project/code name). Easier to navigate then ever before. Many levels above any other firmware downloading tool. - NEW: XperiFirm.jar is being self-extracted when you launch XperiFirm.exe. It is being always validated to be the correct file and recreated if it was modified or damaged. - NEW: Smart downloading: Dummy files are not downloaded. Each file gets a name by analyzing data received from Sony. - NEW: Smart auto-decryption ability, that uses online data to correctly unpack the firmware and prepare it for FTF creating in Flashtool. - NEW: Smart sorting for both "Market" and "Operator", for finding your firmware easily. - NEW: Smart release version checking: Only empty "Latest Release" fields will be checked when using "Check All". - NEW: Smarter error handling. - NEW: Added support for multiple simultaneous downloads. - NEW: Added the ability to copy the raw download links of a firmware to the clipboard. Use however you want and at your own risk! - NEW: Each and every device is being recognized exactly as marketed by Sony all around the UI, including devices that are merely variants of the same device. - NEW: The download folder will always have a unique name (adding "(#)" instead of overwriting). - NEW: The date of the latest update to the device list or any of the CDF lists will be displayed below the device list. - NEW: A cool sound will notify you when a firmware finishes downloading and/or unpacking. - FIX: Fixed a bug that broke the scrollbars of the CDF list when minimizing the window. - DONATE: A nice looking donation button was added, please use it to support me! Download XperiFirm_3.0b_(by_IaguCool).zip 183 KB https://mega.co.nz/#!i4J3zQqR!aIREWI...rDgs28eCPRQr-M |
