Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
06-08-2015, 18:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Any boot damage solved In E3 D2212 CARD SERIAL xxxxxxxxx USBFLASH DRIVER VERSION 03.00.00.00 CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 11 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use SAHARA protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 7xxxxxxx HARDWARE ID : 04000100E1008000 HASH :B77943D5B24F7012CB12EB2FF857C69EAA6518C0E58957AA7 0C0B0590E1F3BCA PHONE NOT SUPPORTED IN THIS MODE FAILED TO SETUP PHONE Elapsed: 20 secs. |
The Following User Says Thank You to DYNET For This Useful Post: |
06-11-2015, 09:24 | #2 (permalink) |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Problem Solve after write this modified file use this file as APP part of 18.5.B.0.26 firmware. With Sign mode and alternate bypass https://mega.co.nz/#!w5c3mDwS!ERKkz8...MfNnNsBNdMhS64 Thanks the_laser Forum setool And Team Regards DYNET CDMA_HOSTING.COM |
