Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
05-11-2019, 22:48 | #1 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Ramkon
Member: 2414762 Status: Offline Thanks Meter: 47 | D6633 bootloop on recovery after update My phone alert for sodtware update and download is complete after that phone restart and then process is go near to 50% but it stop, then restart and now it bootloop into recovery mode, i try to flash but PC dont recognize it i don't know why, USB sucket is OK and when i hold vol down and connect it to PC the green light is on. What should i do guys? i don't have SETools. |
05-14-2019, 17:40 | #2 (permalink) |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | Hi try this solution should help without problem. After install this software all drivers will be installed correctly, I think you got now problem with drivers because this phone not see after connect in flash mode. Sony Xperia Z3 Hard Reset manual by HardReset.info Team Here is second manual more complicated but can write to phone firmware version like you want and language what you need. Sony Xperia Z3 Flash Update, repair manual by HardReset.info Team |
The Following User Says Thank You to IMEI_info For This Useful Post: |
05-14-2019, 21:20 | #3 (permalink) | |
Member: 2414762 Status: Offline Thanks Meter: 47 | Quote:
Right now i can flash another Z3 without problem. | |
05-15-2019, 16:23 | #4 (permalink) |
Member: 2771307 Status: Offline Thanks Meter: 772 | Then charge battery at least 6h then try flash again. I think your phone battery was discharged when you try to flash and should be at least 60% and there is a problem. Charge battery a few hours like I write and will communicate with a computer after. |
