I was trying to flash a D2203 but went dead maybe becasue the USB port was not good abd the cable move when flashing... Any solution now no resposne from PHONE at all... Battery 3.72 V...
log from flastool:
17/037/2016 12:37:28 - INFO - Device connected with USB debugging off
17/037/2016 12:37:28 - INFO - For 2011 devices line, be sure you are not in MTP mode
17/037/2016 12:37:36 - INFO - Device disconnected 17/038/2016 12:38:47 - INFO - Device connected in flash mode
17/038/2016 12:38:47 - INFO - Opening device for R/W
17/038/2016 12:38:48 - INFO - Reading device information
17/038/2016 12:38:48 - INFO - Phone ready for flashmode operations.
17/038/2016 12:38:48 - INFO - Current device : D2303 - ZH8002XQQ0 - 1281-1574_R12B - 1278-3081_18.3.1.C.1.17 - GLOBAL-LTE_18.3.1.C.1.17
17/038/2016 12:38:48 - INFO - Start Flashing
17/038/2016 12:38:48 - INFO - Processing loader.sin
17/038/2016 12:38:48 - INFO - Checking header
17/038/2016 12:38:48 - INFO - Flashing data
17/038/2016 12:38:49 - INFO - Processing of loader.sin finished.
17/038/2016 12:38:49 - INFO - Loader : S1_Root_f82d - Version : LOADER_RELEASE_MSM8X26_28_AID_4 / Boot version : S1_Boot_MSM8x26_LA1.0_38 / Bootloader status : ROOTABLE
17/038/2016 12:38:49 - INFO - Processing partition.sin
17/038/2016 12:38:49 - INFO - Checking header
17/038/2016 12:38:49 - INFO - Flashing data
17/038/2016 12:38:51 - ERROR - Processing of partition.sin finished with errors.
17/038/2016 12:38:51 - INFO - Ending flash session
17/038/2016 12:38:51 - ERROR - Read error :31 : A device attached to the system is not functioning.
17/038/2016 12:38:51 - ERROR - Error flashing. Aborted
17/038/2016 12:38:51 - INFO - Device disconnected
17/038/2016 12:38:54 - INFO - Device connected with USB debugging off
17/038/2016 12:38:54 - INFO - For 2011 devices line, be sure you are not in MTP mode
17/039/2016 12:39:07 - INFO - Selected Bundle for Sony Xperia E3 (D2203). FW release : 18.5.C.0.25. Customization : ES
17/039/2016 12:39:07 - INFO - Preparing files for flashing
17/039/2016 12:39:11 - INFO - Device disconnected
17/040/2016 12:40:11 - INFO - Please connect your device into flashmode.
17/041/2016 12:41:20 - INFO - Device connected with USB debugging off
17/041/2016 12:41:20 - INFO - For 2011 devices line, be sure you are not in MTP mode
17/041/2016 12:41:44 - INFO - Device disconnected
17/048/2016 12:48:52 - INFO - Flash canceled
