Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
08-14-2015, 01:27 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | c6903 repair boot some body flashed c6903 with c6602 firmware i get the phone in this condition when connect holding vol down with setool pc detects as zeus flash interface in win 7 32bit here is the log when I try to repair dead boot with s1tool.here is the log Code: Welcome S1 Tool [06.02.2015]. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCEDURE STOPPED BY USER Elapsed:64 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... waiting for reply thnx in advance and happy independence day stuck here happy independence day stuck here will use DLOAD protocol ... |
