Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 10-10-2015, 01:40   #631 (permalink)
Member: 1339076
Thanks Meter: 30
pls help sony e2104 unlock error
10/037/2015 13:37:09 - INFO - <- This level is successfully initialized
10/037/2015 13:37:09 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00
10/037/2015 13:37:11 - INFO - Device disconnected
10/037/2015 13:37:20 - INFO - Selected Experia E4 model E2104 pattern unlock only / 1293-1927_24.0.A.5.14_R4A / _Customized GEL_
10/037/2015 13:37:20 - INFO - Preparing files for flashing
10/037/2015 13:37:56 - INFO - Please connect your device into flashmode.
10/038/2015 13:38:06 - INFO - Device connected in flash mode
10/038/2015 13:38:07 - INFO - Opening device for R/W
10/038/2015 13:38:08 - INFO - Device connected in flash mode
10/038/2015 13:38:08 - INFO - Reading device information
10/038/2015 13:38:08 - INFO - Start Flashing
10/038/2015 13:38:08 - INFO - Processing loader.sin
10/038/2015 13:38:08 - INFO - Checking header
10/038/2015 13:38:08 - INFO - Ending flash session
10/038/2015 13:38:08 - ERROR - Error in processHeader : Read error :31 : A device attached to the system is not functioning.
10/038/2015 13:38:08 - ERROR - Error flashing. Aborted
10/038/2015 13:38:09 - INFO - Device connected in flash mode
10/038/2015 13:38:17 - INFO - Device disconnected
Old 10-10-2015, 07:42   #632 (permalink)
Member: 564909
Sonork: 1594465
Thanks Meter: 37
i need expira z2 d6503 tft file plz help
Old 10-10-2015, 09:02   #633 (permalink)
Member: 564909
Sonork: 1594465
Thanks Meter: 37
plz upload z2 d6503 tft file
Old 10-11-2015, 18:05   #634 (permalink)
Member: 228420
Thanks Meter: 3
sony t2 ultra
d5303 lock remove ftf file
plz
Old 10-12-2015, 03:11   #635 (permalink)
Member: 1339076
Thanks Meter: 30
sony e2104 flash but pattern lock cant remove
12/004/2015 15:04:41 - INFO - Flashtool Version 0.9.19.0 built on 29-07-2015 12:00:00
12/004/2015 15:04:41 - INFO - Executing search strategies to find proxy selector
12/004/2015 15:04:42 - INFO - No proxy found for IE. Trying next one
12/004/2015 15:04:43 - INFO - No proxy found for firefox. Trying next one
12/004/2015 15:04:43 - INFO - No proxy found for java. Trying next one
12/004/2015 15:04:43 - INFO - Syncing devices from github
12/004/2015 15:04:44 - INFO - Scanning devices folder for changes.
12/004/2015 15:04:57 - INFO - Pulling changes from github.
12/004/2015 15:04:59 - INFO - Devices sync finished.
12/005/2015 15:05:04 - INFO - Device disconnected
12/005/2015 15:05:08 - INFO - Selected Bundle for Experia E4 model E2104 pattern unlock only. FW release : 1293-1927_24.0.A.5.14_R4A. Customization : _Customized GEL_
12/005/2015 15:05:08 - INFO - Preparing files for flashing
12/005/2015 15:05:08 - INFO - Please connect your device into flashmode.
12/005/2015 15:05:19 - INFO - Device connected in flash mode
12/005/2015 15:05:20 - INFO - Opening device for R/W
12/005/2015 15:05:21 - INFO - Device connected in flash mode
12/005/2015 15:05:21 - INFO - Reading device information
12/005/2015 15:05:21 - INFO - Phone ready for flashmode operations.
12/005/2015 15:05:21 - INFO - Opening TA partition 2
12/005/2015 15:05:21 - INFO - Current device : E2104 - WUJ01HM62Q - 1293-7868_R4A - 1290-6614_24.0.A.3.8 - WORLD-a_24.0.A.3.8
12/005/2015 15:05:21 - INFO - Closing TA partition
12/005/2015 15:05:21 - INFO - Start Flashing
12/005/2015 15:05:21 - INFO - Processing loader.sin
12/005/2015 15:05:21 - INFO - Checking header
12/005/2015 15:05:21 - INFO - Flashing data
12/005/2015 15:05:21 - INFO - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_10 / Bootloader status : ROOTABLE
12/005/2015 15:05:21 - INFO - Transfer buffer size : 262144
12/005/2015 15:05:21 - INFO - Found a template session. Using it : C:\Documents and Settings\lords\.flashTool\devices\E21XX\default.fs c
12/005/2015 15:05:21 - INFO - Writing TA unit 00002774. Value : [01]
12/005/2015 15:05:21 - WARN - partition is excluded from bundle
12/005/2015 15:05:21 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 01]
12/005/2015 15:05:21 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 03]
12/005/2015 15:05:21 - WARN - preloader_s1sbl is excluded from bundle
12/005/2015 15:05:21 - WARN - secro is excluded from bundle
12/005/2015 15:05:21 - INFO - Set loader configuration : [00, 01, 00, 00, 00, 00]
12/005/2015 15:05:21 - WARN - cache is excluded from bundle
12/005/2015 15:05:21 - WARN - apps_log is excluded from bundle
12/005/2015 15:05:21 - WARN - lk is excluded from bundle
12/005/2015 15:05:21 - WARN - EBR1 is excluded from bundle
12/005/2015 15:05:21 - WARN - EBR2 is excluded from bundle
12/005/2015 15:05:21 - WARN - logo is excluded from bundle
12/005/2015 15:05:21 - WARN - MBR is excluded from bundle
12/005/2015 15:05:21 - WARN - boot is excluded from bundle
12/005/2015 15:05:21 - WARN - fotakernel is excluded from bundle
12/005/2015 15:05:21 - WARN - tee1 is excluded from bundle
12/005/2015 15:05:21 - WARN - tee2 is excluded from bundle
12/005/2015 15:05:22 - INFO - Closing TA partition
12/005/2015 15:05:22 - INFO - Opening TA partition 2
12/005/2015 15:05:22 - WARN - Unit 2127 not found in bundle
12/005/2015 15:05:22 - WARN - Unit 2301 not found in bundle
12/005/2015 15:05:22 - WARN - system is excluded from bundle
12/005/2015 15:05:22 - WARN - userdata is excluded from bundle
12/005/2015 15:05:22 - WARN - Unit 2212 not found in bundle
12/005/2015 15:05:22 - WARN - elabel is excluded from bundle
12/005/2015 15:05:22 - INFO - Writing TA unit 00002725. Value : [32, 30, 31, 35, 2D, 31, 30, 2D, 31, 32, 20, 31, 35, 3A, 30, 35, 3A, 32, 32, 00]
12/005/2015 15:05:22 - INFO - Writing TA unit 00002774. Value : [00]
12/005/2015 15:05:22 - INFO - Ending flash session
12/005/2015 15:05:22 - INFO - Flashing finished.
12/005/2015 15:05:22 - INFO - Please unplug and start your phone
12/005/2015 15:05:22 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
Old 10-12-2015, 03:16   #636 (permalink)
Member: 1339076
Thanks Meter: 30
try new version diffent error
12/013/2015 15:13:13 - INFO - Flashtool Version 0.9.19.10 built on 04-10-2015 21:00:00
12/013/2015 15:13:13 - INFO - Executing search strategies to find proxy selector
12/013/2015 15:13:13 - INFO - No proxy found for IE. Trying next one
12/013/2015 15:13:13 - INFO - No proxy found for firefox. Trying next one
12/013/2015 15:13:13 - INFO - No proxy found for java. Trying next one
12/013/2015 15:13:13 - INFO - Syncing devices from github
12/013/2015 15:13:13 - INFO - Scanning devices folder for changes.
12/013/2015 15:13:21 - INFO - Pulling changes from github.
12/013/2015 15:13:22 - INFO - Devices sync finished.
12/013/2015 15:13:27 - INFO - Device disconnected
12/013/2015 15:13:52 - INFO - Selected Bundle for Experia E4 model E2104 pattern unlock only. FW release : 1293-1927_24.0.A.5.14_R4A. Customization : _Customized GEL_
12/013/2015 15:13:52 - INFO - Preparing files for flashing
12/014/2015 15:14:11 - INFO - Please connect your device into flashmode.
12/014/2015 15:14:20 - INFO - Device connected in flash mode
12/014/2015 15:14:21 - INFO - Opening device for R/W
12/014/2015 15:14:22 - INFO - Reading device information
12/014/2015 15:14:22 - INFO - Phone ready for flashmode operations.
12/014/2015 15:14:22 - INFO - Opening TA partition 2
12/014/2015 15:14:22 - INFO - Current device : E2104 - WUJ01HM62Q - 1293-7868_R4A - 1290-6614_24.0.A.3.8 - WORLD-a_24.0.A.3.8
12/014/2015 15:14:22 - INFO - Closing TA partition
12/014/2015 15:14:22 - INFO - Start Flashing
12/014/2015 15:14:22 - INFO - Processing loader.sin
12/014/2015 15:14:22 - INFO - Checking header
12/014/2015 15:14:22 - INFO - Flashing data
12/014/2015 15:14:22 - INFO - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_10 / Bootloader status : ROOTABLE
12/014/2015 15:14:22 - INFO - Max packet size set to 512K
12/014/2015 15:14:22 - INFO - Making a TA backup
12/014/2015 15:14:22 - INFO - Opening TA partition 1
12/014/2015 15:14:22 - INFO - Start Dumping TA partition 1
12/014/2015 15:14:22 - INFO - Finished Dumping TA partition 1
12/014/2015 15:14:22 - ERROR -
12/014/2015 15:14:22 - ERROR - Error dumping TA. Aborted
12/014/2015 15:14:22 - INFO - Start Dumping TA partition 2
Old 10-12-2015, 03:16   #637 (permalink)
Member: 1339076
Thanks Meter: 30
e2104
Old 10-12-2015, 03:46   #638 (permalink)
Member: 1339076
Thanks Meter: 30
pls help i write thies file patten lock still there
Xperia E4 E2104 24.0.A.5.14_R4A lock remove.ftf
Old 10-12-2015, 15:59   #639 (permalink)
Member: 2289488
Thanks Meter: 6
Plzzzz upload E4 E2115 kitkat version unlock ftf file.....
Which uploaded on server is not work on new version....
Got error which najeebsalam got error in E2104.
Or is there other solution. To fullfill this error
Old 10-13-2015, 12:32   #640 (permalink)
Member: 2351559
Can I unlock a device without losing any data with this program?
Old 10-13-2015, 12:40   #641 (permalink)
Member: 2289488
Thanks Meter: 6
Where is Jamesjerrs Sir......
V All NeeD ur help.....???
Old 10-13-2015, 12:44   #642 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Use latest version of flashtool http://forum.gsmhosting.com/vbb/f778...-here-1669307/
Will upload new files
Old 10-13-2015, 12:56   #643 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
New files Uploaded Today
Use Latest Version Flash Tool (0.9.19.10)
Xperia C5 Ultra Dual E5533,E5563 lock remove.ftf
Xperia M5 Dual E5633,E5663E,E5643 lock remove.ftf
Xperia M5 E5603,E5653,E5606 lock remove.ftf
Xperia Z5 Dual E6633,E6683 lock remove.ftf
Xperia Z5 E6603,E6653 lock remove.ftf
Xperia Z5 Compact E5803,E5823 lock remove.ftf
The Following 3 Users Say Thank You to jamesjerss For This Useful Post:
Old 10-13-2015, 14:25   #644 (permalink)
Member: 2209517
Thanks Meter: 134
add ling easy-firmware.com
REMOVE LOCK SCREEN | Easy Firmware
The Following User Says Thank You to h11kurd For This Useful Post:
Old 10-13-2015, 15:29   #645 (permalink)
Member: 2289488
Thanks Meter: 6
Thanx for reply ...
I alreadt using latest version thn also i got same error...
I m not confrm but i think.its a file version issue....
Can.u plzzz provide the unlock ftf of E2115 kitkat latest version file.....
Which u have uploaded thts a old ver.
Thnx in.advance
Page generated in 0.28320 seconds with 8 queries
